Leximark X1185 Printer needs a code # from new ink cartridge to resume operation of printer. Code # was lost with recycling of container. Is there another code that can be used?
  • Susan Emerson Feb 04, 2010
    It is a recycled, or "remanufacturd cartridge" ...but I still sent the code number back, (unknowingly, when I sent everything in right away with the green packaging). Then I realized I needed that number, to get the ink started after installing it in the printer. So, is there a universal (or override) code I can use ??? Also there's a prompt where you have to specify whether it is New or Old. I'm assuming it's considered "new"... Thanks.
Is it a recycled cartridge or a new genuine one?
Posted on Feb 04, 2010
  • Anonymous Feb 04, 2010
    Hello
    Thanks for your reply. Yes, the option would be "New". I'm afraid after looking into this I could not find a universal code. You are correct in that a universal code is what you need.
    I have been able to find a website that provides steps for most Lexmark's but the X series isn't listed. Maybe you could try some of those steps as they may be similar to the reset method for your printer model.
    Should these not work you may need to contact the company where you recycle the ink for an alternate code, I'm sure they can issue a new one.
    Kind regards
My Canon Pixma MP220 is has an error code U051 Chk Ink Blk Col, but i have just refilled my ink cartridges
Using refilled ink cartridges will get this error. You have to reset the waste ink levels by doing the followin
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. green led should be on
  3. hold the Power button, release Resume Button.
  4. Without releasing the Power Button, double click “Resume” button and then release Both Buttons.
  5. Click “Resume” for four times then click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Aug 12, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Lost my manual, need to change the ink cartridge, help
  1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
  2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Error code e22 flashing on display ever since we put in new ink from tesco
CANNON Printers ERROR CODE
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
might have to reset the waste ink this way :
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
Feb 18, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Lexmark z25 printer light keeps blinking, will not print
Have you used this printer before? Is it new? The flashing green light means that the ink cartridge needs to be replaced. Make sure you have the ink cartridge in correctly and seated down completely. Otherwise, it may be a defective ink cartridge.
Mar 29, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Oct 03, 2008 | Office Equipment & Supplies
Canon BJC 3000 does not print - 6 orange 1 green
Clean the connectors located on the Printhead and the Printhead Carrier... It solved the problem in my case...
Nov 11, 2007 | Canon BJC 3000 InkJet Printer
Lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
Oct 11, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
