Question about Kitchen Appliances - Others
Friedland door bell push doesn't work
How do I open the friedland door bell push in order to replace battery ?
3 Suggested Answers
  • 1212 Answers
SOURCE: Friedland Evo Wireless Door Chime and Push Problem
While this is a little bit of a stab, if you replace the batteries in both units, do it at the same time, If the batteries are known good ones, simply take them both out and let the units sit for about 5 minutes before you put them back in. Make sure the battery contacts are clean and devoid of corrosion. Put them back together without pressing the button. I assume it is of the newer "self learning" style. In which case, hold the ringer button down until the chiime goes off.
If it is one of the optical greeters, there would be a setup switch position that allows you to focus/align the reflector for the greeter. Usually it keeps chiming until the alignment is correct whereupon it shuts off when things are right. Then you reset the switch to normal. If no switch for set up at all- just follow the same procedure until it stops. You can usually "eyeball" them pretty close without effort.
Posted on Dec 31, 2011
  • 25 Answers
SOURCE: radio, dome light and door open warning bell doesn't work
try changing fuses any way somtimes there dirty or coroted and dont make good contact even though they test good and look good still could be the problem
Posted on Mar 02, 2012
Diagram for connecting a battery operated door chime to push button
IF you are going all elec,you need a door bell,bell transformer and of course the push button. This is all low voltage so phone wire will work.You are just using 1 pair of wires so pick a pair such as the blue pair.Wire from push button to transformer to door bell.It is not polarity senstive....simple to do
Mar 17, 2015 | Cars & Trucks
Wiring diagram friedland door chimes
These are installation and wiring instructions for the Friedland 954 Door chime.
wiring-diagram-friedland-door-chimes-k3ydjvglpspjo3gx23qxrs40-1-0.jpg wiring-diagram-friedland-door-chimes-k3ydjvglpspjo3gx23qxrs40-1-2.jpg wiring-diagram-friedland-door-chimes-k3ydjvglpspjo3gx23qxrs40-1-5.jpg wiring-diagram-friedland-door-chimes-k3ydjvglpspjo3gx23qxrs40-1-9.jpg
Jun 24, 2013 | Cars & Trucks
Will my wireless bell push work with another manufacturers door chimes?
Doubtful they are compatible. If they are set by dip switches and you set them the same bot doesn't work-not compatible.
Jul 17, 2012 | Home Security
Radio, dome light and door open warning bell doesn't work
Mar 02, 2012 | 1997 Dodge Neon
Dec 30, 2011 | Home Security
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Mar 09, 2011 | Desa International White Wireless Plug In...
Button Press (Not Remote) Normal Door Bell Makes Slight Buzz Only
The electromagnet that causes the bell clapper to move when the circuit is closed by pushing the button is failing. Replace the bell unit.
Jul 07, 2009 | Desa International White Wireless Plug In...
Kitchen Appliances - Others Logo
304 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
