Question about Lexmark X340n All-In-One Laser Printer
I have a x340 all in one. The paper tray was slammed shut to hard and now there is no power. I suspect the wiring directly behind the paper tray. How do I get a wiring diagram
  • Official Brand Answer
  • 3,344 Answers
In this case I will recommend to replace the Low Voltage Power supply. For what you are saying maybe something got damaged in the LVPS.
Posted on Feb 09, 2010
Wont print. Cant detect paper.
There's a problem with the software in the unit. Brother does no longer offer software updates. You can try and power off the unit, unplug the USb cord from the back of the machine. Wait 1 minute, plug the USB back in and power the unit up. After unit cycles, should be ok. If not, uninstall/reinstall the software///
Jul 22, 2014 | Brother MFC-9840CDW Laser Printer
It ses "no tray reinstall
it sounds like the tray is not seated. pull the tray out make sure the paper is where you want it and not stuck half way out and well fast and firmly slam it shut. and remember we are dealing with plastic here so no motions with your feet! If it still isn't take out tray and power down unplug from wall and wait 3 minutes then plug in and let it warm up then add the tray back.
here is the manual for your reading enjoyment
http://www.fixya.com/support/p643805-brother_mfc_9440cn_laser_printer/manual-33405
Jun 21, 2011 | Brother MFC-9440CN Laser Printer
A fault or error has occurred. Code 010-327
Solution : Power the Machine OFF and ON CAUTION: Wait at least 30 seconds between powering the machine OFF and powering the machine ON. Damage to the optional hard disk could occur.
  1. Press the power switch to the OFF (O) position.
  2. NOTE: If the machine is equipped with the optional hard disk, the machine remains on for approximately 10 seconds, while storing files and preparing for shutdown. The machine then shuts down completely.
  3. Press the power switch to the ON position.
IF THAT FAILS TRY THIS NEXT:
Solution : Clear the Paper Jam Behind Cover A
  1. Open Paper Tray 5 (Bypass Tray).
  2. Lift up the Cover A release lever, and open Cover A.
  3. Remove any paper below the Fuser Unit by carefully pulling up and out.
  4. WARNING: Do not touch the Fuser Unit, as it may be hot.
  5. If the jammed paper is inside the Fuser Unit, lower the green A2 lever in the direction of the arrow to open the Fuser Unit Cover.
  6. Push down and rotate the green A1 lever in the direction of the arrow to feed the paper from the top of the Fuser Unit.
  7. NOTE: Do not pull paper downward during removal.
  8. Close Cover A until the cover latches.
  9. Close Paper Tray 5.
For pictures on this procedure please follow link: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=218,E=0000000002703126506,K=8100,Sxi=4,Solution=obj(1027)
Hope it helps!
Apr 22, 2011 | Xerox WorkCentre PRO 128 Copier
ERROR CODE 010-327
Hope it helps!
Apr 07, 2011 | Xerox CopyCentre C128 Black and White...
Xerox CopyCentre C128 Black and White Copier Fault 010 327
  2. NOTE: If the machine is equipped with the optional hard disk, the machine remains on for approximately 10 seconds, while storingfiles and preparing for shutdown. The machine then shuts down completely.
Hope it helps!
Feb 27, 2011 | Xerox CopyCentre C128 Black and White...
Hope it helps!
Sep 14, 2010 | Xerox WorkCentre PRO 128 Copier
How to open tray when it don't want to open
You can manually eject the tray, you have to take the faceplate off to do this, but here is the instructions:
http://www.llamma.com/xbox360/repair/manual_eject_xbox_360_dvd.htm
Aug 11, 2009 | Microsoft Xbox 360 Console
Describe your Minolta Di3010 Grayscale CopHi I
The error code you are getting is a paper tray lift problem. Open all the paper trays and make sure that you have the correct size paper in each paper tray. Also, make sure the paper guides are tight againest the paper in the trays. Turn the copier OFF then back ON... Wait for the copier to come to ready and one tray at a time reinstall each tray at a time.... The one that cause's the error code to show up is the paper tray with the problem. Once you know what tray is the problem, remove the tray and look inside the copier for a wade of paper jammed behind the tray... If not you may have a bigger problem, then we can help with... Good Luck....
Jun 26, 2009 | Minolta Di3010 Copier
200.13 paper jam remove cartridge
The Lexmark x340 and x342n has 3 sensors that identify the path of the paper below it.
2 are below the feeder roll of paper and the other in fusion.
Clean the sensor or adjust the tamnho the paper tray to which the document is.
Vagner
Jun 19, 2009 | Lexmark X342n All-In-One Laser Printer
Hp 4000 roller replacement
Sorry, I forgot I posted this. I figured out how to get the rollers off and back on. The problem now is that I replaced the smaller rollers but it is still failing to pick up the paper. It worked well for about 3 days and is back to the same paper jam error, minus the groaning. Any ideas? These would be the intake rollers on trays 1 and 2.
Nov 05, 2008 | HP LaserJet 4000n Printer
Lexmark X340n All-In-One Laser Printer Logo
197 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
