Question about Vacuums
Replacement drive belt westinghouse wired wst1300
Location were i can find the part my address fort lauderdale florida code 33313 thank you
    President:
  • 1,673 Answers
You will just have to look in your phone book for repair shops, one of them should be able to help you get the part you need.
Posted on Feb 21, 2008
I NEED TO FIND A PERSON THAT CAN REPAIR MY PRESSURE COOKER.MODEL #CEPC800 0206 ZIP CODE 33435 FLORIDA.
Hi Pat,
Here is the web address for the CEPC800. I hope this is the one you're looking for.
http://www.qvc.com/man/k/k37000_man.pdf?&cookie=set
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Apr 27, 2011 | Vacuums
The brush is not moving is that mean the belt is not working
Yes, the belt is probably too loose or broken...
replace the belt first before trying anything else..
heatman101
Aug 04, 2010 | Westinghouse WST1550 Wired Deluxe Upright...
IRobot is only moving 1 inch back and fort, wheels are clean
You will need to replace the cliff sensors. One one two IR LEDs are damaged.
Apr 12, 2010 | iRobot Roomba 560 Robotic Vacuum
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
How to dismantle to replace brush drive belt
Check for cross head screws on top of the hood. Usually located either near the pedal release and then on the other side. Either that or flip the machine over and you should be able to locate screws on the underside that will remove the sole plate. Once that's done dont lose the screws - if either top or bottom is removed you should be able to access the drive belt.
Apr 01, 2009 | Sunpentown V-8506 Bagless Upright Vacuum
Broken Belt for Fantom Crosswind 600XL
Hello, your Fantom vacuum will take a Panasonic U vac belt, to replace it, their are two screws in the back, one on each side of the back of the housing, take out the two screws and lift off the top hood, and the vac belt is on the side, remove the brush roller clean any debis away, put the new belt around the metal motor shaft first then around the brush roller, and pull down into the housing, make sure it locks in evenly, then turn the roller to make sure it moves freely. then put the hood back on front first, hold down and put the screws back in, in the back. now your ready to vacuum. Any question or more help I can give, please call 1561-848-3387 Thank you, Teresa.
Jun 16, 2008 | Westinghouse WST1550 Wired Deluxe Upright...
Spot Bot
Their customer service # is 1-800-237-7691 and they can tell who to call for service. You can also go to bissell.com, there is a link for service centers, just put in your zip code and a list will come up.
BISSELL Service Center Locator Please enter your ZIP Code: CANTRELL SUPPLY INC. 2918 SOUTH COOPER F-2 ARLINGTON TX, 76015 (817)465-9121 11.1 miles BRANCH VACUUM & JANITORIAL SUPPLIES, L.P. 12895 JOSEY LANE #122 FARMERS BRANCH TX, 75234 (972)247-5838 15.7 miles FORT WORTH SHAVER & APPLIANCE 1900 MONTGOMERY STREET FORT WORTH TX, 76107 (817)335-9970 16.3 miles AMERICAN VACUUM CO. 5545 W. LOVERS LANE DALLAS TX, 75209 (214)357-8419 18.2 miles KIRBY CO. OF DALLAS 4118 MAPLE AVE DALLAS TX, 75219 (214)526-7951 19.0 miles BRUNER KIRBY CO., INC. 5608 MC CART AVE. FT. WORTH TX, 76133 (817)292-8421 19.4 miles VACUUM DEPOT 5359 WEDGEWOOD FT WORTH TX, 76133 (817)292-4472 19.4 miles MODERN AMERICAN MAINTENANCE 8545 CAMP BOWIE WEST FORT WORTH TX, 76116 (817)244-0919 19.9 miles ALL VAC, INC 4451 LOVERS LANE DALLAS TX, 75225 (214)521-2558 20.2 miles KIRBY CO. OF DESOTO 104 N. HAMPTON ROAD DESOTO TX, 75115 (972)223-4029 23.8 miles AAA VACUUM CLEANER CO. 9845 WALNUT HILL LANE DALLAS TX, 75238 (214)348-1620 25.0 miles BROADWAY VACUUUM 4401 BROADWAY BLVD GARLAND TX, 75043 (972)240-7971 31.1 miles THE VACUUM DOCTOR 500 NORTH GALLAWAY - STE. 10 MESQUITE TX, 75149 (972)329-1104 31.4 miles CHAMPION VACUUM, INC. 8809 LAKEVIEW PARKWAY #128 ROWLETT TX, 75088 (972)463-2755 34.3 miles VACUUM & SEWING DR. OF TERRELL 811 WEST MOORE, SUITE E TERRELL TX, 75160 (972)563-0330 49.8 miles var prm = Sys.WebForms.PageRequestManager.getInstance(); prm.add_initializeRequest(resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity); prm = null; function resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity() { var elAct = $get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity'); var bounds = Sys.UI.DomElement.getBounds($get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_upServiceCenter')); elAct.style.width = bounds.width + 'px'; elAct.style.height = bounds.height + 'px'; Sys.UI.DomElement.setLocation (elAct, bounds.x, bounds.y); } Locating Stores... progressbar.gif
Feb 29, 2008 | Bissell 12005 Spot Bot Handheld Vacuum
How do I open the vacuum assembly?
you have to take the headlight lenses off with a small screwdriver. then a philips screwdriver to take the 2 screws out. one each side. then remove the foil shields on each headlight . then snap loose the rear plastic clips on the cover and it will come right off. it took me an hour to find out how and 10 minutes or less to take it off. watch for the micro switch on the circuit board being worn out.it will stop the roller brush from turning.its a dollar part at any good electronics store ,but will have to be soldiered in or service might have a few from the westinghouse line .so will a broken belt which is a special grooved belt available from fantom at 18007987395..
Jan 11, 2008 | Westinghouse WST1550 Wired Deluxe Upright...
Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Dec 25, 2007 | Westinghouse WST1500 Wired Special Edition...
Vacuums Logo
91 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
