Question about Advent 4211c Notebook
Have an advent..use 3 dongle to connect to internet...in an area where there is no signal..this house has a router for wireless but i cannot get on..help..
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 86 Answers
Try to power cycle the modem as well as the router , disconnect all the filter and then turn off the modem and turn it back on make sure all lights are in green then try to connect internet cable first check if you have internet connection using cable then try to set-up your wireless connection again .
ERNZ
Posted on Feb 04, 2010
Advent 9315 wifi
How are you connecting to the internet?
1. Wireless
2. Wired
This can have an effect on the speed. A wired connection is not subsceptable to any interference and wont slow down from it.
A wireless connection can be slow because of the router, other things that broadcast radio signals, other things that broadcast non radio signals (like flourescent lights.)
How are you testing the speed? Unless you go to a website that has a speed test program or you are running a speed test application, there is no way to know for certain that your speed is what you believe it is. Your speed can also change due to the amount of people on the internet and other things like equipment failure outside your house.
Mar 31, 2014 | Zyxel Computers & Internet
ADVENT 4211-B KEEPS DROPPING WIRELESS CONNECTION
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls, mirrors, fish tanks and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Apr 06, 2013 | Advent 4211c Notebook
Why does my internet keep dropping?
change your connection system
you can get TP link units that plug into the house electrical system and run ethernet cables from the computers on a home network system
works like a charm over any distance on the same power circuit for the house
may be a wireless dongle will fix your problem
Apr 11, 2017 | Motorola Computers & Internet
Dlink dir-142 Dodo usb prepaid dongle t12146l140 no connectivity optus usb prepaid dongle e169 responsive, no internet coverage connects with nintendo 3ds but no internet connection. windows xp...
plug the usb modem into usb slot of pc as normal.
Bridge the connection between the internet connection and ethernet router connection in network page.
Set router to ip add etc and it should share net access while pc is turned on atleast.
Jun 14, 2011 | D-Link DIR-412 Mobile Broadband Wireless...
How to go wireless on laptop
You need three things
1) An Internet service provider. Once you sign up and agree to pay the fee they will provide the internet service.
2) A wireless router. This is a unit that receives your internet service by through a connection to your telephone line. Then it transmits a radio signal (wireless signal) that your laptop can receive.
3) A Wifi card in your laptop or an external USB Wifi Dongle. This is a radio or wireless receiver that picks up the signal from your router.
The router is usually security protected with a keycode. All you need to do is set up your Wifi card or dongle with the same keycode and you will be able to receive the internet wirelessly.
To check to see whether your laptop has a Wifi card already installed, do the following:
Click Start>Programs>Accessories>Communications>Network Connections> and look for "Wireless Network Connection." If you have this, then your computer has a Wifi card installed and ready to go.
Aug 27, 2010 | Computers & Internet
Laptop driver needed
You dont need a driver for the wireless router. If your laptop can recieve wireless signal(from a wireless router) all you need is an active internet connection, configure the laptop and router to distribute the internet, you're good to go.
If your laptop cant recieve a wireless signal from a wireless router then you might need a USB Wifi Dongle.
Apr 06, 2009 | Linksys Wireless-G VPN router with...
Can't connect with 2nd computer...
1st.  What brand and model # of your router? 2. The router cd should be run only on the computer u have connected to the router with a network cable. Your vista laptop. Is it connected with to the router with a cable? 3. If so, it will be the one used to configure your router for wireless setup. When you ran the setup it should have gone thru Wireless Setup. It will ask you for an SSID. That is a name you will give your wirless network. It can be anything you want. just remember it.  It will also ask you to setup security for your wireless network. follow the instructions to setup a password. write it down. This is an important step so anyone cannot just logon to your wireless signal an start using ur internet connection or gain access to your computers. 4. when u setup your dongle on your kids computer it will search for wireless signals in the area. you will look for the one u setup in the previeous step. you will select it and it should ask you for the passkey you setup. once connected you will have access to the internet.
Think of your router as a private radio station and the wireless usb dongle is the radio. The only way your computers can tune to it is using the dongle and if you know the name of the station (your SSID) and the passkey.
Mar 26, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
2wire gateway signal range problems
1. Put the router in the highest location possible in the house.
2. Make sure the gateway is installed in the center of the house rather than in a corner of house, so it will cover area on all sides.
3. Make Sure you dont have any devices that may interfere with the signal eg. cordless phone , close to the gateway.
4. Use channel 3 or 7.
Mar 23, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Usb adapter
if the router is already set up the usb dongle software will need to be used to connect to the router to allow a connection without the need for a cable as the dongle will see the wireless signal
Aug 31, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Connecting WUSB100 to Wireless G WRT54G
laptops have a wide range reciever built around the screen and tend to be far better than a normal usb dongle.
The fact that your pc is downstairs will be effected a lot because the signals from the router will be bouncing around in an area around the antenna and above, signals below will be effected by floors, doors and wall partitions.
Your best solution would be to place the router on a phone line downstairs and see if the signal is increased.
Aug 18, 2008 | Linksys WUSB100 Wireless Adapter
Advent 4211c Notebook Logo
103 people viewed this question
Top Advent Computers & Internet Experts
Lee Durbin
Lee Durbin
Computer Links
Are you an Advent Computer and Internet Expert? Answer questions, earn points and help others
