Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Just replaced transfer unit in my biz hub c250 get error code c-3152
  • 1 more comment
  • victoria cooke Feb 04, 2010
    the technican replaced the transfer unit today ---don't think he knew what he was doing. now i get the error code c2152 ---- plus i can not open the right hand door as it is jammed. any ideas???
  • victoria cooke Feb 05, 2010
    fixed the door, transfer unit had paper onit now we get error code 5357. what now???
    Thank you there was a jam in the right door due to the metal bracket with the white plastic guide being bent down. We had to remove many parts in order to remove the hinges on the door to remove. We rebent the metal bracket into place but were unable to reinsert the white plastic guide. We found the technican had left some tape on the new transfer unit. we were able to get rid of the previous code but now have the CODE 5357. I can not find any info on that code
  • 1,110 Answers
There is no C3152 error code in the service manual. There is a C2152 code which related to the transfer belt. I am including info for that code in case it is the one you have.
C2152 Transfer Belt Separation • The 1st Image Transfer Pressure/Retraction Position
Sensor doesn't turn ON (Retracting) even
after the lapse of a given period of time after the
1st Image Transfer Pressure/Retraction Clutch
has turned ON during the Transfer Belt is retracting.
Sensor doesn't turn OFF (Pressuring) even
has turned ON during the Transfer Belt is pressuring.
Posted on Feb 04, 2010
  • Edwin Martens
    Edwin Martens Feb 04, 2010
    Your 2 issues are most likely related as the right hand door gives you access to the image transfer belt unit. If you just had this unit replaced my recommendation is to call them back out to fix it under warranty. If you get into this yourself you are allowing the service company or person to have an out and say that it was what you did that caused the problem. As much as you may need the machine I would make them fix the problem. I would recommend that you NOT try effect any repairs yourself.
    Good Luck
  • Edwin Martens
    Edwin Martens Feb 05, 2010
    C5357 Cooling Fan Motor/1’s failure to
    turn
    • The Fan Lock signal remains HIGH for a predetermined
    continuous period of time while the Motor
    remains stationary
    Since you did not have this code previously I would suspect that either something was re-installed incorrectly and is blocking the fan from turning or there was a connector left un connected or a connector was knocked loose.
    I would recheck the items you took apart and look for any loose or disconnected wiring connectors.
Biz hub c35 remove waste toner botle
located below the image unit follow instrution and replace
Feb 04, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica minolta biz hub C250 need to reset admin code URGENT
you cannot overide the administrator password on the konicas the default password is 12345678 try that
Oct 30, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Error message sc36-05on my biz hub pro c 500, we cleared a paper jam now this error comes up
Thats a low temp fuser code. You need to reset the code by going into "25 Mode" and reset dip switch 3-1 _ 1 to 0
Oct 11, 2009 | Konica Minolta bizhub C250 All-In-One...
Image ghosting only on magenta
If the ghost is only on the magenta, your imaging unit is to blam.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Oct 08, 2009 | Konica Minolta bizhub C250 All-In-One...
To enter service mode on biz hub c 500 what is the key order?
Lost my access to add employee name to scan docs Biz 500/420
Jan 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
267 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
