Question about Brother HL 2140 Laser Printer
Printer sqeaks loudly when printing. Also there
Printer sqeaks loudly when printing. Also there are foggy black spots on right side of printed document
  • 150 Answers
Sqeaks are hard to fix over the computer but if the black spots are random change the toner cartridge. If they are 3 or 4 to the page change the drum.
Posted on Feb 05, 2010
Hp 2200dtn prints fine but makes loud friction noise
Old age printer, Remove right,left, back & top doors. check fuser assm screws tighten or slacked? if its slacked use more lengthy screws for tighten the fuser.Apply grease for the gears to avoid the friction. Open main motor assembly clean entire gears, lubricate & fix it back..Check any gears are warn out, replace it if possible...Best of luck..
Jan 04, 2012 | HP LaserJet 2200dtn Printer
Black spots on printed sheets. I think the rollers need cleaning. I have a Ricoh Aficio AP 600
If you are getting black spots on printed sheets,
you should clean the rollers or replace it.............
thank you.........
Jul 23, 2011 | Ricoh Aficio AP600N Laser Printer
I want to print metallic gold and gold-foil TITLES on a standard CMYK background with an Alps 5000P. What is the procedure to overlay the spot color where I want to print the gold?
Create a mask or layer for each spot color you want to print using only black. When printing spot colors anything on the mask in black will be printed in the spot color. For foils, print a couple of layers of black ink before you print the foil to get a very good effect. Remember to check the overlay option so the paper doesn't get ejected.
Nov 11, 2010 | Alps MD 5000 Thermal Printer
What can we do about dark toner spots that are appearing on the right side of documents we print? We have tried using a can of air spray to clean the inside of the printer, but to no avail.
I have a Brother HL 4040cn color laser printer and I had the same problem. On every page I printed there were these black dots that appeared down the right side of the page in regular intervals. I tried the automatic drum cleaner and that didn't work. I opened the printer from door, removed the black toner cartridge and looked at the drum. Sure enough there was a speck of black crusted toner stuck to the drum. I used a q-tip and lightly scrubbed at the spot to remove the toner then I used the gear on the left side of the drum to rotate it and check for any other smudges and there were none. Put the toner cartridge back in and it was good to go again...no black dots!!
Hope this helps someone because I couldn't find the solution myself when I searched.
Sep 22, 2010 | Brother Office Equipment & Supplies
White ink printing with alps MD 5000
To print white, you need to use the spot color option in the printer properties. The object to be printed must be all black. It seems counter to what you might think, but the spot color mode will print the solid black areas as the selected spot color.
Mar 09, 2010 | Alps MD 5000 Thermal Printer
Sqeaking noise when printing. Need to be cleaned?
Your printer head that moves side to side while printer is on a bar. There is no cleaning, it just means that you printer printed too much.
Nov 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp 3310 all-in-one injet spilling black inside unit
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 07, 2009 | HP Photosmart 3310 All-In-One InkJet...
BLACK LINE ALONG RIGHT SIDE OF LETTER SIZE PAPER
Is this and Okidata C5100? And is the stripe vertical up and down on the page? I'm going to assume yes to both of those for the sake of trying to help. Worse case is the fuser unit in the machine is wearing in one spot and thats why the streak is appearing. Also, many color printers require a seperate drum unit or photo conductor unit. These could have a wear spot on them as well. They can fail long befor the change drum light appears. Other than that remove and inspect the black cartridge. If there is a shutter on it, pull back and inspect the two inner rollers. You're looking for any wear spots in a location that corresponds to the streaks on the paper...or an excessive amount of toner leaking from one spot on it. Hope this helps!!
May 21, 2009 | Office Equipment & Supplies
Black spots of the left side of the print
If you know how to remove your drum cartridge, take it out and check if you don't see your black spot on your drum....If so, replace your drum cartridge.
You may have a bad fuser to....
let me know !
Apr 01, 2008 | Samsung Laser Multifunction Printer Toner...
Brother HL 2140 Laser Printer Logo
899 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
