There is 2-3 screws in the top of of your microwave that go the cabinet and it should have a bracket on the wall that the microwave should hinge off the wall from
This is a two person job. You have to have one person holding it and the other takes the screws out from the cabinets above the unit. There should be two screws that are inside the cabinet that hold it up against the bottom of the cabinets. When those are loose you can slide the unit forward on the rails that attach to a large wall bracket. Or some use a lift type latch to the wall bracket.
To remove, you will need to remove four bolts on the top of the unit.
Unplug it first, then remove the two bolts nearest the wall first. It would help to place something under the front of the unit about two inches shorter, to catch the unit as you remove the front bolts. The bolts are long, so be prepared for a lot of turns. A ratchet helps. The unit will lower in the front as you remove the last bolt. There is a bracket screwed to the wall behind the unit, with a lip at the bottom that holds the back of the unit. After the front has lowered, lift the back up about an inch, and pull the whole unit away from the wall. Remember to pull the power cord out of the cabinet before moving the unit away. Hope this helps.
If it's like most above-the-range microwaves, there will be 2 or 3 screws holding it from above, inside the cabinet
While supporting the unit from below, remove screws.
The rear of the unit is supported by hooking onto a bracket that is screwed to the wall behind it.
The rear needs to be lifted, then the unit should pull away from the wall. Requires some muscle.
If there is a grill above the door, remove it. There will be two long screws that attach the unit to a metal plate. The metal plate is bolted to the wall. Once you loosen the long screws, the unit will tilt down and come off the wall.
Typically there is a metal mounting plate screwed to the wall and when you take the screws out of the cabinet above it it will tilt forward toward you and then you have to lift it off of some metal tabs that are on the bottom of that mounting plate. Lift up and pull away from the wall and let the cord pull out of the hole in the bottom of the cabinet. Good luck. I usually do that by myself and hook one arm under it and lift it up, but probably better with two people.
You have a bad cavity switch. I would guess it is the one behind the vent cover, toward the left side of unit. You would need to remove unit from wall. Remove outer housing to expose cavity switch. You can see it from vent cover, I would test all cavity switches before removing from wall. You should have a diagram of unit folded up behind vent cover towards right side of unit. This tells all workings of unit. Will also tell where all cavity switches are.
Look in the cabinet above the microwave. You should see a vent if it is vented outside. You will need to remove the vent. Then look in the same area to find two screws that will need to be removed. Disconnect the power cord and have someone hold the bottom of the unit and remove the screws. It will fall at this point so hold it good. With the screws out and vent removed you will be able to let the front of the microwave down a little. This will allow you to now lift the back to release it from the channel hook in rear. Then you will see the mount plate on the wall. It should have screws securing it to the wall on stud locations. remove these screws and remove the wall plate. Hope this helps. Good luck.
There are two phillips head screws holding the unit in from the top and a slotted bracket on the wall or cabinet back. Usually you can remove the screws from the cabinet directly above the unit. Support the microwave from the front while removing the screws. CAUTION ! Use two people! While holding the unit level,lift up underneath the rear of the microwave to release it from the slotted bracket in the back and bring the microwave straight out.
