I PUT PAPER IN DRAWER AND IT CONTINUES TO SAY LOAD PAPER
  • 1234567890mi May 11, 2010
    what machine? make /model
  • 67 Answers
Check paper senseor
Posted on Aug 26, 2010
How to load paper ?
Open the paper drawer, open a ream of paper, run a finger across one edge to fan the paper and then place the paper in the drawer.
Aug 02, 2016 | Office Equipment & Supplies
Where do I load photo paper to print photos?
There are two drawers. For paper you put your fingers downwards and pull out the paper drawer. For photo paper the drawer is above it, so curl your fingers upwards in the same place and pull.
Based on my MG7120.
Jan 08, 2016 | Canon PIXMA MX922 Wireless All-in-One...
Printer model : hp425 dw I get this message: "Load
send back under warranty, first check there is not a paper jam.
Oct 28, 2017 | Office Equipment & Supplies
Toshiba 2060 Copier I PUT PAPER IN DRAWER AND IT CONTINUES TO SAY LOAD PAPER How do I check/clean sensor?
pull the paper tray from the printer turn the printer on its back to have an unobstructed veiw of the bottom on the left side of the pick wheel there is a paper out flag make sure that this moves freely. clean the pick wheels with aresol contact cleaner. this type of cleaner is good to clean all printer part as it leave no residue
Oct 03, 2010 | Office Equipment & Supplies
Canon ir3300 not communicating with microsoft windows getting error: printer load paper but trays are full. Can you help?
Under printer properties check the format of paper, it must be A4 if you have A4 in drawer. The most common fault is that under printer properties is LTR as format and A4 in drawer.
NOTICE: in paper drawer did you check the little blue wheel, is it "telling", the appropriate format as in the drawer?
Jan 19, 2010 | Canon (6981A002AA) for imagerunner 2200,...
My bosch nexxt washer will not drain the fabric softener into the load during the rinse cycle. The same amount I put into the fabric softener hopper is still there after the load is complete
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Oct 22, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Get a load paper in drawer 2 error with the paper in the drawer
Hello sir; Please check the tray paper lifting motor seems it broke, otherwise check the paper sensor .
Aug 05, 2009 | Muratec MFX-2830 Black and White Copier
Tray error
Since tray 2 works, I'd guess that each drawer has a "paper sensor" that sees that paper is in the drawer. You might pull both drawers all the way out, with a flashlight, if needed, look at the area inside of each where paper is fed and you can compare #2 with #1, since you know 2 is good. You may find a sensor out of place. If it's not something simple like it popped out of place, then you may need to put in a new sensor. Good luck, please rate this if it helped.
Jul 03, 2009 | Savin Office Equipment & Supplies
Letter Drawer 1 on Model IR5020
look behind tray for paper preventing the feed rollers from knowing there is paper there
Feb 18, 2009 | Canon imageRUNNER 5020 Copier
Lexmart C524
The printer may be trying to draw paper from a source other than the paper tray. Many printers have a hatch or slot in the front or on the side in which one can load non-standard paper sizes and envelopes. It may be trying to print there. Try to locate this place and put a few pieces of paper in there.
Sep 13, 2006 | Lexmark C524 Laser Printer
26 people viewed this question
k24674
jasbo
jasbo
