Question about Bosch 24 in. SHU43 Built-in Dishwasher
Wont drain? My dishwasher will not drain. I ran a load and now there is standing water in the bottom of the dishwasher. I had problems with my disposal earlier and think maybe it progressed down the pipe.
    President:
  • 2,468 Answers
If you have an air gap on the sink from the dishwasher and water is leaking out here into the sink instead of the drain it is probably plugged from there to the disposer or "P" trap in the drain line,also check the sump screen and down in there for food particles still there
Posted on Feb 04, 2010
Dishwasher will not drain. After I ran the load, the bottom was filled with water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Dishwashers
How to remove debris from the drain holes at the bottom of the dishwasher tub, which is preventing the tub from draining all of the water completely?
I had a similar problem when my dishwasher wouldn't drain and was causing the kitchen sink to back up. I poured a little drain cleaner in the bottom of the tub (where the drain holes are) and let it stand for about 15 minutes then ran a hot rinse cycle (don't put any dishes in the dishwasher while you're doing any of this). The water still hadn't all drained but after a day or two of not using the dishwasher it drained on it's own and hasn't had any problems since. I would recommend reading your manual to make sure that using drain cleaner doesn't void any warranty you may have. Also, it's a good idea to do an empty rinse cycle at least once so that there's no chemicals getting on your dishes.
Aug 23, 2010 | Dishwashers
Doesn't drain; glasses have film; rinses with used, soapy water
The white film problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Sep 02, 2009 | Dishwashers
Need Help Regarding Draining Problem
you might have a blockage in your air gap or your garbage disposal line. check those areas first. do you hear the pump humming and not pushing any water through or do you hear is poushing the water through but just trickling through the garbage disposal? let me know
Jun 02, 2009 | Dishwashers
Not totally draining
Did you hook it up to the garburator, did you oppen the tab at garburator, is there a kink at the drain hose, Is the hose to high  or low or pinched. Is the orrifice to drain big enough , do you have a clogged drain. Vitally
May 13, 2009 | Dishwashers
Bosch 24 in. SHU43 Built-in Dishwasher Logo
280 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
