I put paper in drawer but it still says load paper
  • fletchercarr Feb 04, 2010
    I finally got it to work, Thank you so much.
  • 10,865 Answers
Hello. Open and close the drawer a little more forcefully. If that act does not clear up the issue the next step is to turn the printer off for two full minutes and then turn it back on. The two minutes off will reset the machine. Regards, Joe
Posted on Feb 04, 2010
Where do I load photo paper to print photos?
There are two drawers. For paper you put your fingers downwards and pull out the paper drawer. For photo paper the drawer is above it, so curl your fingers upwards in the same place and pull.
Based on my MG7120.
Jan 08, 2016 | Canon PIXMA MX922 Wireless All-in-One...
Sir in our office the canon ir2270 jam the papers. plz send me the steps which we handle this problem
Please follow these instructions every time you load paper and you will never have paper jamming problems.
Make sure that the paper drawer is properly in place. Do not load paper of an irregular size into the paper drawers. Do not load the following types of paper into the paper drawers. Doing so may cause a paper jam. - Severely curled or wrinkled paper - Thin straw paper - Transparencies - Paper which has been printed on using a thermal transfer printer (Do not print on the reverse side of this paper either.) Fan the stack of paper well before loading it. Never place paper or any other items in the empty part of the drawer next to the paper stack. Doing so may cause paper jams.
Also to clear paper jam if you have the manual with you follow it OR you can go to this link and download the manual. It is equally applicable ti ir2270
http://download.canon.it/manuali_operatore/files/iR4570_USR_ENG.pdf
Sep 13, 2011 | Office Equipment & Supplies
Problem with the Konica Minolta bizhub C450P Laser Printer Bizhub C450 error (C-0212) , HOW TO FIX IT?? PLEASE GIVE ME THE FIX STEP!! TKS!!!!!
This code is for LCT (Large Capacity Tray) lock release failure. This means there is a problem with the LCT, usually the large paper drawer at the bottom. This code is usually reset by opening then closing the front door. Sometimes turning off then on the main power switch on the right side will clear it. Try releasing the LCT and get it open. Then check the paper in the tray. Most of the time when there are problems with these LCT's it is because too much paper has been loaded or it has been loaded improperly. If you get it open, remove all paper. Then load smaller amounts of paper at a time to insure that it is loaded perfectly. Only load the tray half full at first and then close the drawer and allow it to lift. Then make a copy from that drawer to be sure it feeds paper. Then release the drawer again and finish loading if you want. If you continue to have the code then you can leave the drawer open an inch or so to de-activate it so you can still use the printer from the other drawers until you can get a technician out ot service it.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 16, 2011 | Konica Minolta bizhub C450P Laser Printer
I have an old Canon 1150 color copier. The bottom drawer #2 dropped and can't feed paper properly. So I put 11x17 paper in drawer #1 which had 8x10 paper originally. Now the panel still shows drawer #1...
Is there a paper selection wheel or bar in the tray?
Some of the older Canon models have a dial (usually in the lower right hand corner of the tray) or a slider bar (usually on the left hand side of the tray) when you open it. That has to be set properly or the machine has no idea what size paper is there.
Dec 03, 2009 | Canon CLC 1150 Color Copier
Get a load paper in drawer 2 error with the paper in the drawer
Hello sir; Please check the tray paper lifting motor seems it broke, otherwise check the paper sensor .
Aug 05, 2009 | Muratec MFX-2830 Black and White Copier
Copier doesn't recognize that paper is loaded
Hello sir; Make sure you close drawer tight then pay attention on listening the noise when you close the drawer, if quiet that's mean paper lifting motor defect, otherwise go to paper sensor.
Aug 05, 2009 | HP Office Equipment & Supplies
Tray error
Since tray 2 works, I'd guess that each drawer has a "paper sensor" that sees that paper is in the drawer. You might pull both drawers all the way out, with a flashlight, if needed, look at the area inside of each where paper is fed and you can compare #2 with #1, since you know 2 is good. You may find a sensor out of place. If it's not something simple like it popped out of place, then you may need to put in a new sensor. Good luck, please rate this if it helped.
Jul 03, 2009 | Savin Office Equipment & Supplies
Paper set
Take out the paper drawer in the upper portion left of the feed roll should be a black switch, this gets knocked off alot due to not locking down the paper in the drawer when loading. If the switch mounts arent broken you can try to put it back in position, or do what I do to save time and $$, just tape the switch "open"and tuck up above cassette cavity.
-Carl, please let me know if this helps.
Jun 26, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I am unable to print photographs on my D7260 HP Photosmart Printer bacause the blank photo papers are not being drawn into the machine
Have you loaded them face down? I have a 7360 and they are pretty fussy about what they will take and what they won't and how. The paper must be put in the upper drawer (if it is 6x4 paper), with the glossy side down and the drawer must be pushed right in.
Jun 12, 2009 | HP Photosmart D7260 Printer
Letter Drawer 1 on Model IR5020
look behind tray for paper preventing the feed rollers from knowing there is paper there
Feb 18, 2009 | Canon imageRUNNER 5020 Copier
14 people viewed this question
jasbo
jasbo
