Question about Asrock K7S41 Motherboard
My graphics are not working properly and i keep gtting black squares and it keeps getting lines on the screen how do i fix it
  • 316 Answers
Hello my friend this is looks like a graphic cards problem but we are going to check few things before change it.First you need to do is to turn off hardware acceleration-
  1. Click on Start > Control Panel.
  2. In the classic view, double click on the Display icon.
  3. Select the Settings tab and click on the Advanced button. The Advanced Settings dialog box appears.
  4. Click on the Troubleshoot tab.
  5. You can disable the hardware acceleration completely by dragging the slider to the extreme left of the scale. You can also choose to turn down the hardware acceleration by selecting an intermediate value.
If the issue is resolved with hardware acceleration turned off, the source of the problem could be old video drivers for your video adapter that you had.So we are going to the next step.
Uninstall all the graphic drivers and install the latest one,if you still have problem then you have to change your graphic card
Posted on Feb 04, 2010
Screen size and resolution keeps changing while I work.
some tv devices are set by default to auto adjusting, look in tv's setup and adjust the resolution manually.
Feb 23, 2013 | Toshiba Computers & Internet
COLORED LINES RUN THROUGH MY SCREEN
You didn't supply the Make , Model of laptop or the OS you are using? So the only solution I can suggest is a generic one. Open Device Manager,Display Adapter, Uninstall the Graphics Adapter, reboot. Allow your version of windows to apply the generic driver. Post results. Are the fan and vents clean? Is the Laptop getting proper air flow? You may have to open the machine to clean and replace Thermal Paste on CPU and Graphics Adapter.
Jan 26, 2013 | Computers & Internet
I have an HP pavilion dv9540us laptop that is having screen issues. I can only get the screen to work randomly...and then only for a few minutes. If i restart the computer it goes completly black or has...
See if the problem is there when you boot into safe mode. (Keep tapping the F8 key while booting). If you get your screen is working ok then it is software/driver related. By the sound of it , it is a graphics card problem. The graphics are integrated on this model so it means a new motherboard or sending it to a specialist repairer. Srri.
May 09, 2011 | Computers & Internet
Torpedo kerosene heater shuts off after 15 seconds, have to push reset and it starts again, what's the problem?
Does it light? If it does it could be the electric eye that sees the flame and keeps the unit running. It is either dirty or bad. remove the eye and clean it. It pulls straight out and has two prongs on it. Does not matter how it goes back in. It is just a switch. Replace and try again. If it still does not light replace the eye.
If you cleaned the eye and or replaced it and it still does not work there are a few more things to check...
  • Not gtting enough fuel. Check the filter. Usually a small in line filter.
  • It also could be the transformer is getting weak. The transformer produces 10,000 volts between the two electrodes that keeps the heater running. I would only change the transformer if everything else checks out.
  • The electrodes may also need adjusted.
  • The nozzle also may not be atomizing the fuel properly to keep the unit running. I recommend changing it at least once a year depending on the use.
There are some good video on YouTube that will give you some great troubleshooting ideas.
Feb 21, 2011 | Heating & Cooling
Xbox keeps freezing and shows red and black squares on the screen
hi , i think you might find that the graphics chip has had it , i`ve had 2 that have done this and the xclamp fix does not work or did not for mine anyway .
Feb 14, 2011 | Microsoft Xbox 360 Console
Program installing??
just keep the cd and click on the install xp or else keep the cd and start the system u will be gtting press any key on the screen after that partition the disk into four or five parts accordinng to ur wish and after that keep the bar on the c or the drive were u want to install then press enter then xp will installed on the hard disk then after that install the drivers....installation will be completed
Oct 28, 2010 | Microsoft Windows XP Professional
My Screen keeps getting lines on the screen on my
Video card is bad!
Buy a new one and follow these instructions to change it.
http://support.euro.dell.com/support/edocs/systems/ins5160/en/SM/palmrest.htm#wp1084976
Mar 02, 2010 | Dell Inspiron 5160 32MB DDR AGP Graphic...
Vertical lines/black squares all throughout this 50" TV. Is it worth fixing?
I have 5 vertical black bars coming down halfway on the screen. Also 1 black square that appears on the lower half corner of the screen. What can I do to get them off? Please respond or call me @(510)938-6237 Shon Thanx!!!
Dec 27, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Screen problem
That's the text box function of the closed caption decoder. Look for buttons with "CAP", "TEXT","CCD", or "CLOSED CAPTION". Look in menu for same.
Nov 11, 2008 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
May 24, 2008 | Insignia IS-LCDTV32 32 in. Television
Asrock K7S41 Motherboard Logo
69 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
