Question about Maytag EPIC MFW9700S Front Load Washer
My Maytag epic z leaks water from the bottom of the machine, not sure where its coming from.
  • 5,911 Answers
If your front load washer is leaking, the following link explains how to access the interior cabinet and what to look for:
http://www.fixya.com/support/r3576656-washer_leak__front_loader
In the majority of cases, leaks on front loaders are caused by a worn or loose door bellow. This is the gray rubber seal around the door opening. If the bellow has any rips or tears it must be replaced. The following link explains how to replace one (if required):
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacment parts (if required) can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
These sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites on the list also offer helpful exploded view parts diagrams to assist you with properly identifying and locating parts.
Read through the link provided and inspect the washer cabinet thoroughly. It may help to add some water to the drum.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: Overloading the washer can cause premature wear on the door bellow. In addition, using the wrong type of detergent (i.e., other than HE), or using the wrong concentration of soap can cause premature wear to the pump seals.
Posted on Feb 04, 2010
My maytag epic z is leaking from underneath
Remove the front bottom panel. Should be three 1/4" screws on bottom lip of panel. See if you can tell where leak originated. Chances are good you just need to pop the cap off the drain pump and clean it out. Here is a vid that explains the procedure.
http://www.youtube.com/watch?v=iLftnaruKp8
Jan 21, 2013 | Maytag EPIC MFW9700S Front Load Washer
My Epic Z front load is leaking water . It looks like the gray rubber on the door is the cause. The machine is only 18 months old
In the front on the bottom of the gray seal is two drain holes, make sure there is not an obstruction in these drain holes such as a small sock .
May 21, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Water Leak from the Front Door of our Maytag Epic MFW9700S
The water leaking is most likely the gasket. It may have a little rip or something making it not seal. Im not sure about Maytag but on our GE we had to slide the the top back to remove some screws then (I believe to was for the control panel) Then we removed screws for the door and the front of the washer. When that was done you have to remove a round clamp that holds the gasket on. Then replace the gasket.
My suggestion is to have a appliance repair come and do it. Its a pain to do, at least it was for me.
Jan 28, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Oct 03, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
3,679 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
