Question about Buffalo Technology 250GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD 250 GB Hard Drive
Buffalo external hard drive not recognised on PC. It came up as found hardware, then a message saying it might not work properly then nothing. Tried again and it did not come up at all
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
  • yeshey needup
    yeshey needup Feb 09, 2014
    it does make a connection sound .. but it does not appear on my computer. plz help
Buffalo external hard drive not recognised on car sterio
i think you cars stereo firmware is not capable check whether other external hard drive it is recognising
Feb 05, 2013 | Buffalo Technology 1TB DriveStation...
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
External Buffalo Hard Disk 500 Gb model no HD-PF500U2/BK-AP not detecting when connnected to a laptop or a desktop PC
Check the usb port function in the computer bios settings and be sure that it is set to yes. Connect properly your external drive. If it has two wire usb connections, use both to obtain the maximum power that will be need by your drive.
Dec 18, 2009 | Buffalo Technology 500GB DRIVESTATION...
No access at all but power light is on
Using the work PC did you see the information bubble informing you that windows found new hardware?
If so, the problem is likely just a logical issue(damage to the information on the drive), if not then the buffalo enclosure may have failed.
Either way, please reply back with this information and I will be happy to give you the appropriate next steps.
Chris
May 25, 2009 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Hi i got a buffalo tb external hardrive and the pc wont recognise it now after i transfered alot of data when the pc froze and i had to turn pc off mid transfer . please can you help
It is probable that since the transfer did not complete, the data on the external drive will be corrupt.
Uninstall the external drive then reinstall and format the ext drive.
You should then be able to begin the data transfer process again.
It just sounds like bad luck that your pc froze mid transfer.
When you try again, do not use the pc for any other uses until the transfer has completed.
Regards and let me know if this works for you.
Feb 24, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Connecting external hard disk to my pc
hello,
when you connect your wd hard disk to your system it says a new hardware found and plz upload a driver for this. an another hand your pen drive will accepted.
if you make the external harddisk partition in a another pc. then it possible that is not show the patation of your external hdd partation. or it possible that is show the drive letter but nothing to open in the drive.
i suggest you to plug the hard disk with system and boot the pc. after booting process nothing shows then you download a proper driver form site. and upload to your system. if nothing then happen you partation it again. it sove your problem.
thanks
ramesh
Nov 07, 2008 | Western Digital (WD3200JS) 320 GB Hard...
Toshiba Hard Drive Crash
if the datas aleady deleted, then you have nothing to lose. Right ?
What you need is a 2.5 to 3.5 inch IDE ribbon cable connector.
this will enable you to put the drive into an IDE slot on the PC internal motherboard ( primary/secondary )
Unless it,s already 3.5"
boot the computer, see if it recognises the drive. And format it.
then you may be able, to re-fit back into the external casing, and use as an external again.
Mike @ compurepair.
Feb 25, 2008 | Toshiba 120GB USB 2.0 Portable External...
Buffalo Technology 250GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD 250 GB Hard Drive Logo
1,456 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
