Question about Nintendo Wii Console
I keep getting...error code 52130...cannot make a connection..i use an apple extreme base station...it has connected in the past
    Genius:
  • 1,234 Answers
Error Code: 52130 There appears to be an issue with your wireless router's firewall.
  1. Make sure your router is not listed on our "known incompatible routers" page, by clicking here.
  2. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
    4. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
  3. Disabling your router's wireless security may help the Wii console's online connection. Consult your wireless router's manual or check with the router manufacturer for more details. Please note Nintendo provides these recom mendations as a resource to our consumers; it is up to each consumer to determine if adjusting their router's security settings are the right choice for their home network.
  4. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restrarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
Posted on Aug 27, 2010
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Trying to connect acer netbook to wildblue internet using apple airport extreme. keeps reading "limited connectivity."
"limited connectivity" normally comes up when u type in wrong wireless network key. check the correct wireless password
Dec 27, 2009 | Apple AirPort Extreme Base Station...
Epson CX4700 printer/scanner won't connect to my apple network
maybe the twin setting chick to twin settings
go to start and you can find the twin setting try it
Jul 06, 2009 | Epson Stylus CX4700 All-In-One InkJet...
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
Airport Extreme Bases Station not detectable with utility
This depends... Reaching them wirelessly may be unreliable for a number of reasons, so, I'll proceed on the assumption that you are attempting to test in the simplest lowest-variable situation:
First, make sure that you have the latest Airport Utility for your Mac.
Connect your Mac to the Airport via a single Category 5 (or 5e or 6) cable. Factory-reset the Airpot and then wake up the Mac. If the utility still can't discover your airport, it's probably time for a trip to your local Genius bar as you most likely have a hardware problem.
Lather, rinse, repeat for each of the two airports.
Apr 28, 2009 | Apple AirPort Extreme Base Station...
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Apple extreme bridged to apple extreme (Windows network)
OK, do you have the latest version of Apple's Airport Utility: Version 5.4.1 (541.9) ?
If you don't, get it... it's got an excellent interface that will walk you through bridging two wireless routers together.
Once you get your hands on it, you will need to choose which airport will be the primary and which will be the secondary. Ideally, pick the one connected to the highest speed and most reliable internet access.
Connect to the secondary airport and configure it as bridge to the primary, the Airport Utility will walk you through it step by step.
Jan 13, 2009 | Apple AirPort Extreme Base Station...
Need to find the network key
Open up your airport utility software.
Connect to the base station.
Under the main menus look for network equivalent password.
Nov 28, 2008 | Apple AirPort Extreme Base Station
Toshiba laptop to airport extreme cannot get connection
how old is the toshiba laptop? It might not be able to use WPA2.
Sep 10, 2008 | Apple AirPort Extreme Router
Apple error 9672
Are you still interested in discovering the solution to the problem of airport extreme base stations producing an "error 9672" when connecting to printers that have successfully connected in the past? If so you might be interested my platinum uber premium plan with a 30 day trial and money back guarantee. Click NEXT for more details....
Jul 08, 2008 | Televison & Video
Nintendo Wii Console Logo
115 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
phil
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
