How do you remove the housing on a maytag neptune electric dryer, i took all the screw from back and bottom , is there something i am missing Greg
    President:
  • 2,468 Answers
There are two screws near the toe kick panel on the front cover,remove these,then lift up front cover like a car hood there are two spring clips located between the top of front cover and top cover of machine after these release then look just inside bottom side of top cover for screws holding top cover on,remove these and lift up on cover it will hinge up and back again like a car hood,secure the top so it can't fall and break wires to the controls,then remove belt off drum idler and this will relieve tension on drum belt and you can now remove drum
Posted on Feb 04, 2010
Maytag neptune dryer makes loud noise on the right side when top dryer is on
The belt tensioner bushing could be shot or there may be a piece missing from the belt. Did you check the back for a removable observation cover?
Jan 05, 2014 | Maytag Neptune MCE8000AY Electric Dryer
I have a Maytag Neptune dryer, Were do i find the element.
In the back, Remove the back panel and you will see on the right a long rectangular metal housing around it it's testable from the bottom connection where the wires hook on, you will have to disconnect the wires if your checking continuity.
May 16, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Screw holding in paddles are backing out.
remove cord and unscrew back panel. You should be able to reach all paddles by turning each 1 to bottom area and tightening.
May 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How to remove the front panel of a maytag neptune gas dryer
Removal of the front panel requires the removal of the top cover and the console. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the 2 screws attaching the top cover to the rear of the dryer then slide it rearward to clear the screw head from the top cover flange and lift the cover off the dryer cabinet.
Remove the screws securing the heater PCB board and disconnect the black and white wiring harness connectors from the board.
Remove the four screws attaching the console to the washer cabinet and rotate the console down to remove it from the dryer.
Remove the four screws attaching the top of the front panel to the cabinet and the two screws at the bottom of the door opening.
Pull the front panel forward and disconnect the interior light wiring harness then lift the front panel off the tabs across the bottom and move it away from the dryer.
Reinstall the front panel, the console, and the top cover in reverse of the removal steps.
Apr 21, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Electric Maytag Neptune Dryer - rattling noise
Your probably going to have to remove the rear panel and take a look to see what is causing the noise.
Disconnect the power cord and exhaust tube, remove the rear panel and check for anything loose.
You can also pop the lid and fold it back to inspect the top of the tub and belt. Roll the drum all the way around and inspect the belt for "chunks" missing.
If you include your model number, I can send you a web site that will show you an exploded view of the dryer.
Regards,
Aug 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The upper cabinet of the Maytag MCE8000AY Electric Dryer heats up, but the air isn't blowing out the vent. I can't find a filter to check or where the top cabinets vents to the outside vent. Anyone help??
You must remove the screws from the door and the hinges there are 8 screws 2on the top hinge 2 on the bottom and the other side also.After that the door lefts up and toward you.Once the door is off the panel around the door should come off then there is a shroud infront off drum remove 4 5/16 screws off then then cheak for lint obstruction or piece of clothing around the blower housing.Hope i helped:)
May 18, 2009 | Maytag Neptune MCE8000AY Electric Dryer
How do I remove the lint housing of Maytag Neptune dryer
Hi Kate,
Gaining access to the lint housing sounds more difficult than it is. As a matter of fact, I could get to it and have it back together in the time it takes me to type out the instructions!
Tools needed;
1.) Phillips screwdriver
2.) 5/16" nut driver or socket
UNPLUG THE DRYER FIRST!!! Or risk a funky new hair-do...
Open the door and remove the four screws at the hinges then remove the door. Opposite the hinges, you'll see 4 more screws, remove these too. Now grasp the front panel on both sides near the top and pull it toward you. Lean it out to about a 45 degree angle and lift it off the clips that are holding it (at the bottom).
Now you'll see the lint trap housing. Look around the housing, you'll probably see a yellow wire near the 5 o'clock position, remove it. Now, on either side, you'll see four 5/16" screws... Don't remove the top ones, just remove the three below the top ones. You can now pull the entire panel off of the frame for cleaning.
Rebuild in the reverse order (and don't forget to re-connect that yellow wire!)
There ya go! Please don't forget to rate this as "FixYa", OK
SG
Apr 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Gaining access to dryer
open door you see 2 screws holding hinge a a piece,,remove them now remove the 2 screws opposite them ..just let door stay for now...pull the front panel to you its just on 2 clips...now at each corner of the bottom of the top theres a upside down l shaped clip remove 5/16 inche nut driver...ok left the top...swing it up and back ,,so it will lean back,...remove 4 bulk head screw and the door switch connection..and your there..onthejob
Jan 28, 2009 | Maytag Neptune MDE7500AY Electric Dryer
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
How to remove a back panel of maytag neptune dryer?
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
Apr 15, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
