Question about Acer AV009 Computer Speakers
Speaker Output My Acer computer speakers are distorting voices, the output sounds like its playing at the wrong speed, voices are very high pitch...can you help...
  • 4 Answers
Hi this is vijay , it is not ur speaker prob , it is ur music player prob, plz use k-lite codek pack 3.0. and i hope it will slove ur prob.
thanks
Posted on Mar 17, 2008
When I turn volume high it breaks up? Jbl flip Bluetooth speaker
Unfortunately it sounds like one of two things, both rude... one, the amplifier attached to the speaker exceeds the output capacity of the speaker "cone", or alternatively, the amplifier distorts the output signal when near its peak amplitude... Either way, buy quality gear and you wont have this issue. Real and true, you do get what you pay for... mostly...
May 21, 2014 | Audio Players & Recorders
Output distortion from bass amp
The amp is clipping the signal. This could be from the input being too high. The impedance being too low or the finals are damaged.
Dec 11, 2017 | Behringer BXL1800 180W 2-Ch Bass Amp 12In...
Gt5 12 inch 275 watts how many watts of amp best?
Depends on what output your stereo is. If you underrate the speakers (speaker watts is less than stereo output), the unit will sound louder for a while, then you end up blowing your speakers with the excess distortion. If you overrate the speakers (speaker watts is higher than stereo output) the speaker will not operate correctly and the distortion can damage it also. Its best to get a close match. Slightly higher is better. It is important you know actual wattage output not PMPO ( Peak music power output) A lot of stereos are rated at PMPO. The higher number sounds great but in reality, the figure is the MAX output and by then the sound is distorting badly. Distortion ruins more speakers than anything else...
Oct 11, 2013 | JBL GT4-10 Car Subwoofer
I can only hear the person I am talking to through headphones, I want to hear them on my speaker
To solve this problem ,do this; goto start menu >control panel>sound and audio devices
in volume tab under speaker settings , click on "advanced" in speakers tab speaker setup:select desktop stereo speakers
click performance tab Hardware acceleration =full sample rate conversation quality=best. click on apply,and ok
select audio tab in sound and audio output. click on volume ,unmute all . increase all volume to high. close it.
select voice tab in click on volume ,unmute all . increase all volume to high. close it.
click on apply and ok.
then open your audio manager .increase play back volume and unmute all .
important :select default device (sound play back) .to your audio manager's default device . after apply all settings .click ok and close it. in sound and audio output. tick on "use only default devices". . do it and solve it
Sep 08, 2010 | Skype IM
Internal wiring schematic for a JBL 4311 WX-A
the conductor xxx\blk is the minus or black( from speaker) the outher is positive\red pin from speaker) the woofer is bigest speaker inside is connected on the crossover at low output, tweeter at high output, if you connect wrong you can burn speakers and crossover, you can test with very low volume on amplifier.
1st connect low to woofer, it only her low freq below 500Hz like drums and bass, if connect on med out the speaker is working as handpocket old radio audio. if connect on high the speaker is like no audio out. (the woofer take about 60-75% of amp power).
2nd connect the midrange at mid output you can listen to human voice cristal clear. if connect on high output you listem like esteric female shouting.
And connect the tweeter at the empty output
Take particular attention on polarity terminals, if you exchange the polarity you have a moofle sound traped inside of speaker, and some structered box noise who may open the box panels in future.
Feb 16, 2010 | Audio Players & Recorders
Quad 11L One of my speakers seems to distort the sound for a minute or two on switching on the system and then starts functioning normally again. I have a feeling that my toddler may have twiddled the...
First, swap the speakers to see if it stays with the speaker or the amp channel.
Second, disregard the throretical ability of any speaker to handle any amplifier's maximum output. Amp ratings are at a certain power output with a certain amount of distortion. Turn the volume a click higher and power output might rise just a tad but distortion starts to go ballistic. Continue and you get total high current garbage. Clipping (high DC output) will kill any speaker.
Since it seems to go away, I doubt the speaker is damaged, unless torn speaker cone or burnt voice coil can self-repair in a few minutes every time.
Feb 09, 2010 | Quad 11L Main / Stereo Speaker
Acer ax1700-u3793 doesn't display an hdmi sound output option
try to check if the audio cable(jack) is properly connected to your device or speaker
Aug 30, 2009 | Acer Aspire AX1700-U3793A PC Desktop
Distorted and low volume voices - Mr French
hi, first u will have to determine if the center output is bad or the cntr speaker is bad, to do so do not disable the center, simply remove the speaker wires and check if there is noise, if not means speaker is bad, if still noisy then output is bad,u will then need a technician to get the job done.. letr me know..
Jan 26, 2008 | Infinity CC-1 Center Speaker
Surround center speaker does not work
This is a 5.1 (6 Channel Technology) You should hear only the voice thro the center speaker. If the source you are playing is stereo, however the software splits the source its difficult to seprate the voice track, if the source is a DTS 5.1, then you should hear the voice only thro the center speaker. eg: when you play a DVD movie which is DTS 5.1 then you should hear only the voice track in the center speaker, if the dvd movie is just stereo then you will not hear any audio in the center speaker, while the other four speakers get output, this is the special effect in 5.1 ( 6 channel Output).
Dec 27, 2007 | Inland 58019 ThunderSound 5.1 PCI Sound...
Acer AV009 Computer Speakers Logo
132 people viewed this question
Top Acer Audio Players & Recorders Experts
Marvin
Marvin
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
