How do I install a second hand waher/dryer with limited piping?
I have a second hand Hoover Performa eco1200 washer dryer. there is an outlet pipe attached but no incoming water hoses. In addition the kitchen sink only has one connection to send water in. Question 1 Are hot & cold inlet pipes all standard, if not, what do I need?
Question 2. Can I buy a Y-piece to connect the appliance hot and cold pipes to a single sink outlet.
Question 3. Will I get both hot & cold water going through the Y-piece?
Question 4. As it is a flat should I assume the outlet pipe on the appliance will have to go into the sink to take any waste away?
    Sergeant:
  • 215 Answers
1 yes all standard.2 Yes you can get a Y piece. 3 no you will only use water from cold. But you can solve that by going to a good hardware store or B.Q and gettein a self cutting tap for washing machines. You can fit this in just minutes, and do not even need to turn off the water supply. just make sure there is a clean straight piece of pipe to fit it to. 4 yes fit waste pipe to u bend under sink.
Posted on Feb 08, 2010
Hi, i got a hotpoint ultima extra washer dryer, code WDM73, it does a wash but at the end of a cycle it wont drain the water, it says check the outlet pipe but theres nothing wrong with it, i dont have a...
try bottom front right hand side is a filter ,...undo ..water will come out so have some towels ready... clean and refit... bsc appliances 07779933829 spares and repairs.
Feb 27, 2011 | Hotpoint Washing Machines
Water coming from soap compartment. is there someway to clean the dryer fluff from machine
It sounds like the water outlet is blocked. Same happened to me.
Unplug machine from mains.
Remove panel located on the rear near the base of machine.
In the bottom right corner you will see the outlet pipe and the pump.
Remove grey outlet pipe to get better access.
Undo the large jubilee clip where the black pipe joins the drum outlet.
Inside this pipe is a white plastic cage filter.
Check to see if anything is blocking it.
Jan 07, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
My maytag performa washer continues to drain while filling, therefore never starting the rinse cycle. The drain pipe is in a loop position so I know it is not siphoning the water out and the washer seems...
how far does the drain pipe go into exit drain because this shoulh not pushed into pipe more than 6" and should have a air break and also the drain pipe should be above top of bowl line
Nov 19, 2009 | Maytag Performa PAV2200
Will wash but won't spin unless water syphoned off by draining through pipe into low bucket. So, the spin motor is ok, the pipe is not blocked... but the pump..... how can I get to clear out the pump?.......
Check to see if there is a filter located at the bottom front of washer behind plastic trim, if no filter, then remove rear panel of washer, and remove and check pump for blockage or malfunction.
Please rate my so9lution.
Thanks
Nov 01, 2009 | Washing Machines
I have a Hoover dishwasher D820 model,water is now leaking as soon as the machine is switched on. I have examined inlet pipe and renewed washer, no other cracks are in the outlet pipe. All connections are...
with hoover it should have a water pump prior to the start of the outlet pipe. Id remove this and check for blockage, as anything in there that wont allow the motor to turn will force the water out somewhere else once its under pressure.
Oct 07, 2009 | Dishwashers
User guide for hoover performa eco 1200
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=10
go to that website to get an online manual for any hoover machine. the performa eco is a WB120.
Mar 26, 2009 | Washing Machines
I am looking for the instruction manual for the hoover performa eco wb120 washer dryer as i cant seem to spin my washing which is stuck in the machine
My partner fixed this problem by taking the machine back out and found that the connection to the water outlet pipe under the sink had a buung left in so after it was removed my machine drained
Mar 22, 2009 | Hoover Washing Machines
Water Accumulating in Washing Machine Drum
Could be draining from your sink outlet. Ensure the outlet pipe is routed higher than the sink trap. Normally attached underside of the work surface.
Mar 04, 2018 | Hoover Washing Machines
Washer dryer error code 'check outlet pipe'
the outer drum could have dropped ]it might be a shock gone or top spring] close ire bye
Oct 11, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
