Question about Intel Compaq Deskpro EN Pentium 3 1Ghz / 256MB SDRAM / 20GB HDD / CDROM / Integrated 10/100 LAN / NO OS / (RBDTCPQP31GW98) PC Desktop
Cannot boot or switch on - Intel Compaq Deskpro EN Pentium 3 1Ghz / 256MB SDRAM / 20GB HDD / CDROM / Integrated 10/100 LAN / NO OS / (RBDTCPQP31GW98) PC Desktop
I have compaq desktpro with the above spk but i need to install os xp from cd room after file copied to the system it dosnt work? who can helpe me?
Posted on Mar 19, 2011
  • 644 Answers
The power supply is faulty and needs to be replaced, undo the screws holding the top cover on, pull the cover up and away from the from the front, the power supply will be at the back on the right, there are four screws holding the power supply in place, they are at the back of the computer case, undo these and the power supply should come out, make a note of where the power connectors go before removing, take the power supply to your local pc store, as most power supplies are standered the compaq power supplies maybe slightly smaller in size, so your local store may have a replacement or you may have to order one straight from compaq. hope this helps. cheers.
Posted on Feb 04, 2010
What switches on the boot light
Mostly one side of the boot light is permanently live and the other side is earthed by a switch that operates when the boot lid is opened. The switch is sometimes in plain sight and sometimes it is operated by the hinge mechanism or might be buried in the boot lid catch itself and have a dual duty of telling the central locking and/or alarm brain the boot or tailgate is securely closed.
Sometimes a tilt switch is used and this will be found inside the boot lid.
Sometimes (rarely) there is no automatic switching and the light is supplied by the parking lights or tail lights and others must be manually switched on in the way of the cabin light.
Feb 20, 2016 | Cars & Trucks
I explained the boot on my jaguar s type 2001 the light on the dashboard says the boot is open but it is not.i am unable to set the alarm because the dashboard is saying boot is open,when I open the boot...
you may have a broken wire around the boot hinge. or a faulty boot latch switch, also check the switch on the boot lid.itself.also the plastic boot closing panel has not come adrift, has the boot switch will not operate if the panel is missing/adrift.
Mar 01, 2015 | Jaguar Cars & Trucks
My boot wont open but the boot light stays on and on the dashboard says boot is open but the boot wont open
There should be a switch that opens and turns the dash light off when the boot is closed. find and adjust the switch.
Nov 13, 2014 | Cars & Trucks
My i30 boot open warning light staying on when boot is closed
Check the switch position. See if the light goes out if you manually depress the switch. If it does, raise the switch
Sep 13, 2014 | Cars & Trucks
L can't boot xp from my cd rom in nec versa 680
need to change the boot seq in BIOS....
u need to press one of the foll...
DEL, F1, Esc, key etc as the case may be...immediatly after switching on the PC....
once u r in BIOS screen look for "Boot Seq" in one of the BIOS setup screens....
change the boot seq to CD ROM as 1st boot device...and HDD to 2nd boot device...
press F10 or choose BIOS "save and exit " option....
insert the XP cd...switch off and switch on...it should now boot from CD....
all the best....pls revert back...pls give a rating and feedback for this advice....thanks
Sep 27, 2010 | NEC Versa FX Notebook
Jag 1997 x300 and the boot switch not working
the boot switch works off the earth(power return to batt)check that the wires around the boot lid havent rub through and are causing it to earth.
Apr 07, 2010 | 1997 Jaguar XJ6
Recover Password
there are two ways ..try them
first :
In order to set a new password do the following:
Make sure you have a console connection to the Foundry device.
Reset the device using the reset button in front or remove and then reinsert the power cable.
Immediately enter b to go to the boot monitor mode at the time of boot up.
Enter no password in boot monitor mode.
Enter boot system flash primary (or secondary).
At the prompt enter the following commands:
FastIron>enable
FastIron# configure terminal
FastIron(config)# enable super-user-password test
FastIron(config)# write memory
Your new password is now "test".
second... only try if first doesnt work
Set the switch to its default configuration. Make a direct connection to the switch’s console port and power cycle the switch. Immediately after powering on, press <Ctrl><u> to access the system file menu. ]Select <D> to delete all user-defined configuration files. Press <Q> to boot the switch.
hope this solves your problem
Aug 08, 2009 | Foundry Networks Foundry EdgeIron 2402CF...
Rocker switch boot deteriorated
Contact us at www.arrowmotor.net , we sell the part.
Jun 10, 2009 | Dolphin Maytronics Advantage
Hi, I have done a reload on my Cisco 3560 switch byy giving these commands. write ersae reload Ever since i have done this i am getting only switch: on my switch. Its not working. kindly help me out. When...
This means that switch is in boot mode, In order to boot it use "dir flash:" and see if you can find a valid image in it. if it is there, use "boot flash:<image name>" to boot up the switch. in case there is no image we need to do an xmodem to recover the switch, we need to have a console cable connected in the console port and an image for 3560 on your system, Issue the command " copy xmodem:<image name> flash:<image name> " after this go to transfer file in the menu of hyperterminal and choose " send a file " browse the file and select protocol as "xmodem" this will take around 4 hours to copy and then you just need to enter " boot" and switch will be up.
Regards,
Harshit
Nov 12, 2008 | Cisco Catalyst 3560-24PS Switch
Intel Compaq Deskpro EN Pentium 3 1Ghz / 256MB SDRAM / 20GB HDD / CDROM / Integrated 10/100 LAN / NO OS / (RBDTCPQP31GW98) PC Desktop Logo
88 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
