Question about Kitchen Appliances - Others
Toaster needs new heat coil
My toaster (a model from the seventies) needs a new heating coil. I went to a local small appliance repair and was told the toaster was not repairable b/c Toastmaster does not supply parts. Any alternatives?
  • 863 Answers
Find a comparable model at flea shops, yard sales, or e-bay and take the parts off and install them on yours.
Posted on Feb 04, 2010
Broiler heat element
It probably is the broiler heat element that is defective. Small appliances are generally not worth repairing due to the high cost of parts plus shipping and handling charges. You are much better off buying a new toaster oven broiler.
Aug 11, 2015 | Applica Black & Decker TO1675B 6 Slice...
I need top heating element
to be honest cost more usually to fix than buy a new one but your local appliance repair shop is best bet
Jan 17, 2015 | GE Ovens
Top filament has burned out; does it pay to repair toaster oven or shouldit be replaced by a newer model??? We rarely use the oven and mostly use the appliance for toast. A replacement would cost less...
Chances are very slim your toaster oven is repairable anyway if the heating element burns out. A replacement part is not available, and there's no way to reliably repair a break. Even if it could be fixed, the low replacement cost makes it uneconomical. Parts and labor would run close to $50, maybe even exceed that price.
Unless you can find a part and do the repair yourself, small appliances today are throw-away items.
Jun 20, 2011 | Black & Decker TRO400 Toast-R-Oven Toaster...
I had the " dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 07, 2011 | Roper RGX4634KQ Gas Dryer
Broken ceramic tube that contains the heater coil in my toaster
take it in to an appliance repairs shop and have it fixed proeprly
Mar 07, 2017 | Cuisinart CPT-50 Heat Surround Toaster
Doesn't get hot, runs fine no heat
It is possible that the heating element has burnt out or a high limit switch (safety device to prevent overheating) has gone out. Element is located at the bottom of the dryer on the oppisite side of the exhaust. Looks like a toaster coil. Any break in the coil and no heat. New elemenrts can be purchased at an appliance parts house with the serial and model numbers for your unit to ensure correct part.
Dave
Jan 13, 2010 | Bosch Axxis WTA4400 Dryers
Unit is not heating but fuse is good
Heating element inside of unit has overheated and is possibly burnt out. This isn't an easy fix for a novice due to the location of the heating coils located behind the a/c evaporator coil. The coil looks just like the coils in a toaster and can be seen if you pull the unit out of the casing. The part can be purchased at any appliance parts house if you take the model and serial number with you. Good Luck on your repairs
Dave
Oct 13, 2009 | Fedders AEY12F7F Wall/Window Air...
Sunbeam toaster oven upper heating coil not working
the part (element) cannot be bought , its connectors are welded into place ........ if you realy love your oven , you can get one by shopping in a goodwill store for a used oven and cut the element out and cut and weld the element into your oven ........ this does work ,i have done it
Feb 25, 2009 | Sunbeam 6198 Toaster Oven with Convection...
Lower Heating element will not turn on
take notice of the local repairers
if they say parts are hard to come by , a DIY will have even more trouble
junk it and get a new one
Nov 24, 2017 | DeLonghi EO1258 - Stainless Steel Toaster...
Kitchen Appliances - Others Logo
843 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
