Printmaster gold 16 installation problem
I had a computer crash and needed to reinstall the OS. I upgraded to windows 7. Everything seemed OK when installing my print mater 16 gold, except I got a message ''amyuni Document converter 2.10 kernel mode print driver'' is not compatable and to contact the manufacturer. I can't seem top find a link at borderbund that addresses this issue. Is there an updated driver out there to addresss this? Please advise.
Try running it in compatibility mode.
Posted on Feb 07, 2010
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I cannot install PrintMaster Platinum 2011 on my Windows 7 computer. Is there a way to do it? It says it is compatible with windows 7.
Administrator privileges are required to properly install the program on Windows® XP, Windows Vista®, Windows® 7 and Mac OS X for PrintMaster Platinum 2011 .
Using mouse, right click on the "setup" and Run as "Administrator"
Hope it helps.
Apr 28, 2011 | Encore PrintMaster 17 Gold for PC
Can't install PrintMaster Platinum 16 on my Windows 7 PC
This version of print master is not compatible with windows 7.
see the compatibility criteria of Printmaster on the link given below!
http://www.microsoft.com/Windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=PrintMaster%20Platinum&v=Encore&uid=18&l=en&pf=0&pi=9&c=Graphics%20%26%20Printing&sc=Image%20Editing&os=64-bit
You can try if this works in compatibility mode in your pc - Try running in compatibility mode. Right click the program icon, click Troubleshoot Compatibility, wait while the problem is detected. Click Troubleshoot program > select an appropriate version of Windows the program is known to run in, try Windows Vista SP2 > start the program to see if it runs. If it runs, click next to proceed with saving the settings for it.
Mar 19, 2011 | Encore PrintMaster 17 Gold for PC
How do you make Printmaster Platinum 16 work with windows vista
Printmaster Platinum 16 is not compatible with Vista or windows 7. You can try to use Vista compatibility mode to run older programs in Vista. There is not guarantee that it will work!!! Please take note:- **The installation of an older program to run in a newer OS may also crash your PC too.
Link to How to "Use windows vista compatibility mode" - Use at your own risk!
Good luck
Dec 20, 2010 | Broderbund PrintMaster Platinum 16
I cant get printmaster gold to work on my computer. i have windows vista
Broderbund PrintMaster Gold 16.0 is not compatible with Vista.
Platform: Windows 98 / 2000 / Me / XP
Good luck.
Dec 07, 2010 | Broderbund PrintMaster Platinum 16
Can I install my software in windows 7
before you can install the windows 7 operating system, download first the windows advisor software that allows you the check your computer if the components of your system is capable for having a windows 7 operating system, it also checks your computer if you have incompatible programs and applications if your thinking of an upgrade from windows vista to windows 7.
if your planning to do an upgrade check the version of your vista OS to see the compatible version of windows 7.
i hope this helps
Feb 25, 2010 | Broderbund PrintMaster Platinum 16
I am running windows 7 , however I cannot get my print master gold 11 to run with this operating system . It seems to have something to do with the 64 bit
Check out whether you are running 32 or 64 bits.If you are running Windows at 64 bits, you may not have enough memory to actually manage it. 4 gigs of RAM is the norm for 64 bit installations. This is more likely if you upgraded and didn't buy your computer with 7 preloaded, but you should have gotten a caution message during installation if that was the case.
Go to start, computer, and then system properties. Then look at whether you are running X64 edition. If you are running x64 and don't have enough memory or a fast enough chip, that can create problems. That usually takes the form of crashes during games and other graphic intensive programs. If that is the case, you might have to change your Windows installation.
Make sure that you go to Microsoft update advisor and Broderbund's printmaster updates to make sure you have the latest drivers. Usually, if you go to help in the program menu there is a way to update automatically. It may be under about or something like that. Printmaster was designed to work at 32 bits, but most programs will run on 64.
Hope this helps, leave comments if you have more questions.
Dec 19, 2009 | Broderbund PrintMaster Gold 11 for PC
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
