Question about ASUS P5LD2-VM Motherboard
Please can you give steps to disable the onboard usb controllers to use the CPI USB Card. I've installed the PCI Card after the onboard stop working
    Genius:
  • 1,011 Answers
2.4.2 USB Configuration
The items in this menu allows you to change the USB-related features.
Select an item then press <Enter> to display the configuration options
USB Function [Enabled]
Allows you to enable or disable the USB function.
Configuration options: [Disabled] [Enabled]
Legacy USB Support [Auto]
Allows you to enable or disable support for USB devices on legacy
operating systems (OS). Setting to Auto allows the system to detect the
presence of USB devices at startup. If detected, the USB controller legacy
mode is enabled. If no USB device is detected, the legacy USB support is
disabled. Configuration options: [Disabled] [Enabled] [Auto]
USB 2.0 Controller [Enabled]
Allows you to enable or disable the USB 2.0 controller.
USB 2.0 Controller Mode [HiSpeed]
Allows you to configure the USB 2.0 controller in HiSpeed (480 Mbps) or
Full Speed (12 Mbps). Configuration options: [HiSpeed] [Full Speed]
BIOS EHCI Hand-off [Disabled]
Allows you to enable support for operating systems without an EHCI
hand-off feature. Configuration options: [Enabled] [Disabled]
NOTE!!!
Do not disable the BIOS EHCI Hand-Off option if you are running a
Windows® operating system with USB device
hope above given details with give you a detailed description as you desired.
good luck
Posted on Feb 04, 2010
  • 4,281 Answers
When you power up the computer press F1` or F2 or "del" key to enter in bios setup .
Then go to advanced configuration and disable usb controller.
Then save settings and exit from bios then onboard usb disabled
Let me know if you need further assistance.
Thanks for using FixYa.
My pc is not detecting the pendrive
CHECK WHETHER ONBOARD USB PORTS OR ENBLED OR DISABLED IN CMOS SETUP.IF ENABLED PORTAS SHOULD WORK WITH WIN XP SERVICE PACK2. OTHERWISE PURCHASE AND INSTALL PCI USB CARD 2.0.
Mar 05, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pc gets hang after connecting pendrive to pci usb card 2.0
Update the PCI USB card driver. This may fix the problem.
Mar 01, 2010 | Computers & Internet
I have a dell precision 340(400fsb) and have just bought a link it pci usb card to upgrade my usb hubbs to 2.0.The pci card has the gold teeth divided into 3 sections,but the bank for it has only 2.It fits...
Some USB add-on cards do have 3 sets of "teeth", i don't know why. As long as you remember to tighten it down by screwing it in at the expansion slot opening it should be fine. Also remember to disable your onboard 1.0 USB functionality in the bios before booting up and installing drivers for the new card.
Feb 19, 2010 | Dell Precision 340 PC Desktop
My usb ports dont work in my toshiba satellite A135-S2386
Unplug the PCMCIA card first.
Then disable the onboard USB hub and ports. Shutdown, plug in the PCMCIA card and reboot into Windows.
Let Windows detect the card and if necessary put in the driver CD for the card. Had similar issues with my desktop PCI USB card.
After disabling the Onboard though it works perfectly fine now.
Hope this might help you a lot.
Please rate me if i a m helpful.
Thank you.
Beboy
Aug 18, 2009 | Toshiba Satellite A135-S2386 Notebook
USB ports won't work after hard drive format
hi
well u can try installing an USB PCI card .You must also check the usb status through device manager.For more technical help you can visit at------http://robs-tech.blogspot.com/2009/06/get-technical-support-related-to.html
Jun 21, 2009 | Sony VAIO VGN-FS742/W Notebook
Gigabyte GA-6VTXE Motherboard cant detect any USB pluged It used to detect JUST SanDisks memory, now... not even that. All windows updates installed. In manufacturer site theres just a 4in1 driver set that...
The problem is probably not software, but hardware. The BIOS probably has disabled the USB controller, or the USB controller has probably gone out, the way to tell is when you restart the computer, when the screen first comes up, press the DEL key to access the CMOS setup utility. Check around for something that says "Onboard USB Controller" or "Onboard USB Support" and if it is disabled, enable it. otherwise the Motherboard has lost the controller and you either replace the board, or get a USB controller PCI addon card. Hope that helps.
Jun 16, 2009 | Intel Motherboard
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
USB ONBOARD NOT WORKING
Hello there.
It sounds like you do not have the additinal USB patch which you can download and install from here http://dlcdnet.asus.com/pub/ASUS/misc/utils/S3USB.zip
The article for the patch is here, which addresses the problem with USB failing to work.
Please run this fix and your USB should be working, if not then please get back to us and we can try additional steps.
Hope this helps.
Jun 28, 2008 | ASUS P4S8X-MX Motherboard
USB 2 PCI card installation on IBM NetVista with MS Vista
Lucy,
USB 2.0 cards require 2 IRQs.
  • 1 IRQ supports USB 1.1
  • and the other the Enhanced (USB 2.0) controller.
Installing the USB 2.0 card in a slot that does NOT share an IRQ or shares an IRQ with onboard USB produces the best result. Consult your motherboard manual or online guide to determine which PCI slot is best for you.
You should also try disabling the on board USB support from BIOS setup.
Thanks
Iqbal
Apr 28, 2008 | IBM NetVista A40 PC Desktop
USB port malfunction?
Oh God i have the same exact problem. I run XP Pro and USB ports all malfunctioned, after tyring EVERYTHING I reloaded windows and it worked.......for about 8 months, now I'm back to I can't use my printer, storage devices ANYTHING that plugs into the USB ports. I'm at my wits end. I'm thinking of throwing the compter out the window
Jan 12, 2008 | Computers & Internet
ASUS P5LD2-VM Motherboard Logo
2,060 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
