Question about Microwave Ovens
Power mosfet p/n 1M30D-060 for panasonic microwave mode NN-L530BF
Do you know where I can buy the part??? Or do you know a substitute part?? Thanks.
  • Anonymous Feb 23, 2008
    El horno, al conectarlo enciende normal pero al momento de ponerlo a trabajar solo trabaja por 5segundos y se vuelbe a apagr ¿cual sera el problema?gracioas
  • Anonymous May 23, 2008
    I have the same problem finding a 1M30D-060 power MOSFET. Has anybody found a US source for it? Partstore.com only has the entire HV Inverter board available. OUCH!
  • 2,334 Answers
Posted on Feb 21, 2008
My Panasonic NN-L530BF Microwave Oven comes on for about 5 seconds and the shuts itself off...I don't know if it is heating because the time is so short...help!
Hi this ONLY ever happens when you have had a catastrophic failure inside the MW, usually the power supply and or the magnetron. Most often they are NOT an economic fix and replacement is the cheapest and best option, should you still wish to try to repair take it to a professional repairer and only first ask for a "Quote" and go from there.
Oct 12, 2011 | Microwave Ovens
I have a Panasonci NN-SD686S and after a power cut last night, the microwave is now in demo mode. After power cuts previously this has never happened, and I can't find anything in my manual to...
To set Demonstration Mode: press micro power once, then press Stop/Cancel 4 times. To cancel Demonstration Mode press Micro power once, then press Stop/Cancel 4 times.
Sep 09, 2011 | Panasonic NN-C994S Convection/Microwave...
My Panason NN-C994S is on demo mode and I am unable to switch it back? Do you have instructions to convert back to cooking mode. Thank you
If you go to the Panasonic site you can download the manual.
www2.panasonic.com/consumer-electronics/.../model.NN-C994S
Regards
Alan Hood
ami-man
UK
Apr 05, 2010 | Panasonic NN-C994S Convection/Microwave...
Panasonic Microwave model # NN2505C stuck on Demo mode following power outage do not know how to return to normal function
The manual is not available on line so I do not know if this will work but try pressing FUNCTION-0-2.
Nov 01, 2009 | Panasonic NN-T655SF Microwave Oven
Hi, I have a NN-C784MF microwave oven from panasonic which is inverter based. The two diodes # ux-c2b are blown. I replaced them they blew again.Please help. Regards.. Anwar.
Chances are there are other bad parts blowing the diodes, most likely a MOSFET.
Also, the ESR of the electrolytic capacitors should be checked and all board connections must be checked and resoldered if suspect.
If you're not experienced in troubleshooting switched-mode power supplies (inverters) then you can probably save a lot of timer and money by replacing the whole inverter.
You can find the nearest spare parts supplier by selecting your country then the support links at Panasonic.net.
Dec 30, 2008 | Panasonic NN-SN657SMicrowave Oven
Panasonic NN-S262SF stops cooking after 3 seconds
inverter problem the transistor 1M30D is shorted
May 28, 2008 | Panasonic NN-S262SF Microwave Oven
Panasonic Inverter Microvave (NN-T990SA) Does Not Operate at Full Power
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 13, 2007 | Panasonic NN-T990SA Microwave Oven
The microwave does not work.
check control circuit and related control panel circuit
Jul 28, 2007 | Panasonic NN-T993SF Microwave Oven
Microwave Ovens Logo
1,477 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
