My player stuck on transferring music. i prassed reset button and since then when i connect it to pc it shows my player as "rom recovery"
I need the software
Posted on Feb 04, 2010
MP3 files will not transfer to my SA6045/02
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Nov 17, 2008 | Philips GOGEAR SA6045 MP3 Player
Stuck on start screen
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Then get the firmware upgrade
Jun 24, 2008 | Philips GOGEAR SA6045 MP3 Player
Not showing memory
Helpful website:
http://www.samsung.com/download
Jan 12, 2008 | Samsung YH-925 MP3 Player
Recovery
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Dec 29, 2007 | Creative Labs ZEN V Plus MP3 Player
Recovery Mode
Clean Up
Format (All)
Reload OS/ Firmware
Dec 28, 2007 | Creative Labs ZEN V Plus MP3 Player
STUCK in RECOVERY MODE
Clean Up
Format (All)
Reload OS/ Firmware
Dec 17, 2007 | Creative Labs ZEN V Plus MP3 Player
Recovery Mode
  • Detach your player from the PC if it is connected, and turn off the player.
  • If the player stops responding, you can reset the player. To reset the player, gently insert a thin object into the Reset hole located below the power switch.
  • Press and hold the Play button while powering on your player.
  • When the player displays the Creative logo, release the Play button.
  • It will display the following options:
    Clean Up Scans the player and removes invalid links from its music library.
    Format (All) Caution! Erases all content!
    Reload OS/ Firmware Caution! Erases your player's firmware.
    Dec 06, 2007 | Creative Labs Zen V MP3 Player
    Hard disk prob
    hard disk is bad.
    can you format?
    1. Detach the Zen player from your PC , and ensure that the Zen Sleek is turned off.
    2. Connect the power supply to the player.
    3. Hold down the Play/Pause button while inserting a paper clip into the Reset hole
    underneath your player, beside the data/power connector. Keep on holding the
    Play/Pause button while you release the Reset button. The Rescue Mode screen will
    then appear.
    4. After the recovery mode has started, release the Play/Pause button
    It will display the following options.
    Dec 04, 2007 | Creative Labs Zen Touch MP3 Player
    Transferring Music from Napster w/o WMP
    Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
    http://www.sandisk.com/Assets/File/Downl...
    You need to put the device into "recovery mode" before you run the tool.
    - Turn the device off (hold power for 20 seconds)
    - Slide the hold switch into "hold" position.
    - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
    Then run the recovery tool. Select format when prompted.
    Best of Luck.
    Sep 01, 2007 | SanDisk Sansa E280 MP3 Player
    No music library content
    try downloading the MP3 player recovery tool from Creative's website (the tool contains the latest firmware update available -- 1.15.03). Plug your ZV+ into your PC, run the program and let it update the firmware. Then format, reload your music and try it.
    May 13, 2007 | Creative Labs Zen Touch MP3 Player
    27 people viewed this question
     Grubhead
    Grubhead
