Question about Beverage-Air Undercounter Refrigerator one section with stain
Under counter beverage air refrifgerator stop
Everything is working fine and then it just stop getting cold.
    Champion:
  • 435 Answers
It needs to fill the the circuit of the refrigerator motor with gas.
Posted on Feb 04, 2010
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Beverage Air Kegerator Runs constantly gets too cold
yes sounds like a bad defrost terminator or timer?
not allowing it to go into defrost so compressor runs all the time and it frreezes up
Apr 29, 2013 | Beverage-Air Refrigerators
Where can I get a wiring diagram for an under-counter Beverage-Air cooler. The condenser runs then stops after a few seconds. Figuring a bad relay? The power runs but the condenser kicks off immediately...
If it's the condenser fan you are talking about you will not need a wiring diagram. The fan should be wired to the compressor and the thermostat. the thermostat is the relay to start the fans and compressor. I will continue to look for a wiring diagram. When the fan wears out they will stop causing the cooler to overheat. I think replacing the fan would be what you need. I believe that Beverage Air used the Copeland compressor with the condenser fan mounted on the one end of the the same slide in compressor. Check your voltage on the 2 wires going to the fan. When compressor is on the fan should also be running. I just have the feeling that condenser fan is defective.
Sea Breeze
Aug 19, 2009 | Refrigerators
Beverage air model UR30G, not cold, fan still running
check the thermostat for proper setting, evap could be frozen up, the condenser fan could not be running, unit could be low on freon. start check some items and let me know.
Jun 09, 2009 | Carrier Beverage-Air UR30GEFD Beverage...
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
Jan 20, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Beverage Air ST58N Not cooling
Compressor is cycling on the overload protector. Cause could be a bad starting relay but is more than likely the compressor is bad.
Jun 11, 2008 | Carrier ST58N
Under counter beverage cooler
It might be ice around the fan. Try defrosting it. This has been happening to mine, even through it is supposed to be 'frost free'
Jan 15, 2008 | Avanti 310SST Compact Refrigerator
DRIPPING OLD BEVERAGE AIR FAUCET
New faucets are easily had from many places like beveragefactory.com, northerbrewer.com, austinhomebrew.com, micromatic.com, etc. You should also be able to find replacement washers/o-rings for your current faucet, but it may require an email or phone call to one of the sales reps to locate one. If you decide on a new faucet consider a Ventmatic (Shirron) forward sealing faucet. Much better design that drips less and doesn't stick after sitting a few days. The only issue I've seen is that the machined grooves in back of the faucet may not mate up with your current shank requiring a machined (as opposed to cast) shank to match.
Nov 01, 2007 | Beverage-Air MT27 Beverage Cooler...
Beverage-Air Undercounter Refrigerator one section with stain Logo
76 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
