Question about Nintendo DS Lite Console
When on charge only lasts a few seconds and then cuts out
When plugged in to charge only lasts a few seconds then cuts out tried new battery and charger but still the same,
    Guru:
  • 110 Answers
Your charging fuse has blown. If you have a warranty i'd suggest using it to get it repaired, if not you can either take it to a local repair shop or try replacing it yourself.
You need to have fairly good soldering skills as the fuse you will be replacing is tiny (1.6mm x 0.8mm). You can buy the fuse you need from ebay (do a search for ds lite fuse). Taky your ds lite apart and locate the "f1" fuse (here is a link to the pic of the fuse location: http://m3wiki.com/index.php/Image:Usgcpu01fuses.jpg ). Remove the blown fuse by de soldering it and replace it with the new fuse and solder it into place, once this is done you can put your ds back together and test if the charger now works... if it does but the ds will not switch on you will have to also replace f2 (also shown on the picture).
If you want a more detailed explaination for the replacement of the fuses do a google search for "ds lite fuse replacement2 and you should get plenty of guides show up.
Some people say just to bridge this fuse if its blown but i'm strongly against this, the fuse is there for a reason and if you bypass it more serious damage can occur and that will be far more costly and dangerous.
Hope this helps and like to say I accept no responsibility for any damage that may occur whilst using my advice.
Regards,
SOD69
Posted on Feb 06, 2010
I have a newer 58v Echo trimmer. Worked fine last season, but when I use it now it runs for a few seconds and then completes shuts down. If I try again, it runs for a few seconds and stops again.
This appears to be a good news problem. There is an easy fix/work around! Consumer reports found the same problem that you have discovered.
Holding down the check battery switch allows the unit to operate. Read the link around the sixth paragraph the story is told.
Echo Trimmer Can Be Tricky to Start
"Our testers discovered the fix by chance. Pressing the check battery button, a last-ditch attempt to get the trimmer working, made all the difference. While this button ordinarily indicates the battery's charge status, in this case it also served to keep the battery from switching into protection mode and cutting off power to the motor. The next time you fully charge the battery, however, the problem can reoccur."
Hope this has helped?
Feb 27, 2016 | Echo Garden
When I use the driver it runs down quickly only six screws .then only charges 10 seconds.battery voltage after charge is 11.8 .driver cuts out at 10.4
how old is the device ? if new check warranty take back to shop and complain if you had a few years and work you done with it could be field coil or bushes probably cheaper and simpler to replace whole device
Mar 13, 2015 | Drills
My huawei ascend m860 wont charge. when i plug in the charger nothing happens. it was working fine yesterday and last night it wouldnt charge up. today i bought a new phone charger and it still wouldnt...
This happened to me too, you have to take your phone back to who you bought it from so they can repair it. Its the chip inside the phone that is bad. Not the charger.
Dec 31, 2010 | Cell Phones
My htc touch phone don't want to charge i put in the chager and the light just blinks. what seems to be the problem.?
Your battery has been depleted past a chargable state. This is a due to a bad design in the phone that doesn't monitor the battery power state well enough. It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
WARNING:
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
WARNING:
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 30 seconds. Then quickly plug the battery back into the mobile, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 30 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Feb 01, 2010 | HTC Touch P3450 Smartphone
Philips Go Gear 1BG not turning on
The battery could be bad.. They only last around 1 year.. IF the battey is bad id could give off wrong readings too...
I would try a new battery..
Rate well ;o)
Jul 22, 2009 | Philips Sport Personal CD/MP3 Player
The DS Green Light Cuts On But Shuts off after a few seconds
I dont now about the sound but for the battery is that the ds charge battery is over! if you see backwards you will need to open it and buy a new battery thats all!!!!!! I try it it works
Jun 06, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
180 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
