Question about Sony DAV-FX10 System
Buttons I have the problem that the buttons are working bad. When a press play the volume goes down, when I press the stop button it changes the disc. What can I do?
  • 682 Answers
PLEASE APPLY A GOOD BRAND CONTACT CLEANER(FROM RADIO SHACK OR OTHER ELECTRONIC STORE)-OVER THE BUTTON AND PRESS IT MANY TIME AFTER THAT.-IF YOU FIX IT BY CONTACT CLEANER IT IS O.K-OTHERWISE IF THE PROBLEM EXIST YOU HAVE TO PASS TO SERVICE CENTER.
Posted on Mar 24, 2008
I have an uniden exa 2980 and losy manual,how do I obtain a copy.also how do I turn up ring volumn?
Uniden has the manual for the EXAI2980 here: https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/exai2980om.pdf .
Do you need to adjust the ringer volume of the base, the handsets or both? To set the ringer volume of the base, start with the phone in standby mode (no calls being made or received) then press Menu 4 times (the right-hand button in the row above the volume up/down buttons). You should hear the current ring volume and see it displayed on the LCD screen. Press Set (the left-hand button in the row above the volume buttons). Press Skip/FF or Repeat/RR (the buttons on either side of the Play button below the LCD screen) until the desired ring volume level is displayed. Press Set to save the setting. Press Play/Stop to exit the menu system. See page 38 of the manual (page 40 of the PDF above) for the directions.
To adjust the handset ringer volume, press the handset volume up or down buttons with the phone in standby. The last chosen ringer tone and volume will be saved. See page 16 (page 18 of the PDF). Sometimes, the handset will not ring after losing the security code that pairs it to the base. Remove the handset from the base. Press and hold Page on the base (between Set and Menu). While the handset is sounding the paging tone, replace the handset in the base. Leave the handset in the base until the flashing stops (more than 5 seconds). See page 47 of the manual.
I hope this helps.
Feb 12, 2018 | Uniden Lands Phones
I have my brothers droid moto phone he passed away and I want to get it hooked up to Verizon but do not know his password. How can I clean the old password off of the phone and install my password.
Hi @Rock Aduh , are we talking about the password to go in to the phone? If it is, please perform a factory reset.
1. Ensure the device is powered off.
Note If the device doesn't respond to input, press and hold the Volume Up/Down button then press and hold the Power button. When the device screen goes blank, release the Power button while continuing to hold the Volume Up/Down button then proceed with step 3.
2. Press and hold the Volume Up/Down buttons then press the Power button.
Note When presented with the Boot Mode Selection Menu, release all buttons.
3. Press the Volume Down button to tap Recovery then press the Volume Up button.
4. From the DROID triage screen:
a. Press and hold the Volume Down button.
b. Press and release the Volume Up button.
c. Release the Volume Down button.
5. Select wipe data or Factory Reset.
Note Utilize the volume keys to highlight and the Power button to select.
7. Select Yes -- delete all user data.
Note Data wipe may take several moments.
8. Select reboot system now.
Note To set up the device after the reset has completed, refer to Initial Activation and Set up.
Hope this helps. Factory Data Reset Powered Off DROID RAZR RAZR MAXX by MOTOROLA
Oct 30, 2017 | Verizon Cell Phones
My iPhone SE stopped making sound when ringing, it only vibrates. I have checked all settings/side button, all correct.All other alerts-text, etc.-still work with sound alerts. Anyone know how to fix?
One thing to check is the ringer volume - by default you can change the ringer volume using the volume controls on the side of the phone even when the phone is locked - this often means that it can get pressed in your pocket to zero volume, which is very annoying. Try pressing the volume up button from the home screen while not playing any music and see if it goes up. You can set the volume in the settings and even tell the buttons to only change music volume, which is what I do.
Jan 24, 2017 | Apple iPhone Cell Phones
I want to play Dvd's from Europe so I want a region code free.
1. Power ON the main unit (some unlocks work with, some with no disc inside)
2. Press the SETUP button (on the top of the player) to open the setup menu
3. Navigate to the PREFER menu using the button below the screen
4. Press NEXT>, PREVIOUS, NEXT>, PREVIOUS, NEXT>, NEXT>, aPREVIOUS
(NEXT> and PREVIOUS are on the top of the player next to the SETUP button. Don't use the menu navigation buttons below the screen for this.)
5. The current Region of the player should be displayed on the screen
6. Use the menu navigation UP/DOWN buttons (below the screen) to change the region. Region 0 is region-free.
7. Press PLAY/OK (below the screen) to confirm the region selection
The player should now be unlocked and able to play discs from all regions - it worked on my PD9012/37 that was region 1
Please note: Unlocking a DVD player may invalidate the warranty and some DVD players have been damaged through failed attempts to unlock them. Unlocking the DVD player is attempted at your own risk.
Jun 21, 2011 | Philips PD7012/37 Player
I just purchased a 5300 home theatre system. When I insert a blue ray disc, it will play the previews, but when I hit the play putton, it goes to the settings menu. What seetting have I missed?
I would suggest to read on the owners manual first before operating your machine.and you can avail of the warranty if you found problem n your playaer...
Jun 13, 2011 | Samsung Televison & Video
None of the buttons on my cd player work. I can put a cd in it and it will play it, but nothing comes up on the face and i can not change the volume
in your manual it says when you buttons dont function press the reset button
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=CDXM610PDF&sliceId=pdfPage_1&docTypeID=DT_MANUAL_1_1&dialogID=178426004&stateId=0 0 188734284
here is the link and it goes to sony scan down to troubleshooting and you will see were it says to press the reset for you problem
caraudioquestion@gmail.com
Oct 16, 2010 | Sony CDX-M610 CD Player
How do I play a movie on my Samsung blue ray without a remote
On fornt of the player you have the buttons for opreation.You can use these buttons to operate your DVD player with out remote.
I have attached a image for your BD-P1600 player so your reference
1.DISC TRAY :Opens to accept a disc.
2.DISPLAY :Displays the playing status, time, etc.
3.Remote Control Sensor :Detects signals from the remote control.
4.OPEN/CLOSE BUTTON :Opens and closes the disc tray.
5.SEARCH/SKIP BUTTONS :Goes to the next title/chapter/track or goes back to the previous title/chapter/track.
6.STOP BUTTON :Stops disc playback.
7.PLAY/PAUSE BUTTON: Plays a disc or pauses playback.
8.POWER BUTTON :Turns the Blu-ray Disc Player on and off.
9.USB HOST:A USB memory flash stick can be connected here and used as storage when connected
to BD-LIVE. It can also be used for firmware upgrades and MP3/JPEG playback.
Thanx
Jul 26, 2010 | Samsung BD-P1600 Blu-ray Disc Player
Stop beeping at end of wash on bosh machine
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops. Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Aug 16, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Help Finding Replacement Parts
I had the exact same problem with the channel/volume autoshifting. I found a electronic firm that would rebuilt the board for $185.00 plus shipping-----screw that. I cut the plastic hold down nubs on the channel/volume buttons itself and disassembled the contact. Inside the button was a copper metal disc showing arc tracks and "carbon scoring" on the underside. I just removed the button guts and now use the remote for channel and volume adjustments. So far the power button still works for me. I may try buffing and cleaning the disc and contacts later, but what the hey, I'd rather surf with the remote from the couch.
Jan 09, 2008 | GE 31GT740 31" TV
Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Nov 05, 2007 | Tivo DirectTV Remote Remote Control
Sony DAV-FX10 System Logo
71 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
