Question about General Electric Microwave Oven
My control panel went out, I mean the glass doesn't turn and the panels light went out. It heats but I have to move objects around to acquire even heating.
  • 72 Answers
Your problem is possibly a blown spot on your control board due to surface lights blowing out
Posted on Feb 04, 2010
One of my glass top plates doesn't work, it goes red and then turns off. How can I fix it?
I have no idea what you're talking about. Glass top plates? In a microwave oven? All I know is the glass turntable tray. And if it's not turning around, you either have that feature turned off (a dedicated button on the control panel), or else the turntable motor is bad.
Sep 09, 2014 | Microwave Ovens
I have a Maytag Microwave/Hood MMV4203DS00. Twenty minutes after its last use as a microwave oven, the Vent Fan spontaneously went on and the Display Shows: VENT...FAN..--5E-- (or SE?). The microwave...
"SE" error means you have a shorted membrane keypad.
On this model, the membrane keypad is not available as a separate part, so the control panel frame assembly (which comes with a new keypad) would have to be ordered and replaced.
It's actually a pretty simple DIY repair.
The frame assembly is part number W10258190 and you can get it for $67.98 (subject to change) from the Pros here. You can also order the thermostat (part number WB27X10567 ) from them.
Their is a video here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad as per the photo below.
Some connectors on the relays have a lock:
positivelock.jpg Then move your circuit board into the new frame. Be careful, the display is made of glass.
Sep 01, 2013 | Microwave Ovens
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Electrical short /pop sound & now it doesn't heat. Everything else works. Any idea what went out.
The signs are not always evident, but from the description the magnetron has failed.
Apr 13, 2012 | Sharp R-1491 Microwave Oven
Where is the fuse in under-counter miccrowave?
remove the vent grill at the top, may have to slide to left after screws are removed. then you will see a screw holding the control panel, remove. then slide the panel up slightly and the panel should come off. behind the panel you fine a 20 amp 250 vac glass type fuse. remove and replace. if your MW works cool,,,,, if it does not you may need to call for service.
Jan 23, 2012 | Amana Microwave Ovens
I have a Gold Star Model MV-1500MG over the range model microwave oven. Everything works except it will not heat and the turn table does not turn. While it is running everything sounds normal but does...
Hello, does the control panel light up? If it doesn't then probably the fuse has shorted. Now, if the front control panel does light up. There a number of thing going on. Door closer switch is working.
The mega-tron tube is shot or something is going on the micropressor. Now, if the mega-tron is shot. Buy a new micro wave oven and allways to recycle used appliances. GB...stewbison
Aug 22, 2011 | Goldstar MV-1526 Microwave Oven
Control panel seems to be responsive, internal
Make sure the glass platter is correctly seated on the plastic drive. Now gently press down on the platter and see if it resists turning. If the platter turned easily, the plastic drive is spinning on the motor shaft and needs replaced. If the platter resists movement, the motor under the floor needs to be replaced. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 25, 2009 | Sharp R-930AK Convection/Microwave Oven
Danby DMW753W ; machine starts without any command
The membrane of the touch control is shorted and must be replaced.
Mar 27, 2017 | Danby DMW773 Microwave Oven
Micro turns on but doesnot heat also turn on by self
Hello bbmasonjim,
If your micro turns on ( meaning everything seems to be working from the control panel) and you aren't getting microwave energy to heat food..you may have any number of damaged or defective components : Magnetron Tube, Filament Power Supply or HV Capacitor.. None of which are something the untrained person should mess with. Even unplugged, there is High Voltage potential inside the electronics compartment. If it is less than a year old, it may still be under warranty.. otherwise.. the cost to repair would probably be higher than the cost to replace..
Regards,
Rick
Dec 13, 2008 | LG LRM1250 Microwave Oven
Won't heat
The Microwave's "Magnetron" is what heats things up. This is true for all Microwave's. The magnetron is normally on the left and sends excited electrons across the interior. Those electrons bounce around inside until their energy is spent.These excited electron 'waves' are slightly larger than the hole openings in the front door glass panel black grid. Usually, when a magnetron goes you would see and hear some popping and witness some arcing inside the interior. However, you may not have been nearby when this happened. Since you heard popping behind the control panel, you probably have electronic failure in the control panel and that failure may have been precipitated by the magnetron or not. In any case, it is very dangerous to disassemble a Microwave and access the magnetron unless you are trained and have been qualified to do this.
With the cost of Microwaves having stabilized and also being quite low compared to 20 years ago, I would take it to a warranty service provider in your area that also sells them, such as Home Depot for example. That way, if it is too costly to repair compared to a replacement cost you can shop for a new one and may even get a discount should you ask them to give you one.
Sorry for the apparent bad news but if you feel this is the answer you're looking for please rate this solution as fixed or helpful. It means a lot to those of us who work for you in the free area instead of for a fee.
You can phone or write this address below for questions regarding your warranty or warranty repairs. Othewise, you can shop online for a replacement at homedepot.com or sears.com
May 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
General Electric Microwave Oven Logo
44 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
