Question about HP LaserJet 3020 All-In-One Printer
How do you scan multiple pages on one page we have a 3020 all in one. we would like to scan multiple pages and would like them to appear on one image/page
  • 16 Answers
SOURCE: scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Posted on Jan 05, 2008
adonscott
  • 106 Answers
SOURCE: Scanning multiple pages
hi,
For you to be able to scan multiple pages using the .pdf and save it in one file, here are the steps that i want you to follow.
SOLUTION I.
1. Open the Solution Center.
2. Click on Settings, then go to scan settings.
3. Click on Scan preferences.
4. Make sure that the "Prompt for additional scans from glass/TMA has a checkmark. then click OKAY.
SOLUTION II.
1. Solution Center is open, click on Scan documents.
2. Scan document settings is open, choose SCAN TO: .pdf and file type is .pdf
3. Click on SCAN below. It will start scanning, and just click on ACCEPT everytime it gives preview on each document.
Thank you.
adonscott
Posted on Jul 04, 2008
safenude
  • 124 Answers
SOURCE: scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
Posted on Jan 27, 2009
  • 11 Answers
SOURCE: Scanning Multiple pages into one pdf
Typically it is possible, in advanced settings for scanning it will typically give you an option to scan multiple pages into one document.
Posted on Jun 26, 2009
  • 1121 Answers
SOURCE: does HP 8500 scan multiple pages into one file?
yes if you use a pdf editor or office suite.
Posted on Dec 25, 2009
How do I scan multiple pages to make one document ?
To scan multiple images into one file:
  1. Go to Start, Programs (Windows XP: All Programs), Lexmark , Lexmark All-In-One-Center.
  2. Place your first scan on the scanner glass. Press Preview Now to see what the scan will look like.
  3. Under Scan... Send scanned images to, select Microsoft Word (or the relevant software).
  4. Click See More Scan Settings.
  5. Next, click on Display Advanced Scan Settings.
  6. Under the Scan tab, look for an option towards the bottom that reads Scan multiple items before output,and select it.
  7. Click Scan Now.
  8. After each scan, you will be asked if you would like to scan another document. You can select either Yes or No.
  9. Click on Yes to continue after each scan until you have scanned in all of your pages.
  10. When you have scanned all your pages, click on No. One of two things will then happen:
    A screen will appear which will allow you to save all your pages in a single file to a destination of your choosing.
    The software package you have chosen to scan your item to will open with the scanned image displayed.
source is fro the link below. I do not own a Lexmark and hence could not verify
http://support.lexmark.com/index?page=content&id=HO841&locale=EN&userlocale=EN_US
Mar 02, 2016 | Lexmark X7350 All-In-One InkJet Printer
How do i scan multiple pages and sav it to my documents. It seems like i am only able to scan and save one page at a time
Hi
If you have a Top feeder on the scanner, you can scan mutiple pages. Change the setting of the scanned file to pdf file (not JPEG) by going to the scanner icon and change the type of file you want to scan. Scan it as PDF FILE and then it will scan multiple pages. Regards
Jun 16, 2011 | Computers & Internet
I can't figure out how to scan multiple pages to one file
Hi There !!
Thank you for choosing fixya.com
It is possible to scan different batches scanned from the ADF into one PDF file. When loading more pages in the ADF after the first realm is finished, it asks if you want to continue scanning to the same file. After that, it will continue scanning to the same file. However, this feature can be selected in the Adobe Acrobat application itself. From HP software, if we load the paper after one realm of paper in the ADF is finished, it will scan the second realm to a different file. If you want to continue scanning to the same file, you need to have either Acrobat Exchange or Adobe Acrobat installed on the computer. Adobe Reader will not provide this feature. After installing either Adobe Acrobat or Acrobat Exchange, perform the following steps to scan pages to a single file:
  1. Make sure your scanner is turned on.
  2. Start Acrobat Exchange or Adobe Acrobat.
  3. Put the document into the scanner (usually face down on the scan bed).
  4. In Adobe Acrobat, click File , then Import , and Scan .
  5. Select the device and whether you are scanning a single- or double-sided document.
  6. The scanning software opens and the scanner completes a preview scan.
  7. When the preview scan comes up, make any adjustments you would like, including selecting the area you want to appear in the final scan.
  8. Click Scan . This will get the final scan into the computer.
  9. Your scanning software should take you back to Adobe Acrobat.
  10. In Adobe Acrobat, you should see a small window asking you if you want to scan another page. If the document you are scanning has more than one page, click the Next Page button. If this is the only page, click Done .
    NOTE: Scanning multiple pages causes each page to append to the previously scanned page. If you have multiple pages, but want them to be in different files, click Done after each page to create separate files.
  11. When you have scanned the last page, click Done on the window described in step 10.
  12. Your scanned pages will open in Adobe Acrobat. Scroll through to make sure that everything is there.
  13. Click File , and then Save As to name your file and save it.
Still unable to figure out, How to do this? Here are some tutorial on HP website that might help.
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&taskId=120&prodSeriesId=1161389&prodTypeId=18972&supportTaskId=23095
Hope this would help.
Regard's
Anurag Shukla
Sep 04, 2009 | HP LaserJet 3055 All-In-One Printer
I have an Epson Office Bx300F - I have a CV of three pages and want to know how to scan the three pages into one scan file Can you advise ? As you imagine having to scan three times means I then have to...
I have a different all-in-one but the tool used for scanning may be similar. When installing the printer, the MF Toolbox utility was also installed. If I want to scan multiple pages into a single document, I have three options for "Save as type". One is "PDF", another is "PDF (Multiple pages)" the third is "PDF (Add page)". I use the second option for multiple pages. Once the first page is done, a dialog box will appear and prompt me to insert the next page in the scanner and continue.
See if the tools installed with your printer have something similar.
Sep 03, 2009 | Computers & Internet
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
Jun 26, 2009 | HP Photosmart C5280 Printer
HP C6180 will NOT scan multiple pages into one file
If you want to scan multiple pages, go to HP Scan Pro, click on the SCAN menu, and then make sure that "Documents" is checked under "New Scan." This will allow you to scan multiple pages and it will scan black n white or color...whatever you place on the glass.
Jun 21, 2009 | HP Photosmart C6180 All-In-One InkJet...
Scanner is not reading multiple pages...
Check your scanning software settings. If you are getting only one file output, then you must have chosen 'multipage' option.
S. Mohan
Jun 12, 2009 | Canon DR-2580C Path-Through Scanner
How to scan from dell926 printer
Hi here is the user guide for your printer
Download it here
http://support.dell.com/support/edocs/systems/prn926/en/ug_en.zip
How to Scan
Scanning Single-page Documents or Photos
  1. Turn on your computer and printer, and make sure they are connected.
  2. Load your original document or photo.
  3. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 926.
  4. Select Dell All-In-One Center.
    The Dell All-In-One Center opens.
  5. From the Send scanned image to: drop-down menu, select the program you want to use.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add the program to the list.
  6. Click See More Scan Settings to customize your scan.
  7. When you finish customizing your settings, click Scan Now.
Scanning Multiple Photos or Multiple-Page Documents note-dell.gif NOTE: Some programs do not support multiple-page scanning.
  2. Load your original document. For more information, see Loading Original Documents on the Scanner Glass.
    note-dell.gif NOTE: You can also open the Dell All-In-One Center from the operator panel on your printer. For more information, see Using the Dell All-In-One Center.
    note-dell.gif NOTE: If the program you want to use is not listed, select Search for more... in the drop-down menu. On the next screen, click Add to locate and add your program to the list.
  7. Click the Advanced button.
    The Advanced Scan Settings dialog box opens.
  8. On the Scan tab, select the Scan multiple items before output check box.
  9. Click OK.
  10. When you finish customizing your settings, click Scan Now.
    After you scan the first page, a prompt appears requesting the next page.
  11. Place the next sheet on the scanner glass, and click Yes. Repeat until you finish scanning all pages.
  12. Click No when asked for another page.
    The program opens with the multiple pages scanned.
Oct 06, 2008 | Dell Photo 964 All-In-One InkJet Printer
Hi there
This could be one of many problems, i will tell you a few solutions that i know of, check the lid and see if there is a bulge in the middle of the lid (is the lid uneven in anyway?), if it is, i would suggest that you return your printer to the place where you bought it. This could also be a setting on your printer, the setting could be to scan a book or to scan two smaller pages.
If you would like a manual on how to sort this out (if the problem persists), please e-mail me at dustin_ellse@yahoo.co.uk
Kind regards and good luck
Dustin Ellse
Jun 26, 2008 | Samsung SCX-4725FN All-In-One Laser...
Scanning...
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP LaserJet 3020 All-In-One Printer Logo
Ben Johnson
