Question about Dell 1600n All-In-One Laser Printer
ADF works only in vertical.
Hi. I haver two Dell 1600n with the same problem. If you try to use the ADF, it takes the paper but stops at the middle of the scan (for copy, fax o scan, it doesn't matter) with an error of [paper jam]. I have checked the three sensors it has, and they seem to be right.
The most strange is that if de ADF is not horizontal, but vertical (you turn the printer so it lays on its back), it works perfectly.
Any ideas?.
thank you in advantage.
Paco.
    Scholar:
  • 105 Answers
Sounds like a paper jam sensor. Most sensors are spring-loaded and will move in one direction, then back when the paper is feeding. If the process works when the printer is on its back, you are likely using gravity to bypass the sensor's intended operation. Sensor is not swinging in either direction as paper passes through, therefore it is not reporting any blockage/jams.
Posted on Mar 27, 2008
DELL 1600N ADF JAM. IT ISNT PICKING UP THE PAPER. THE GEARS ARE TURNING BUT IT ISNT GRABBING
Hi I had the original problem too, but the cheapest replacement part I could find is 30 pounds.
So I stuck a piece of sellotape over the white bit and trimmed the edges so it didn't catch the paper on the way over. Works for the moment.
Oct 21, 2011 | Dell 1600n All-In-One Laser Printer
Black vertical line along left margin when using the adf to scan.
Check both the Fuser Unit and the Cartridge for lines . In any of the rollers are found with a line that means it needs to be replaced.
Jan 26, 2010 | Dell 1600n All-In-One Laser Printer
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
Dell1600n showing a document jam, have tried everything eg switching it off but cant find a solution. it prints fine and copies fine as well just isnt taking anything from the ADF. So I cant send a fax...
check the gears in the adf maybe you have one that is misaligned ,run a piece of paper following the paper path check the flag sensor make sure none of them is jammed close or misaligned.
Good luck
Jul 09, 2009 | Dell 5310n Laser Printer
Hi. I've a Dell 1600n printer. There is plenty of paper in the drawer, but message says No Paper/Add Paper.
Remove the drawer then insert again.. if the same problem.. clean the sensor maybe its broken.
Jun 15, 2009 | Dell 1600n All-In-One Laser Printer
Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
Printer Problem
Clean the small glass strip on the left side of the scanner. There is probably some dirt there and will only show up when using the ADF.
Nov 15, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n: Toner marks down the center of the page.
There are 2 seperate glass areas on the top, the large one is for when you lift the cover to scan or copy, the little narrow one is when you use the ADF. If there is a dot or a spec on the narrow part, it will leave the streak on the page, Clean the narrow part really well. I use a foaming window cleaner, and a razor blade.
You may also want to check to see if there are any small scratches on that glass. That will cause the same thing to happen.
Nov 14, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n ADF Problem
You have either a piece of dust or a scratch on the scanning glass. This will show up as a line because the paper is pulled across the point.
Nov 12, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
99 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
