Question about Califone International 1030AV Turntable
My Cardmaster is not reading very loudly. Is it
My Cardmaster is not reading very loudly. Is it because it needs to be cleaned? How can I do that?
Program button no response
The cd shouldn't be making a noise, but your cd drive might be, there could be something wrong with it try to identify any cracks or marks on the cd, if there are any that may be the cause behind the program not responding. The loud hum you're hearing could be due to overheating, carefully check your computers temperature, if the cd is damage the loud hum may be produced due to the cd drive overworking itself trying to read a damaged disc. Hope this helps.
Feb 12, 2013 | Computers & Internet
When I try to clean the oven there is a very loud noise. what is this?
This is likely the solenoid that actuates the door lock. Read this link Self Cleaning Problems
Nov 04, 2010 | Frigidaire Ovens
Self cleaning oven doesn't work and makes loud noise when you close latch
Hi.
The door latch mechanism must be replaced after reading impedance and volts from EOC to latch.
This kind of problems can be caused by the high temperatures generated on self cleaning cycle.
Regards.
Mar 01, 2010 | Jenn-Air Kitchen Ranges
Xbox 360 console can't read disk
If your console has stopped reading discs this can be because the receptors on the back of the drive have overheated and to fix it you will need to send it in or use a good repair guide to do the job.
Nov 25, 2009 | Microsoft Xbox 360 Console
My Dell Inspiron's DVD has suddenly begun making a loud humming noise when I play a video? Why?
This is usually happens if the DVD drive receives too little power from the laptop or maybe it's just needs a cleaning.
I would try first to clean it from the inside, using a cleaning CD. If that doesn't help you will have to check maybe with a technician if the drive is receiving enough electricity.
Some info- Dell is known for her malfunctioning drives, mine sucks. It reads okay, but burns crappy CD+DVD. sometimes these drives needs to be replaced after a while
Oct 15, 2009 | Dell Inspiron 4000 Notebook
Not reading disc
If Wii gives Disc Read Error, First step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives Information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Dec 30, 2008 | Nintendo Wii Console
How can i get the text to be read out loud?
First you have to specify, which program you are using ! Adobe Acrobat, MS Word or any other program ?
  • Adobe acrobat: On your Menu, select or click "view" and select the "read-out-loud" option from the menu, then, in the next pull-down menu that appears, select your optioon to read the whole document, or only the page.
  • General WindowsGo to start, click on run, then type in narrator. Make configurations that you need in the little narrator window. This program should read most Windows appliances. To configure your narrator, navigate to your control panels to the "Speech" control panel. Open it and configure the speed and the output audio device.
  • If you use WinWord, you can easy copy-paste your text into notepad to read the text-out-loud
Kind Regards,
Stef
Apr 19, 2008 | Computers & Internet
My Emachine T5212 has a loud fan constantly running
sounds like a fan is going out .. with the case open can you identify which fan is making the noise?
Mar 10, 2008 | E-Machines eMachines Desktop PC
Doesnt play any games.
try cleaning the lens with a cotton swab
Nov 10, 2007 | Sony PlayStation 2 (PS2) Console
Califone International 1030AV Turntable Logo
Top Califone International Audio Players & Recorders Experts
Michael Galve
Michael Galve
Michial Gueffroy
Ben Armstrong
Are you a Califone International Audio Player and Recorder Expert? Answer questions, earn points and help others
