Question about RCA Televison & Video
Rca tv model no p529229 serial no 103351510 chassis no ptk19551b .my tv had went out, then it would not power back up ,i opened the back up found blown 5amp .125 volt fuse.replaced fues now it powers up but color is not alinged .tv had an opption to ajust projection tubes owers manule page 33 screen menu number 6 opption ajustprojection tv is know longer there ,whay; one time e mail please.
  • RCA Master
  • 19,396 Answers
Hi.
If you cannot adjust the convergence using the alignment procedure , that usually means that the convergence ICs must be replaced.
Along with the convergence ICs (I think STK730 -130 on PTK195 chassis), better testing resistors located in convergence board.
If instead part of the service menu has disappeared, then the EEPROM hosted on the digital communication circuit may have failed. In that case the whole digital board must be replaced, as the EEPROM (250696) must be re-flashed with image, and the image software is not available anymore.
This last problem is not a common fault.
Posted on Feb 04, 2010
I need the serial number for an RCA 22" tv with DVD model number LED22B45RQD
Its serial number should be with its back cover; either on a sticker or hard printed. If not, can get this information by its chassis inside.
Electro help
Oct 20, 2014 | RCA Televison & Video
Lost all power in 1991 RCA TV model F35100ST
Best thing to start here is open up the TV and look for any blown components on the power board (which is the one that has the power cable attached to); check the transformer for continuity first, that is the first thing to blow. Then go on with capacitors, resisters, and any burnt wires.
All of these parts are easy to find and replace, they can be found in local electronics shops.
Please post back how it went and any further information or questions you may have, so we can help you better.
Dec 14, 2007 | Televison & Video
Smelled smoke and hot wires, tv went off and never came back on again. opened back and found only one small part looked burned out, ( broken and a little brown on the board.) Part number R14705.
Thats a 27K 1/2 watt Carbon Composition resistor 5% tolerance. You got deflection issues so a replacement resistor will most likely fail unless you discover whaich componenet on the deflection board caused the resistor to burn. The deflection boards have been discontinued for your model which has the ATC321 chassis. But you can get a remanufactured ATC321 deflection board from www.tvrepairworld.com
Jun 12, 2011 | RCA HD52W56 52" Rear Projection HDTV
Power wont come back on TV
the most common component to fail with that sympton is the flyback. If the chassis is a ITC222A the flyback will be 259296 or 265409 as they were both used in that chassis and model number. If you need more assistance let me know the Chassis number from the tag in the back.
Mar 13, 2009 | RCA R52WM24 52" HDTV Projection Television
RCA Model 32V434T chassis ATC010A
for shure your fly back transformer is bad is a commom problem in this chassis
Mar 29, 2008 | Televison & Video
Tv went dead while viewing, will not power back up
You have a short somewhere in the load for the power supply. Probably the horizontal output transistor and the flyback transformer. You need to have it checked out by a tech. You may want to get an estimate. Stargazer
Mar 11, 2007 | RCA F36715 36" TV
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
