Question about Whirlpool RBS275PD Electric Single Oven
Whirlpool RMC305PDQ1 Oven-Microwave Combo Unit
I need to replace the door switches on the microwave. Is there a way to take the front of the microwave apart without having to slide out the entire unit out of the casework. From the part manual it look like it might come apart but I can't tell. Can someone provide guidance. Thanks
    President:
  • Whirlpool Master
  • 2,651 Answers
Is this model mounted over the oven as one piece unit?or does it hang above the stove?
Posted on Feb 24, 2008
I Have a Whirpool Microwave Oven Combo Model RMC305PDQ1 sometime when the oven is cooking the oven latch closed and we can;t open
Despite what the owner's manual says, you should not open a microwave door when it's cooking. You should press the Pause or Stop pad first. Otherwise, you will shorten the life of your door switches.
If you're ever unable to pen the door, then you have a problem with the door latch, spring, etc. that needs to be investigted and corrected.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 27, 2013 | Whirlpool RBS275PD Electric Single Oven
I have a Whirlpool double oven GMC305PRS01 when you turn on the oven it appears to me making all the right move IE it goes into pre heat and starts counting down but the elements are not getting hot.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message
Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
Nov 22, 2010 | Whirlpool GMC305PRS Stainless Steel...
My daughter did something to the door... when you close the door and set the time and start the display reads 'DOOR' as if it isn't closed and it won't start. Thanks for any assistance. Whirlpool...
i have seen this a few times. the m/w portion has seperate fuses and sometimes the cartridge fuse can be blown. it is located inside the top above oven. hard to get to without pulling the unit and getting the top off of unit.
others have had a failure in the microwave control board.
Jan 10, 2010 | Whirlpool GSC308PRS Stainless Steel...
Multiple replacement of Microwave door springs
KitchenAid Architect Series KEBC107KSS Electric Single Oven problem error F1E7
Sep 15, 2009 | KitchenAid KEBC107 Electric Single Oven
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
My GE Microwave/Oven Combo Unit JKP85B0A3BB has a melting chamber
It is one unit. You can not replace just a microwave.
KEMC308KBL01
send me am e mail at b4829@yahoo.com with the model number
May 31, 2008 | KitchenAid Architect Series KEMC308KSS...
Service Manual
when you took down the control panel and gained acess to the upper cavity , there wasnt a service manual just to the left inside a red plastic bag???, if not there is another fuse loacted just behind the micro front looks to be atop the capacitor area
Mar 09, 2008 | KitchenAid Architect Series KEMC308KSS...
Whirlpool oven/combo unit
http://www.repairclinic.com/SmartSearch/smartsearch.aspx go here enter your model number then under parts select all parts not listed and its on page two
Feb 08, 2008 | Ovens
Whirlpool RBS275PD Electric Single Oven Logo
236 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
