Question about Garden
Cant find sproket number 76695
MY SUPER DELUXE CHAIN SAW SPROKET NUMBER 76695 IS WORN AND CANT SEEM TO FIND REPLACEMENT? DO YOU KNOW WHERE I CAN GET THIS PART?
  • 677 Answers
Super Deluxe ? Do you mean a Poulan chain saw. Check here they handle all brands of chain saw parts.
By the way Poulan is owned by Husquvana, which is owned by Electrolux.
sales@mfgsupply.com
Posted on Feb 05, 2010
Greenfield mower chain tension
take chain off -- lay on floor --pull taught end to end push together --if it flexes more that one quarter of a inch --chain is worn --replace chain--also see how deep chain sits on sproket--- if sits too deep sprokets are wore and need replacing
Dec 27, 2013 | Garden
Chain is sticking to back sprocket and making my bike **** when i accelerate
Sounds like the chain is worn out and needs replacing if there is no more adjustment!
A good idea is to replace the sprockets at the same time, as they wear along with the chain, and will cause a new chain to wear out sooner.
Nov 19, 2013 | Suzuki RF 600 R Motorcycles
Knocking noise of chain in honda dream yuga bike when accelerating after shifting the gears. i have tightened the chain but still it happens.
That knocking noise could be that the teeth on your main drive are worn out and chain is jumping them on acceleration.Pull th primary cover and check the drive gear for chain on motor sprocket.Replace it if worn to that point.
Oct 02, 2013 | Honda Motorcycles
Popping noise coming from front sprocket when wheel is turned on 01 suzuki gsxr 600
hi it sounds like your front sproket is really worn and hooked when you turn the chain its not releasing the links smoothly ,replace it with a new one and check the condition of your chain it may be worth replacing a complete chain and sproket set as running a bike with a worn front sproket could lead to a back wheel locking up at speed if the chain jams
Feb 22, 2011 | 2001 Suzuki GSX-R 600
Chain seems to be installed correctly but when I start to cut the chain slips and stops it is properly tightened and pulls easily by hand
You need to inspect the sprocket for wear. Many time the sproket will get a groove worn in the theeth. When you're stopped, and on the normal teeth all is well. If you begin to cut and the chain moves into the goove it's suddenly loose. Replace sprocket and chain and you'll be sure they fit .
Jul 21, 2010 | Garden
I need to replace the chain sproket on my Hsuqvarna 345e chain sa
It has an out board clutch, please view this it is essentially the same.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
    Let us know how it worked for you.
IPL and operator's manual download
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
You may find detail B beneficial. HTH
Lou
Dec 17, 2009 | Husqvarna Forest & Garden No.967012396 345...
I hear a cluttering noise coming from my sprocket. I believe the front is worn pretty badly. Does anyone know how to get the front sprocket cover off? I think the clutch cable may be the problem but I...
The front sproket normally last for a very long time so I am pretty sure it is not the cause of this problem.Try to adjust the chain tension and this may solve this problem.Also if the rear sproket are worn out or it could well be the chain that needs replacing.Hope this gives you an idea.
Nov 13, 2009 | 1991 Suzuki GSF 400 Bandit
The cover that is over the chain sproket is missing the piece that holds it tight to the sproket to keep the chain from coming off and it does'nt have anything threaded so what was on there. the right side...
Go here:
http://shoppingcart.msservicecompany.com/Default.aspx
In theSearch for your unit by Model #:window type “RPS96” click “Search”
RPS96 – 8 Ft Electric Telescoping Pole Saw Appears; click the “View Model” link.
Click the “View Illustrated Parts Diagram” link.
I think page 2 detail 20B shows your saw configuration; pn 108120-01; E-Ring; $0.63. This is the 1 in 100 RemingtonPower parts still available.
You do know they are no longer is production? Replacement parts are almost exhausted.
In the very near future eBay will be your sole source for parts. HTH
Lou
Nov 06, 2009 | Remington Electric Chain Saw
My electric chain saw model # el-7 needs a new plastic sproket this one is stript. Ilove my chaine saw can you help me. aricher1@cogeco.ca waithing for your reply. Thank You
The el-7 is the series number, so I would need the model off the unit and I can give you the part number. You also call call 800-446-1446 or go online to www.masterparts.net with your model number and purchase your part from them.They should be able to help you. I hope this helps...
May 06, 2009 | Remington 16" Electric Chain Saw
Engine still cuts out and backfires after changing coverter
This seems to be a timing problem. backfiring usually means that the timing is off. The timing belt sproket could have worn off or belt its slipping.If your car has a timing chain that could have broken sprokets. Timing is usually the culprit here in cases like this.
Jan 21, 2009 | 1992 Chevrolet Lumina APV
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
