Question about Gateway MX7122 Notebook
I need to replace the power button - Gateway MX7122 Notebook
    Scholar:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 86 Answers
You can log on to their support site http://support.gateway.com/s//Mobile/Q106/Shadow/1009083nv.shtml
ERNZ
Posted on Feb 04, 2010
Change power switch on iphone 4s
Hi Justo,
First buy the new switch here: iPhone 4 and 4S Power and Lock Button iFixit
Then follow this guide to replace the button: iPhone 4S Power Button Replacement
Let us know if you need any more help.
Jun 25, 2016 | Apple iPhone 4S
I tried to replace my "volume/power" button on my 2004 Chevy Suburban but now it won't turn on. Any ideas? I got the replacement button from the dealership but they don't know what to do. If I coul
did you disconnect the radio to fit the button. if so you will need the radio code.
the button is a press on button the by pressing it on, you switch of the power . press again and the power comes on .turning the button gives volume
Feb 11, 2015 | 2004 Chevrolet Suburban
My phone power button
Depending on the phone the power button needs to be replaced.It's possible that the power button can be re-adjusted.The spring is crooked or fell out of place.
Apr 05, 2014 | Samsung Galaxy Prevail
Broken power button
You will need to replace the whole control board interface since the button is part of that assembly. Here is the part to order.
Nov 03, 2012 | LG DLE8377 Dryer
My printer will not turn on
First, try pressing and quickly releasing the Power button to start a Power On/Off cycle. Do not hold down the button. If this resolves the problem your done; if not continue on.
Inspect the power cord for visible damage; if damaged will need to contact HP to replace.
Disconnect the power supply (power module and cord) from the power source (wall socket) and the printer.
Test the power source, wall socket with or without your power bar or surge protector in place, with a small appliance you know works to confirm you have power. You may want to test the wall socket first and then test the power bar, etc. to make sure each component is not the problem.
If the appliance works then need to investigate the power supply. If the small appliance does not work you may need to check your electrical panel for a tripped breaker and possibly consult an electrician to check your electrical wiring.
To test the power supply plug in to the working power source; if the green light on the power supply does not light up you will need to contact HP to replace the power supply.
If the green light on the power supply lights up; reconnect to the printer.
Press and quickly release the Power button to turn the printer on. if the printer does not turn on you will need to check the USB cable.
Disconnect the USB cable from the printer.
Press the Power button to turn on the printer; if the printer turns on you will need to replace the USB cable.
If printer does not turn on, check the battery if your printer has one. A red light means the battery requires recharging; if it is still red after recharging, replace the battery.
If none of these steps resolve your issue before replacing the power supply try plugging the power supply directly in to a different working wall socket with no power bar or surge suppressor.; Press the power button.
If still no power to the printer you need to replace the power supply.
I
Dec 22, 2010 | HP Photosmart 8050 InkJet Printer
The ready light is flashing green then amber. What does this mean
This lights pattern means the waste tank needs the blotter replaced.
Then once replaced, the tank reset needs to be performed.
Waste Ink Tank Reset
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and release the Resume button
4. Press Resume button 2 times then release BOTH buttons.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
Jun 15, 2010 | Canon i950 InkJet Photo Printer
The power button needs replaced
go to hp.com down load the manual service & maint info its the top one of three it has pictures and directions how to disasemble your laptop remember its complicated make diagrams for yourself as you do it.
Oct 15, 2009 | Computers & Internet
Why cant i turn my iphone on
First off, we have to see if it is a power issue or a button issue. Try plugging in your charger first and see if you get the battery life symbol on your screen. If no, send it in for repair. You may have a cable problem, power or board problem that needs replacing. If yes, while leaving it plugged in, try to hold down your power button to see if it responds by turning on. If it does, you need to change your battery. If not, you need to fix/replace a bad button or cable button. You can get parts or service here -> iPhone 2G Replacement Battery and iPhone 3G Replacement Battery
Jun 18, 2009 | Apple iPhone Smartphone
Front power seat doesn't have power
check power going to seat buttons if there is power then the seat buttons need to be replaced/ buttons are only 5-10.00 a piece then replace if it there is no power going to buttons then its the motor/ Please rate my response thank you very much
Dec 29, 2008 | 2002 Toyota Avalon
Canon ip4300 ink absorber is full
You need to reset the waste ink counter. The printer doesn't know that you have replaced or cleaned the pads you need to tell it.
1. Turn off printer
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
8. Your printer should respond as normal.
Hope that helps, if it does please rate my solution.
Thanks
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Gateway MX7122 Notebook Logo
71 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
