Question about Dymo LabelWriter 320 Thermal Printer
Error: Will not print
Dymo 320 with USB connection. It has been moved from one computer to another. I have tried putting it into different USB ports. I have reinstalled the software but I still cannot get it to print.
  • 1 more comment
  • Smeeglq Feb 20, 2008
    Hi, should this still be done for Windows XP? Thanks
    I have just gone into the Ports and it says that I the operation to reconfigure the port is not supported.
  • Anonymous Feb 12, 2009
    Connected to XP, wll not print.
This things fucked. still not working, just the damn led light keeps blinking.
Posted on Oct 01, 2008
    Genius:
  • 1,011 Answers
Hello Sir,
To check the printer settings in Windows 95/98/2000
1. On the Windows task bar click the Start button, point to Settings, then click Printers.
The Printers window is displayed.
2. Right-click the EL40 or EL60 or EL Turbo icon and select Properties in the shortcut menu.
The Properties dialogue box is displayed.
3. Click the Details tab, then click the Port Settings button.
The Port Settings dialogue box is displayed.
4. Verify the following settings:
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo, 330 Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo, 330 Turbo)
5. Click OK to close the Port Settings and Properties dialogue boxes.
6. Click the Close button in the upper-right corner.
The Printers window is closed.
To check the printer settings in Windows NT
3. Click the Ports tab, then click the Configure Port button.
Select the COM port and click the Settings button.
Bits per second: 19,200 (for EL40, EL60, XL, XL+) / 115,200 (for EL Turbo, XL Turbo)
Data bits: 8
Parity: None
Stop bits: 1
Flow control: Xon/Xoff (for EL40, EL60, XL, XL+) / Hardware (for EL Turbo, XL Turbo)
7. Click OK .
Thanks
Good Luck
Don't forget to comment
Cheers!!!!
Posted on Feb 20, 2008
  • 1 more comment
  • Asfiya Ahamed
    Asfiya Ahamed Feb 20, 2008
    Yes sir... also check at the XP also..
  • Asfiya Ahamed
  • Asfiya Ahamed
    reinstall the driver software and try iy....
DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
First of all, on Dymos you need to use original Dymo roll,.
Dymo rolls have a tag at the back, non original ones does not have it.
Before reinstalling driver you also need to run the dymo uninstaller utility that you find at Dymo website.
I will post the links for download.
Oct 03, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
How do i transport the address book from old computer windows xp to new computer vista
The easiest way would be to identify the location and the file your Dymo printer uses to store its address. Copy the File to a USB memory stick, copy the File on the USB stick to your your new computer, and when you start up your Dymo printing utility open the copied file as your default address library.
The problem you may run into can be caused by different versions of the Dymo printing utility. You may be forced (using the Dymo printing utility) to export the address book on the XP computer and then import the address book on the Vista computer. The picture below outlines this procedure using Dymo printing utility v.8
Also, if you have created any custom label designs you will want to transfer them as well
Jan 17, 2014 | Dymo LabelWriter 310 Printer
Wont print
Hello
Check the usb cable.May be you will need to use a usb 2.0 one
thanks
Jul 27, 2010 | Dymo LabelWriter 320 Thermal Printer
Cannot print from computer. printer will print test pages, though
How the printer is connected to PC Via USB or using Network Cable. If it is connected Netwrok cable than printer configuration page and on netwrok configuration there will be IP Address if this is valid IP Address than reinstall drivers and upgrade the Firmware of the printer.
If Printer is connected USB than try different USB Cable and try different USB Port on the computer
If USB port on the computer is working fine and check in Device Manager if the printer has detected as unknown device or not detected at all.
If detected as unknown device than reinstall printer driver if not detected at all than USB Port on the printer is faulty you need to set up hardware repair of the printer.
Oct 16, 2009 | HP Color LaserJet 3500 Printer
I had computer problems today and had to swop my hard disk into another computer box. After doing that my Brother MFC8460N faxed and copied but does not want to print from my computer at all. I uninstalled...
Trying connecting the USB printer to some other computer,
to see if the other computer recognizes the printer.
Try a different USB port on your computer.
Try a different USB-device (memory-stick? camera?) into your USB port, to confirm that the USB-port is working.
Jul 16, 2009 | Brother MFC-8460N All-In-One Printer
HP Photosmart Printer, Mac won't recognize with USB
Sounds like their is not communications between your printer and computer. Could be a bad USB cable - swap out and see if that fixes it. If not it could be a faulty USB port on the computer or printer. You can check the computer USB port by connecting another device, but there is no way to check the HP's USB port. I would also check printer USB port for dust bunnies! If you're not able to resolve, I think it is time for another printer.
Jan 07, 2009 | HP Photosmart 8050 InkJet Printer
Dymo 320 thermal label printer: The printer suddenly stopped printing ... the labels spool through and the printer makes it's normal noise as if printing ... but no printing is done ... possibly the...
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Esselte DYMO LabelWriter 320 Thermal...
Dymo stamps doesn't see USB Dymo scale
You might try connecting the USB cable directly to one of the computer's USB ports.  My scale (DigiWeigh) showed as not connected when it was connected to a USB hub.  When it is connected directly to the computer, it shows the scale as connected.  Unfortunately, it still won't transfer weights to the Dymo Stamps software.
Dec 11, 2008 | Dymo DateMark Date/Time Stamper
Error message and won't print
change the USB cable
tray to re install the usb port from device manager
Jun 29, 2008 | Brother HL 1240 Printer
Dymo LabelWriter 320 Thermal Printer Logo
699 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
