Question about Apple MacBook Mac Notebook
Spilt coffee over keyboard
My Dad tipped a cup of coffee over this morning and a 'reasonable amount' went over the keyboard. Is his laptop doomed?!
I am not sure which model he has got but it is under a year old.
    Scholar:
  • 64 Answers
It might be :-( and usually stuff that lack isn't covered unless you pay extra for a high end warranty.
There are a few things you can do to try to save it though. As long as nothing shorted out (you didn't smell anything burning did you?), chances are a good cleaning could fix it. Are the keys sticking? Most laptops nowadays have a small try under the keyboard to keep stuff away from the vital electronics in case of situation such as yours.
1) Power down the laptop and remove the battery
2) Gently pop the keys around where the spill occurred, just pry them with your finger nail, they should snap right off with a little encouragement
3) Take a damp rag and blot up any remaining spills, or sticky spots, remember liquids and electronics dont mix so go easy on the water.
4) With a dry rag, blot up any remaining wet spots, can hurt to let it sit and air dry for a few minutes as well.
5) Pop all the keys back on and hopefully you'll be all set!
Posted on Feb 04, 2010
    President:
  • 1,216 Answers
There is an increased probability of it getting damaged only if it would be on that time.othetwise you must immediately switch it off and allow it to dry completely
Spilt coffee down car air vent
Short of complete disassembly of the dash, I'm not sure you can. Unless the coffee gets into something electrical or on an actuator, not much harm will be done. Do all of the HVAC control functions still work?
Oct 16, 2012 | 2001 Suzuki Swift
Tip
BURNZY.....YOU ARE A GOD SEND!! After calling the Keurig Service Center about my...
Symptom: keurig B100 coffee maker not brewing. If your brewer sounds like it should be brewing but little or no coffee comes out, the problem may be a simple malfunctioning check valve, located on the right hand side of the unit under the plastic cover. If the check valve is clogged or fails, water from the tank leaks into the air pump (located just below the valve) disabling the pump. This happened to my brewer two days ago. I have had this unit for about four years and never had a problem. When I called tech support at Keurig they said "it sounds like the pump is shot", but there was nothing they could do and they would not repair it. Instead of the throwing out my $300 coffee maker I figured I would try to fix it myself. After 3 hours of tinkering, I found and fixed the problem, so I am passing on the tip. Since 2.5 of those hours were spent diagnosing the problem, the fix itself is pretty simple. The pump that pushes the water out of the tank located on the right hand side of the unit (I included a photo) has a check valve just above it. On my unit the check valve failed allowing water to enter the top chamber of the pump disabling it. The pump was not damaged it just cannot operate correctly with water in it. Here is the Fix: Disconnect the check valve and make sure it is operating correctly. Mine was clogged with a small amount of mineral deposits, which was cured by a half hour in a glass of vinegar, and a good rinse. Then disconnect the tubing from the top of the pump and run the unit to allowing the water to escape the pump. Make sure there is no water left in any of the tubing between the pump and the check valve, even the smallest amount will disable the pump again. Reconnect everything and it should work. Hope this was helpful. Erik
on Dec 13, 2007 | Keurig B100 Coffee Maker
WHEN BREWING A CUP OF COFFEE, ONLY A SMALL AMOUNT OF COFFEE COMES OUT. I HAVE TO REPEAT THE PROCESS 4 TIMES TO GET A FULL CUP OF COFFEE.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 31, 2011 | Keurig B50 Coffee Maker
My machine is not brewing correctly, I have owned it for less than a year and have been very satisfied til now. It states ready to brew and brewing yet no water comes out wasting many pods too many to...
Hi, Give that thing a few good whacks on the back...there is air stuck in it and it needs to be burped...
heatman101
Aug 30, 2011 | Keurig Platinum B70 Coffee Maker
My compaq presario c 700 laptop keys sticks and runs hot, also runs very slow
sticking keys well! theres only one thing you can do about that is take the keyboard apart and wash the parts in a weak solution of detergent and clean the rest with a damp cloth--someone must have spilt a cup of coffee over it at some stage.
if it runs hot replace the fan,clean the aluminum heat sink of dust ,,hot aint such a big deal as long as the plastic isnt melting
Slow--try anotherOS
Sep 07, 2010 | Compaq Presario 700 470024-192 Notebook
My machine only brews 1/2 cup of coffee. I have de-scaled twice within the last week and I get a full cup of vinegar/water, but as soon as I put in a K-cup I only get 1/2 cup of coffee out. The first cup...
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Aug 15, 2009 | Keurig B60 Coffee Maker
Keyboard
You can try to clean the keys with a cotton swab and alcohol. Just take the key off, carefully, the clean around the key and on the plungerwith the tip of the swab. Good luck.
Sep 28, 2008 | Compaq Presario Notebook
Apple MacBook Mac Notebook Logo
416 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
