Question about Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S
I have a three year old home with a noritz tankless hot water heater. It's leaking and the plumber says the flue was plumbed incorrectly which invalidated my warranty. So, apparently I need a new tankless water heater. Does this make sense?
    Problem Solver:
  • 3 Answers
Bull ****! . If the heat exchanger is leaking, it should be under warranty. If you have and improper installation that should be the responibilty of the builder or his plumber. You may have some labor cost, but not the entire cost. contact your builder
Posted on Feb 04, 2010
I have a Noritz N063 tankless hot water heater. I am getting an error code 11. Sometimes it fires up and sometimes it doesn't. It is around 13 years old, and only started giving me trouble.
it could be leaking some where or condensation in the electricals but most hot water nits in my experience start to fail after 10 years
Dec 02, 2016 | Noritz Water Heaters
Our rinnai R94LS will shut off after running several minuets and shows error code#10. I'll turn it off for several minutes and turn back on, run system for several minuets and it will shut off again and...
Tankless computer is not working.
Error 10 is blocked flue or inadequate air supply. Or failed PC motherboard, or failed sensor etc.
Get more fresh air to unit. Check if bird built nest on flue pipe. If flue exits side of house, look for obstructions nearby that can slow the exit of poisonous vent byproduct into the air you breathe. For example trash cans and boxes or parked car etc.
http://waterheatertimer.org/pdf/Rinnai-installation-and-error-codes.pdf
Call service technician who is qualified to work on tankless computer. This will be a well-seasoned veteran of computer technology and plumbing expertise ... a plumber who knows how to fix computers lol.
This person will catch unit up on required yearly maintenance, and check specialized operation conditions needed for tankless computers to function properly.
If tankless computer is older than 5 years, then compare it to your 5-year old laptop, and assume same level of glitches and problems.
Solve any tankless problem yourself, today, for $385 by installing tank type heater from local box store:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
h
Aug 29, 2013 | Rinnai Water Heaters
Noritz NR98-DVC tankless water heater won't give hot water thru a single valve fixture. Gives us all the hot water we want on a double handled fixture. Any suggestions on what to do?
Replace single-handled faucet cartridge, and see if hot flows to that faucet again.
http://waterheatertimer.org/Crossover.html
Exposing tankless to hard water causes reduced efficiency within a few months, and can cause Total failure of parts within two years.
Do not expose tankless to more than 11 grains hard water.
Here is research pdf conducted by water softener industry comparing tankless andf tank-type:
http://waterheatertimer.org/pdf/Battelle_Final_Report.pdf
To solve problem long-long term, install tank-type gas water heater from local box store for $350.
Oct 12, 2012 | Noritz NR98-DVC-NG 100W Freeze Tankless...
Help! We bought out home 3 years ago and have a Nortiz tankless water heater. Recently we heard a dripping sound coming from the water heater and found that the bottom of the unit is leaking. We had a...
you will need to explain more of where the leak is on the bottom. You have two plastic valves on the bottom and if the clips are not on exactly it will leak and if the person who replaced valves did not use vasoline when they put it back together the could have cut the gasket ring on the inside putting in back together and again it will leak. You have to determine where the leak is coming from to begin with using a flash light to get the exact location. .
Oct 05, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
Difficult to turn the water heater
step one... remove from wall
step two... throw in dumpster
step three... purchase and install a quality tankless water heater.
Rinnai, takagi, Noritz are the only brands I install now. Aquastar (Bosch) always had problems, then purchased by Bosch but never fixed the problems, just put their name on it and sold them at Lowes or home depot.
Garbage!
Jul 31, 2010 | Bosch & Tankless LP Hot Water Heater
I have a Noritz Tankless outside my home on wall for several years. Works fantastic until now. Controller is going blank intermittently. Able to restart after resetting GFCI, plugging and replugging. On...
It sounds like your GFI is tripping. There are two common reasons for this to happen 1) plugged into another GFI 2) moisture on the gfi. I'd look for evidence of a water leak which is tripping your gfi. Look for puddles, water spotting, water hardness, etc.
Jan 28, 2010 | Noritz 6.9 Gallon Residential Tankless...
I have a noritz water tankless heater and hot water stopped. Red light blinking three times. Need help.
Three flashes typically indicates the unit is overheating due to scale. I'd try a descale initially and see if that remedies the problem.
Dec 27, 2009 | Noritz 6.3 Gallon Residential Tankless...
What is error code 59 on a noritz tankless water heater lp?
The 59 code is typically caused by insufficient gas supply to the unit. It can also be caused by obstructed exhaust flow, stuck exhaust damper (located directly on top of the unit's exhaust), insufficient makeup air, or improperly installed venting (i.e. too long or too many elbows).
I would recommend initially checking the incoming gas pressure at the gas connection on the unit. The gas pressure should not drop below 5" water column for a natural gas unit, 8" for a propane system (the unit need to be operating at its maximum output).
Apr 29, 2009 | Noritz 7.1 Gpm Propane Lp Gas Tankless Hot...
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Noritz 6.3 Gallon Residential Tankless Water Heater - N-063S Logo
304 people viewed this question
Top Noritz Water Heaters Experts
gizmonix
Level 1 Expert
jasbo
jasbo
Mack Baxter
Are you a Noritz Water Heater Expert? Answer questions, earn points and help others
