Question about Ovens
Our 20 year old gas Kenmore oven won't ignite. The digital controller indicates the oven is on...displaying 100 degrees, but the oven doesn't ignite... Worth fixing or time for a new one?
  • 80 Answers
Its the glow coil getting you to 100 but it isn't getting hot enough to iginite gas so it needs replacement, cost of doing so maybe 50 bucks if you do it yourself
Posted on Feb 05, 2010
My gas oven won't ignite, takes several tries to ignite it.
All gas appliances have a thermal cut out this will shut the gas off if the flame goes out the down side is when the thermal cut out becomes faulty it can shut the gas of when you are using the cooker the only fix is to replace the thermal cut out
Jan 18, 2015 | Kenmore Ovens
Kenmore wall oven 3052
most likely the igniter is not working at 100% and the gas valve won't open unless it is at 100%. Replace the igniter first.
Aug 12, 2014 | Kenmore 24" Manual Clean Wall Oven 3052
Kenmore electric wall oven will not increase in heat after the setting has been selected. The display is held at a constant 100 degrees; which normally increases as the oven heats up. There is a clicking...
the most common is the control board.you may have to contact the manufacturer for a new board,my supplier does not have a replacement board listed
Jan 23, 2010 | Ovens
Not the right temp in the oven 100 degrees off
I have a kenmore gas range with digital display that will let me increase the temperature up to 35 degrees f*. It says to press BAKE for 6 sec., then use the number pad to increase or decrease then press START.
Hope this helps
Don
Jan 05, 2010 | GE Ovens
My oven temperature is 100 degrees hotter than it should be
It will be the sensor inside the oven compartment that is causing the problem.
A new sensor should cure the prob, certainley cheaoer than buying a new oven.
Hope my advice helps you.
Dec 15, 2009 | Kenmore Ovens
Oven won't heat up 100 degrees continues to show on console
Is this a 120VAC. gas range or 240VAC. electric ?
It sounds to me as though it is gas and the bake ignitor is faulty.
If it is 240V AC. You've likely got a control issue or source voltage problem.
Try swapping out the ignitor, that should allow the oven to ignite. The reason it is only showing 100 in the display is the ignitor is the only source of heat. If it is left like this long enough it will also destroy the bake burner assembly as it is likely a hot surface style. so try and fix it asap.
hope that helps,
Good luck
Oct 17, 2009 | GE Ovens
I replaced the igniter (glow bar)on our Kenmore
IF THE UNIT IS 14 YEARS OLD BE CAREFUL THE GAS VALVE MAY BE GETTING TO THE POINT WHERE IT IS NOT SHUTTING OFF AS QUICK AS IT USE TOO, YES THIS WOULD CONCERN ME ,YOU DON'T KNOW IF ONES OF THESE TIMES THE GAS VALVE MAY NOT SHUT AND GAS BUILD UP COULD BE POSSIBLE ,NOT A GOOD THING. PLEASE BE CAREFUL
Aug 31, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
Wont Heat at all
sounds like you have a bad wire connection someplace in the oven.
Dec 10, 2008 | Magic Chef 9815 Electric Single Oven
Controls work, but oven does not turn on
same problem, latinbeater: ink_spot1@msn.com
Oct 27, 2008 | GE JGRS14 Gas Single Oven
Kenmore 911.30464, 30465, 30469.....Wont ignite at all
there is a second ignitor for the oven unlatch bottom panel remove heat panel there is your burner and ignitor
Jan 15, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Ovens Logo
61 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
