Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where can I get a ripping chain for a Poulan Pro 18''?
  • 677 Answers
You can try the oregon chain website :
www.oregonchain.com
Posted on Feb 05, 2010
  • 82 Answers
SOURCE: What size chain does the Poulan Pro 4218 use?
It is an 18" chain .The user manual is at http://www.chainsawsdirect.com/manuals/PP_3516_4218_Man.pdf
On page 6 the part numbers for the bar and the chain are shown
Hope this helps .. if so, pls leave feedback, if not - let me know!
Posted on Jan 25, 2010
SOURCE: poulan pro with tooless chain tightening - chain will not stay on
i have a 4620 poulan that had the same problem. use it for 10 minutes, spend 15 minutes reinstalling the chain. i sent poulan an email threatening to sue them and they decided to send me the parts to change it over to the old style for free. try poulan.com
Posted on Apr 27, 2009
  • 205 Answers
SOURCE: Poulan Pro 42cc Just Won't Cut It
The chain is directional, only cuts one way. If a new chain won't cut, it must be on backwards.
Posted on Apr 28, 2009
dontbother10
  • 2220 Answers
SOURCE: 18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Posted on Feb 19, 2010
Testimonial: "you'all have been very helpful.to even ask a question at a repair shop around here you must first hand them your wallet! Thank kindly"
dleemacc
  • 281 Answers
SOURCE: My 18" Poulan Pro Wild
Sounds like your chain is to tight.Take the cover that is at right side of the saw motor off and loosen the two nuts a bit and look for a tension screw behind the bar and back it off,if the bar won't move loosen the two nuts that hold the bar on the saw.With the saw siting like you use it pull down on chain and get about 1/8 of an inch between the bar and chain.(use gloves)If the bar is blue by the chain groove You will need a new bar.Blue means the bar has over heated and lost its temper.The blue metal is brittle in other words.You should all so check the drive sprocket for wear.
If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions. Thank you for choosing FixYa.com and good luck.
Posted on May 20, 2011
Poulan Pro 42cc 2-Cycle 18'' Gas Chain Saw excess oil on chain
are you using a chain bar oil as this is a lot thicker than normal engine oil
Jul 16, 2012 | Poulan PP4218AV 18" Chain Saw
Poulan 18" PP4218 Pro 952051338 It has fuel
you may need to clean your sparkplug, or replace it
Aug 05, 2011 | Poulan 952051338 18Inch Chain Saw Chain 38
Purchased like new PP4218 from local, bought for his son, after one tree, son lost interest. No manual with saw. What chain and bar do I buy as replacements? He replaced chain, not sure it is correct...
it's an 18 " poulan bar and chain...just a standard bar and chain for poulan...most of the aftermarket brands have a cross reference that will give you an idea on which to use
Jan 23, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have Poulan Pro 42 CC 18" Chain Saw. When I
Check to see if you have the chain oriented correctly - it is east to put them on backward without realizing it. Th3e teeth should point forward, with the anti - kickback lug in front of the tooth. Let me know if this helps!!
Nov 05, 2010 | Poulan Pro Chain Saw 46cc 20"
How does the throttle cable route on a poulan pro 260 42 cc chain saw
HOW DO I INSTALL AN ACCELERATOR CABLE ON MY 260 PRO POULAN CHAIN SAW?
Oct 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2 cycle gas chainsaw 18 inch. Was real
no bar oil should just hurt your chain and bar. remove them and try to start saw. if it still won't start you have other problems you may have to buy a new bar and chain
Feb 02, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Jan 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Apr 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
918 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
