Question about Belkin Computers & Internet
I have a Belkin F5D8233-4v3 router. I can get just one wired port to work. I use both wireless and wired connections. Could this be a hardware or software problem?
    Scholar:
  • 64 Answers
That's a fairly new router, you shouldn't be having those issues. Make sure you're identifying the uplink port, the quickstart guide with router should help with that.
If everything is wired correctly, it could be either firmware of hardware. Might want to try calling Belkin or even where you bought it from to see if you can exchange. Sounds like you got a defective unit. Alternately, try going to Belkin's website and downloading and installing the latest firmware for the router. If that doesn't do it, then you have a hardware failure, and Belkin should owe you a new router, that router claims a lifetime warranty.
There is a new firmware v4, sounds like you have v3, check here:
http://en-us-support.belkin.com/app/answers/detail/a_id/521/kw/F5D8233/r_id/166
Posted on Feb 04, 2010
2 Suggested Answers
kakee
  • 1269 Answers
SOURCE: F5D8233-4v3 - Belkin Wireless Router
You must configure the wireless settings of the laptop manually. It should match the wireless settings of your router. If you have wireless encryption enabled, make sure to type the network key on the wireless settings of your laptop.
Posted on Jun 30, 2009
Hello, I am currnetly using a Belkin ADSL2+ modem with wireless G Router and have just been given a D-Link Dir-855 Xtreme N Duo router I wish to use and have been told I can buy a ADSL Modem only to...
I think there is no need to replace the ADSL2+ Router.
Belkin is fine and should work well in combination with the D-Link Router and you would get the downlink data rate up to 300Mbps.
I recommended that you use Belkin Router as ADSL Modem and Dlink to provide wireless access. (Instead of buying ADSL Modem)
So, all you have to do is : -
-Turn-off wireless signal of the Belkin modem.
-Connect the Dlink Router to the Modem (Belkin) through CAT6 Cable.
-Configure the Dlink Router, Secure it and Enjoy 300Mbps Data Rate.
(In this way your Belkin will serve as ADSL Modem and Dlink would be the wireless router)
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
May 09, 2011 | D-Link Xtreme N Wireless-N Gigabit Router...
Can not connect to internet on my laptop with belkin router f7d3302vi
The Setup CD does not automatically start.
  • If Belkin Setup does not run when you insert the CD-ROM, your computer may not be configured to open CDs automatically.
  • If Belkin Setup does not appear within 15 seconds, browse to your CD-ROM drive and open the "Belkin Setup" icon.
  • Alternatively, you may visit HYPERLINK "http://router/" or "192.168.2.1" and perform the setup manually. Belkin Setup cannot find my Router.
If Belkin Setup is not able to communicate with your router during the installation process, please check the following items.
  • Make sure that the wireless hardware on your computer is turned on, if available.
  • Try connecting your computer to one of the four "wired" ports on the Router with an Ethernet cable.
  • Ensure that the Router is on. The front panel LED should be lit.
  • Unplug the Router's power supply for 10 seconds, then plug it back in. There may be firewall software on your computer preventing an outgoing connection. You may choose to temporarily disable this software before attempting setup.
once you login to router page by 192.168.2.1
under wireless click channel & ssid ->change a diffent name in ssid
under wireless click- >security ->use 64 bit wep and disablw wifi protected set uo would work fine
Aug 11, 2010 | Belkin (F5D5231-4) Router
Wired connection randomly drops
Since the wireless works fine on your router, then it is possible that there is a problem either on your ethernet cable or on the port of the belkin router.
Try a different ethernet cable. (Ethernet cable is the one that is connected from your computer to the router.) If you don't have a spare cable, you can directly connect the computer to the modem, just to isolate the issue and determine if it is the cable or the computer itself.
If you have determined that the cable is working fine, then try a different port on the router.
I hope this helps!
Jul 24, 2010 | Belkin F5D7234-4 Router
Trying a add another desk top to an existing Belkin wireless G router at home. Right now there's a desk top and laptop working off this router.Try several times and still can't connect to internet.
Make sure the Belkin wireless is the only device directly connecting to your internet service provider's router/modem. Usually that port is labelled "WAN" or even "Internet". The Belkin should have extra ports/jacks for WIRED connections, right? You then connect the PC into the other remaining ports/jacks on the Belkin (if they're wired) or just use the wireless for the laptop if the laptop has wireless. After getting the wireless going, though, you should lock it down by using WPA encryption key if possible.
Feb 24, 2010 | Belkin (F5D7230-4) Router (587009)
WIRELESS ROUTER
Well, Your Modem will have the cable wire from the wall going to it... from the modem the wire will go to the "Input" or "IN" line on the router. Then, there should be other ports (about 3 - 5 on most) where you can plug in a cable and connect THAT cable to the computer. Usually, the "IN" wire on the router will be closest to the power wire and/or away from the other ports. Try that and see if it works.
Jul 06, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Jan 05, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Using 2 routers
You may use your wireless router as an Access Point:
1. Connect one of the LAN port of the Belkin to a LAN port on your Voyager. If the link light on both side are not coming on, try using a cross-over cable. Important: Do not connect anything to the WAN port of your Belkin.
2. Configure the LAN IP address of your Belkin in the same subnet as the Voyager. By example, if your Voyager has 192.168.0.1, you may give your Belkin 192.168.0.3.
3. Disable the DHCP server on the Belkin since the Voyager most likely already has one.
4. Configure the Wireless parameter of your Belkin as you would normaly do.
Using this method, your wired and wireless devices will be able to communicate together since they will be on the same network and your Belkin will act as a bridge between the wired and wireless network.
Apr 20, 2008 | Belkin (F5D7231-4) Wireless Router
Networking
You actually have a couple of issues here. Fix these in this order. 1.) Login to router and turn off wireless (if you're not wanting to use wireless) 2.) Connect the ADSL modem CAT5 port to the WAN port of the Belkin router. 3.) Login to router and turn on NAT and make sure DHCP is enabled. 4.) On your Windows machine turn on DHCP under the network settings. This should allow your connection to be setup automatically and stop wireless access on the Belkin router. Let me know if you need more help. JC
Jun 24, 2006 | Belkin Wireless (F5D7130) 802.11g/b...
Computers & Internet Logo
608 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
