Question about Goodman GMS90703BXA Heater
Furnace was blowing cold only, now no power at all. Code indicates control failure. Can't get it to reset.
  • jamesfallerj Feb 04, 2010
    I have no power at all now. I have tried to restart it with no luck. The error code light is black, not on. Which according to the key is control failure. I know after 3 tries it locks itself out, but I should be able to reset it by turning the power switch off and then on again right? I've done that several times and nothing happens. Checked all fuses and fuse box, everything is good.
  • 506 Answers
It could possibly be the igniter itself. When the furnace turns on does the igniter start glowing after about 15 seconds? The comes on so that is telling me the control circuitry is ok, I would definitley check the igniter. Here is a parts list for Goodman Furnaces.
http://igate.northernplumbing.com/partsbreakdowns/GoodmanMfg/GMS9.pdf
Good luck man.
Posted on Feb 04, 2010
  • David S. Feb 04, 2010
    Try locating a small bi-metal thermostat with a tiny button on it. This will reset the thermostat and allow power to be supplied to the unit. They look like this.
    http://img.diytrade.com/cdimg/510438/455...
    If this does not work the main limit may be tripped. This would be reset by cycling the power to the furnace. It may be a combonation of both however. If the main limit is stuck you can jump across the two terminals with an INSULATED screw driver. If it turns on then your main limit switch needs replaced. BE VERY CAREFUL WHEN DOING THIS THIS IS A SHOCK HAZARD. The main limit switch looks like this.
    http://www.hvacpartstore.com/products.ph...
Error code= two red flashes, lockout/ no flame
Trane XV80 hard lockout, 2 flashes, Can't be reset - DoItYourself ...
www.doityourself.com > ... > Gas and Oil Home Heating Furnaces
Jan 10, 2013 - The only way I can get diagnostic Red LED light to reset is to switch ... a2 flash with absolutely no operation from the furnace does seem to ..... inducer gets a demand you should get a pressure switch error code 3. ... the flame sensor wire and giving the furnace a heating demand after resetting power twice. Luxaire Furnace Blowing Cold - 8 Red LED Flashes
Mar 1, 2010
Winchester furnace diagnostics
Feb 14, 2010
American Standard Freedom 80 - Cold Air - Getting Error Code 9 ...
Nov 20, 2009
York ignition lockout due to retries
Dec 29, 2008
More results from www.doityourself.com
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
cause this fault. 2 RED FLASHES: This indicates that thenormally open pressure ... The furnace will lock out for one hour and then restart. 7 RED FLASHES: This fault code indicates that the flame could not be established. This no-light ... problem. Bothheating and cooling operations will be affected. Check
Jan 23, 2016 | Heating & Cooling
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
RV FURNACE
It's hard to answer your question without the age and brand of your heater but the blinking of the red light can be a heartbeat, which indicates all systems are ok and there is power or the blinking is like 2 blinks, pause, and 2 blinks, pause repeating. That would indicate a failure code. In that case Google the model and serial number to get the failure code.
Oct 26, 2014 | Heating & Cooling
Furnace blowing cold air
Turn power off & on again. Watch to see if it cycles...it could be the hot surface igniter if you don't see it turn bright orange. If it goes straight to blowing cold air, then normally it is a limit switch open- mostly manual reset - thermal disc-located around flame rollout.
Dec 20, 2013 | Ruud RGTM10ERBJS 100K BTU 95%...
Comfortmaker furnace model GUH075 requires resetting for flame to light?
Is this an oil or gas fueled furnace? All heating appliances have several safety switches in the controls. Flicking the on/off switch (assuming you mean the emergency toggle switch) is not resetting the burner. If you pressed a button near the red light,that MAY have been the primary control reset.
Your problem could be anything from the main power switch to one of the many controls with a wiring or sensor issue. Or even a t-stat wire problem.
Regardless, a thorough technician should be checking the entire circuit, from the t-stat to every control in the circuit. Including every wire.
Lastly, a qualified licensed technician should never diagnose without being in front of the appliance. Hope this helped :)
Jan 30, 2013 | Heating & Cooling
Just had power failure and now the green light flashes for a bit while it makes a funny noise and wiil not blow cold
Unhook the power for 10 sec and retry. If the power failure was due to a storm lightening ect could be a problem. Is this a split system or window unit. Is the green light on the furnace if it is on a split central unit or on a control panel on a window unit is it a steady flash ect...
Aug 09, 2010 | Heating & Cooling
My AC unit wont blow the cold air.
if the ac outside is working, but not the furnace, means there is a control problem with the furnace, check wires in the furnace, make sure there is a blower wire plugged into the contact marked cool on the control panel of the furnace
Jul 09, 2009 | Fedders A&B Chassis A1A07W2B Air...
Carrier Furnace wouldn't light, fan was running all the time.
Most furnaces have a photo cell if it gets dirty the photo cell does not see a flame so it trips the reset button on flame failure.
May 13, 2008 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
52 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
