Question about Acer Veriton 5600G PC Desktop
Pin settings for Acer Veriton 5600g motherboard
Need front panel pin settings on motherboard
    Sergeant:
  • 349 Answers
Go to this site download vt5600.pdf file when downloaded sellect point 4 upgrading you computer,\system boards\mainboard layout\veriton 5600g mainboard layout.
http://www.acerpanam.com/synapse/data/7117/documents/vt5600.pdf
good luck
terry
Posted on Feb 20, 2008
Power front panel conectors on acer 915m08
This Foxconn 915M08-G-8KS motherboard made for Acer Veriton desktop computers?
http://www.sella.co.nz/general/computers/components/motherboards/other-motherboards/b1jnj6/
Do not know what the Front Panel header pinout is.
(Front plastic part of computer tower is the Front Panel.
Area of contact pins on the motherboard, that the wires (Cables) from the Front Panel connect to, is the Front Panel header )
CAN see by clicking on - View full size image - that the Front Panel header is to the Top Left corner of the motherboard, by the CMOS battery.
(View of mobo is upside down, in relation to how it actually sits in the computer tower case)
Shows me it is just the normal two rows of contact pins used in a LOT of desktop computer mobo's. (MOtherBOard)
If it were I, I would use one of the LED lights connected to two wires, and touch across each two sets of pins.
Looking at the motherboard as it sits in the computer case, there is a row of pins on Top, and a row of pins on Bottom.
In your mind start at the LEFT side of the pins at the TOP.
Number them from Left to Right.
Example, Pins 1, 3, 5, 7, and 9.
Now number the pins on the Bottom, from Left to Right,
Pins 2, 4, 6, 8, and 10.
Computer plugged into power, touch the two wires of the LED light, to Pins 1 and 2.
Computer doesn't start? (Power Supply turns on)
Go to the next set of pins.
I am willing to bet Pins 5 and 6 turn the Power Supply on.
No? Keep experimenting.
What will happen if you touch the WRONG pins?
N-O-T-H-I-N-G
You will NOT hurt the motherboard.
When you get to the correct pins, the Power Supply will turn on.
These pins are for the Power On switch.
Now go back through the pins with the Power Supply on, but DO NOT touch the pins that turned the Power Supply on.
When the LED light STAYS on, you have the pins for the Power On LED light.
If the LED light BLINKS, you have the HarDDrive activity LED light.
If Windows starts to load, and you touch the Restart switch pins, the computer will restart over again, and Windows will load again.
(IF this computer has a Restart switch. I do NOT use one, even for the older computers. Just press CTRL, ALT, and DELete keys at the SAME TIME, to restart the computer, or use the Task Manager option)
One pin left all by itself? That is for 5 Volts, and only used by the factory. Leave it unconnected.
There may also be a blank spot on the Front Panel header, where it looks like a pin is missing. This is the KEY pin, and is not used.
It is just to orient where the other pins are.
Worried about getting shocked?
There may be a small spark, as you connect the wires, I will gramnt you that.
But the voltage is 5 VOLTS DC.
In comparison two D cell flashlight batteries produce 3 VOLTS DC.
The harmful AC voltage is contained in the metal enclosure, of the Power Supply. Can't get you unless you pour water on it close up, or stick a metal rod through one of the ventilation holes, in the Power Supply enclosure.
Regards,
joecoolvette
By the by. You could be a lot of people's hero, if you came back, and posted the pins for what they do. Post in a Comment.
Jun 08, 2012 | Acer MB.V1509.002 VERITON 7700G VT7700G...
Acer m464 front panel connectors
Sorry in the 1st instance for my lack of specific knowledge when it comes to ACER hardware.
Is the model of your MOTHERBOARD - Acer m464?
If so do you happen to still have a manual that came with the motherboard?
Sometimes you can see the pinout in white writing on the mainboard itself near the connector block... have a close look and see if it is there.
The pin out for the connector block will definately be in the mainboard manual. If you don't have the manual then you'll need to do a little searching for it... I'm sure a .pdf of it will be floating around... i guess start at the ACER site.
On the rack mount chassis, are the plastic chassis connectors grouped (ie. 2 wires into 1 connecter for pwr led, etc) or are they individual single pin connectors?
Either way for each group, one should have a little TRIANGLE on the opposing side to the writing. Conventionally this is your positive (+) pin when looking at the pinout diagram. Ensure you have correct polarity for all ur connections obviously.
See how you go mate.
Mar 25, 2009 | Acer Computers & Internet
Things to consider when replacing a 5600G case
I assume this is an ATX motherboard. Most cases should work. I think most cases come with a power supply but if not make sure yours will fit. I like cases with at least three drive bays which give room for expansion. The biggest problem I see with switching cases is connecting the wires for power button, hard drive LED, re-set button etc. to the motherboard. Maybe you will get a schematic with the case. Some boards are not marked very clearly in this area. You will need a magnifying glass to read this information on the MOBO. Trace the different colored wires back to the case to see what they do.
Jan 04, 2009 | Acer Veriton 5600G PC Desktop
Acer Veriton 5600g Motherboard FP1 Pinouts
well only that in most manuals further on in, it should show the pin out you require.,
Terry
Mar 11, 2008 | Intel Motherboard
Vreiton 5600g
try the following.
http://www.drivers.com/
There maybe a small charge but they are very good and have alot of device drivers in there database.
Hope it helps
Thanks J
Jan 19, 2008 | Acer Veriton 5600G PC Desktop
Acer Veriton 5500 Desk top
driver acer sound veriton 5500
Mar 08, 2007 | Acer Veriton 5500 PC Desktop
Acer Veriton 5600G PC Desktop Logo
1,226 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
