Question about Dishwashers
Glasses are blasted with grime. We no longer have the manual (apartment came with dishwasher) so don't know how to clean parts, or what parts to clean. Also, not sure what the second trap door is for. Where to put the rinse, the ''salt''? Thanks in advance for any insight into how to operate effectively this somewhat ancient appliance! (Commercial code found on inside of door: ADP 456 DW)
  • liseandsteve Feb 04, 2010
    Thanks for your prompt reply. The information I gave in the original message is the only info on the label on the inside of the door (Philips Whirlpool. Made in Germany. Mod. ADP 456 DW. Typ: NBO/2. There is another number that is not identified: 29210.) Otherwise, that's it.
  • steve
    steve May 11, 2010
    All dishwashers are not created equal. We must have a good model number from the tag inside the door.
  • 12,285 Answers
Sounds like the glasses have been "crazed" by the detergent used. The detergent is so harsh that it removes the smooth finish on the glass. Unfortunately, there is no way to fix this. The new detergents on the market now days is better and does not do this.
Also, some older machines did not have a "rinse" dispenser so there won't be a separate "trapdoor." You can try some of the new detergents that have the rinse in the detergent, ie Finish.
As you said, it's a very old machine.
Posted on Jul 27, 2017
SOURCE: Water in salt reservoir
I've had the same dishwasher for 2 years now and always had water in the salt compartment. Don't know if this is normal but disn't seem to be a problem til now. Just fill with salt as if it was empty.
Posted on Jan 22, 2008
SOURCE: G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Posted on Sep 18, 2008
mgprice
  • 744 Answers
SOURCE: soap isn't rinsing clean. It looks like there's a
Hi this is not salt or detergent. This is likely to be lime/calcium. Go to home depot or a similar hardware store and buy a gallon of lime-away or similar product. Start the dishwasher on pots and pans then once the dishwasher has filled with water open the door and pour around 2 cups of lime-away in. Let the entire cycle run and then repeat this once a week until the problem clears up. Once the problem clears up repeat this once every 3 months to prevent the problem returning. If you have any other questions please feel free to comment. Mike
Posted on Feb 14, 2010
Testimonial: "Thank you so much! I'm quite impressed."
SOURCE: an extra part inside the dishwasher
we found that part inside ours. it twist snaps on to the water out let at the back of the unit where the top sprayer arm normally connects. although we cannot find a reference in the manual, it looks like it is for cases where you want to remove the top rack to wash a tall item.
Posted on Dec 30, 2010
  • 33 Answers
SOURCE: GE Profile Dishwasher does not get get dishes
Are you getting a white cloudy film on the dishes? Do you live in a hard water environment?
Posted on Jan 12, 2011
The vent fan stops on my dishwaher
It differs in every computer model but you will probably need to disassemble part of it and use compressed air to blast off grime.---------------------------------------------------------------------------------------
vas 5054a
Nov 28, 2012 | Cars & Trucks
The dirt and grime that gets stuck between my laptop computer keys does NOT come out by blasting with a straw compressed air can
Use a toothpick to loosen it. Stop eating on your keyboard. Keyboards are cheap, maybe you should just buy another one.
Apr 05, 2012 | Dell Inspiron Mini 10 Notebook
Advent adv200p problem loading
Take a Q-Tip and rubbing alcohol gently clean the lens and allow several minutes to dry, also get a can of compressed air attach straw and give it a few good blasts to clean out dirt and grime.
Apr 04, 2012 | Advent Computers & Internet
How to clean under the keys?
Buy a can of compressed air attach straw and blast between the crevice of the keys, this will clean most dirt and grime that get trapped.
Apr 03, 2012 | Dell Inspiron Mini 10 Notebook
Mac Book Pro Mouse Button
Buy a can of compressed air attach straw, gently lift button with fingernail and give a good few blasts of air to clean out trapped dirt and grime.
Apr 03, 2012 | Apple MacBook Pro Laptop Computer with...
Shift key stick
Buy a can of compressed air, add straw, and slightly lift key and blast a few times to remove dirt and grime.
Mar 19, 2012 | Acer Aspire 1691WLMi Notebook
Pull out cam gears cant get back in ..need to know how to set timing
You need to download the factory service manual. If you haven't pulled the top end apart to at least get the pushrods out your not getting the cams in without damaging the cams or the lifters. Google the factory service manual for a buell blast.
Mar 06, 2011 | 2002 Buell Blast
Weather king furnace collecting water in top panel
modern furnaces produce water vapor.simple solution is a blast of air back up drain line,taking apart and cleaning lasts longer.if theres a u shape on drain line you might have to cut pipe out to clear blockage simply glue back together with a coulping
Jan 12, 2011 | Heating & Cooling
My GE Eterna Series 3 Quiet power is not cleaning our dishes. Mostly the dishes on the top row has lots of stuff found in the glasses and mugs. YUCK!! I ran it for a minute and there is just water in...
I just took mine apart (bottom turntable, screen, etc.) and I was disgusted by the grime and gum that was clogging everything. I think it was keeping all the water a gritty white, which constantly left residue. I am currently running a load... hope that the "clean" dishwasher actually washes my dishes now!
Nov 18, 2009 | Maytag Dishwasher
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
