Question about Jensen VM9511TS AM/FM/CD/DVD/SD Player/7" LCD Car Video Player
Touchscreen how do i access the touchscreen
    Problem Solver:
  • 3 Answers
The top right button on the face of the unit will slide the touchscreen out. Kind of like a'cd eject button' but its to open the touchscreen
Posted on Apr 01, 2008
How do I calibrate the touch screen on a Konica 7165?
To adjust the touchscreen sensitivity, perform the following:
1. Power the copier OFF.
2. Access the Key Operator Mode (Power the copier ON, while pressing the [HELP] key).
3. Touch [10. Control panel adjustment] on the touchscreen to display the control panel adjustment screen. Note: If the touchscreen is so far out of adjustment that there is no response when touching [10. Control panel adjustment], the control panel adjustment can be accessed (at this point) by touching any numeric key on the 10-key pad.
4. Touch the + at the upper right corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Check the coordinates displayed in the top line at the top of the touchscreen.
5. Ensure the X coordinate and the Y coordinate displayed in the message area fall within the standard values. The acceptable values are on the second line.
6. If the values are not within the acceptable parameters, repeat Step 4 until the values are acceptable.
7. Touch the + at the lower left corner of the touchscreen lightly with a touch pen (something with a round tip which is made of resin is recommended as a touch pen). Repeat the process used for the upper right coordinate until acceptable values are achieved.
8. As verification of a correct adjustment, touch the [CHECK] icon at the upper left and lower right corners. You should hear a beep tone for each one. If a beep tone is not heard, repeat the adjustment.
9. Power the copier OFF/ON to exit the Key Operator Mode.
Nov 04, 2014 | Konica Minolta Office Equipment & Supplies
I am having touchscreen access to icons on my huawei , The touchscreen will not let me open the lowere icons i.e.home, apps etc, any advice is most welcomed!Thanks J
hi,
unfortunately the symptoms you describe show that the digitizer(touchscreen) of your phone is bad and theres no way to fix it domestically. in newer phones, the digitizer is glued to the screen of the phone to enhance its response when you touch it , so when it malfunctions like in your case you are left with only one choice to have the entire screen replaced. the upside though is that these parts are readily available from your local fix it shop.
hope this sheds some light.
goodluck mate
Jan 23, 2014 | Cell Phones
The touchscreen on my Samsung Brightside is too sensitive. Is there any way to reduce its sensivity?
go to the settings on the phone and look for the accessibility settings. under the accessibility settings there should be a screen calibration option. if present select it and follow the directions. generally the touchscreen sensitivity can be calibrated to help deal with most sensitivity problems, but the problem can also be inherent with the type of screen used in the phone and the hardware related to it so beware that this might something that cannot be truly "fixed".
Oct 17, 2013 | Cell Phones
Touchscreen is not responding. Web Updater Wizard couldn't find the device.
If there is a PIN set and the touchscreen has failed, you wont be able to gain access to the drive until the PIN has been entered. Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
Too much info to retype here.
- Jim
May 23, 2011 | Garmin Nuvi 660 GPS Receiver
My LG KE970 touchscreen is completely black and I can only receive call with it. I can't make call, access my contacts or know my callers because of the problem. Thanking you in advance for your help.
Please be informed that the phone has no touchscreen capacity.For navigation you use the middle button and to answer calls you have the dedicated buttons once you slide it open,
Mar 31, 2011 | LG Shine KE970 Cellular Phone
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
I have problem with touch screen n98 plus dualsim i cant make touchscreen calibration
A REGISTRY EDITOR will allow you to input the touchscreen configuration numbers manually. Of course, none of these will be much good if you dont have 'Windows" phone or cant access your Registry!!
If all this fails, ASK 'XDA DEVELOPERS', or 'MoDaCo'.
Aug 25, 2010 | Cell Phones
Touchscreen doesn't work. It happened suddenly. Garmin nuvi 255
try recalibrating the sceen. to access, turn unit on but hold power switch to the left until touchscreen config shows (35-60 seconds) follow prompts onscreen
Mar 19, 2010 | Garmin nuvi 255W GPS Receiver
Code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Nov 24, 2008 | Office Equipment & Supplies
Car Audio & Video Logo
172 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
