Question about HP Compaq Evo Notebook N410c
My Compaq Evo n610c stopped working....it went into screen saver mode then shut off two minutes later. It will not power on. There are no lights, nothing. I tried with and w/o battery in, adaptor checks out fine. What are the main components that would cause this issue and how can I replace them if needed?
  • 66 Answers
Hi, i own an n610c too,one of the most horrible and buggy designs compaq probably ever made.seems to b a prob wid motherboard.or a tiny circuit that has the pin for the power adapter to take in.mine had a similar problem and i got it fixed with that solution.i also happen to have a spare circuit.get it checked with a repair shop
Posted on Feb 04, 2010
Testimonial: "Thanks. I will try that route and see if it works. Thanks again for the fast response!"
  • Romeet Barmeda
    Romeet Barmeda Feb 05, 2010
    hello moosecobb,
    yes lets hope its just that, you can check out the thing which i told u abt, the link is http://www.pchub.com/uph/model/65--1266-...
    check out the thing called PCB-PC8415I0B-42A-VER1.0 , and as you can see there,its abt 35$ only..thts where i bought mine from...if you are told by the repair shop thats its a motherboard prob then pchub keeps the boards too..last time i checked it was under 60$..
    good luck!
  • HP Master
  • 5,660 Answers
I believe laptop is dirty inside........
The cooling system for the laptop is air cooling.
If 'Gunk' is coating the cooling system, the cooling capacity of the cooling system drops tremendously.
['Gunk' = Dirt, dust, hair, carpet deodorizer, lint, food crumbs.....you name it ]
The two hardware components that give off the most heat, is the Processor and graphics chipset. (CPU and GPU)
When a Processor (CPU) overheats it turns off. (BIOS turns it off)
This is a fail safe feature that is built-in. Keeps the CPU (Processor) from burning up.
Once this has happened an Error Code is stored, and will not be released until the inside of the laptop has been cleaned.
Should also replace the Thermal Paste on the Processor (CPU), and Thermal Pad on the graphics chipset. (GPU)
Let's start here...........
Before you dig into that laptop, you need to be wearing an ESD wrist strap, and have it's alligator clip attached to a good ground source.
Average cost is $3 to $5.
Here is but one example,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case. I feel an Anti-Static Mat is unwarranted, and can expound on that.
You can set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted)
HP Support > Compaq Evo n610c Notebook PC > Manuals > Service Manual,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=316664#2
Under the bold black subheading - Service and maintenance information - click on the first file listed -
Compaq Evo Notebook N600c, N610c, N610v, and N620c Notebook PCs - Maintenance and Service Guide
Can step by step you through the procedures. Post back in a Comment.
Regards,
joecoolvette
Posted on Apr 11, 2013
My compaq evo n610c switches itself on when the
Disconnect the power cable from the Notebook and then remove the Battery pack. While the Battery pack is removed, press and hold the power button on the Notebook for 15 seconds.
Next, reinsert the Battery pack and connect the power cord to the Notebook and turn it ON. While the Computer is booting, you can view the information on the bottom of the screen to get to the Setup Screen.
On the Setup screen, use the right arrow key to highlight the "Exit" menu, then select the option "load/get default" and press the Enter key followed by F10 keypress to reset the BIOS and save and exit the screen.
Feb 26, 2010 | Compaq Evo N610C Notebook
I have a Compaq Evo N610c laptop and when i turn it on it gets half way through the boot up process and then shuts down
Try restarting in safe mode by pressing F8 on start-up use system restore to go back to a date that your laptop worked
Jan 24, 2010 | HP Compaq Evo n610c Notebook
Screen turn off of Compaq Evo Notebook N610c
check your settings under power options in control panel, also check advanced power options in bios. very likley you will find problem here.
Jul 25, 2009 | Compaq Evo Notebook N610c
Compaq Evo N610C Faint Screen
Usually it's the inverter. Sometimes it's the backlight / lcd, and occasionally it's the lcd cable and or video card.
Easiest thing to do is order a replacement inverter from ebay. They're cheap and then swap it. You just need to remove the outside lcd bezel, it's just four or five screws and you're in business.
Feb 22, 2009 | Compaq Evo N610C Notebook
Laptop stops at screen saver
i want to know were i can download my sidebar for my laptop?
Dec 15, 2008 | Compaq Evo N610C Notebook
Evo N610c Laptop. I get an attempt to start and an immediate shutdown every
can u get in bios remve all power then plug back in not off battery use direct plug defult new bios f1 f2 f11 ect
Oct 07, 2008 | HP Compaq Evo n610c Notebook
My compaq
To force the computer to shut down - hold down your power button for 5 or 10 seconds.
-Magnon
Jun 03, 2008 | Compaq Evo N610C Notebook
Powered off.
Any beeps when you turn it on? unplug everything and then plug it back in. Make sure the monitor connections are good and that you have it turned on. Again make sure it's turned on. Sometimes it's the simple stuff. Was the monitor working well before it failed? Do you have a video card?
Remove the battery, AC, count to ten and try one last time?
Jan 01, 2008 | Compaq Evo N610C Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
COMPAQ EVO N610c MOUSE JUMPS
try reseating the keyboard and the mouse cables.
Nov 20, 2007 | Compaq Evo N610C Notebook
HP Compaq Evo Notebook N410c Logo
170 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
