Question about Packard Bell Computers & Internet
Good afternoon I have a Packard Bell Ixtrem 1907 and the on / off button on the front has broken i need a new button or front bezel complete. Can you help? Regards John Eyre
  • 34 Answers
Many computers have the same switch u can find a good used one in any pc u can find that u can pull the switch out of
Posted on Jan 25, 2011
I have Packard bell easynotee LJ65which won't turn off. I have black screen fan is on. Won't turn on or off
1-Take screen bezel plastic out by removing each screw hidden under a white circular cover around the screen hinges and pry it open with your nails.
2-remove touch button trim above the keyboard by removing 2 x screws hidden under the battery.
3-remove the keyboard by unplugging it from motherboard. be careful on this.
now rest is easy. just remember how the button board fitted in originally as it has a spring behind it. that s bit tricky but you can do it.
The Power button cable gets damaged when you shut and lift open the screen lid over the time and the button become unresponsive therefore you can't power on the laptop.
Such cable exist on ebay. Just buy one and within less than an hour you can fit it in to fix it.
http://www.ebay.co.uk/sch/damultd/m.html...
Sep 21, 2017 | Packard Bell Computers & Internet
Packard bell alp ajax c3 power button does not work.
You may well find the switch is broken or damaged in some way. To get to it means you must take the case apart.
This may help;
http://www.youtube.com/watch?v=1po_tEMQEPs
Dec 12, 2013 | Packard Bell Computers & Internet
Packard bell laptop wont power up.
You need to check your charger first. Use a voltmeter to make sure that the output matches the prescribed output.
Oct 01, 2013 | Packard Bell Computers & Internet
I have a packard bell easy note tj65-au-065,which i need a new on/off switch with its casing/hinge due to being dropped and broken?
I would take it to your home town computer repair store. Not BB or some other box store. Something like Bob's computer repairs. It should cost 10 or 15 dollars I would guess
Mar 14, 2011 | Packard Bell Computers & Internet
PACKARD BELL NEW90 SCREEN BROKEN ANY HOPE?
If there's no internal or other issue or damaged part other than the Screen, You can still replace it. Check out for more details here (Click Here).
Good Luck.
Thanks for using FixYa.
Jan 11, 2011 | Packard Bell Computers & Internet
I need to replace the screen on a Packard Bell Easynote TJ65, and I can't get the top cover off to get access to the hinges. I've managed to release the top cover on the front and sides, but the back edge...
Have you removed all of the screws from the bezel all the way around the screen - looking at the picture of the laptop there should be six screws one in each corner and two more across the top, left and right of the web cam.
Get the whole bezel loose so you can bend it down and see what is holding the bezel in place, sometimes you have to be firm in pulling the bezel away from the top plastic (back of the screen) if you bend it forwards you should be able to see what is holding it in place - good luck
Jun 30, 2010 | Computers & Internet
Need to buy Packard Bell keyboard relacement for S/N BCKB21006311: P/N 6837780001. Can you advise/?
Packard bell should be a standard PS2 keyboard, I would just get one at your local thrift store for a couple bucks. Look at the connector where it plugs into the tower and then just make sure the new one looks the same, should work good. Most modern keyboards are USB, but packard bell is old and may not work with this type. You could go find a new PS2 keyboard at a store but it will be about $20
Jun 12, 2010 | Computers & Internet
My power supply for packard bell blew up due to much power,so i
The style of power supply is different from a universal power supply. A universal power supply won't fit in the slot properly.
This website has it for fairly cheap:
http://www.partstore.com/GetModel.aspx?MfgName=Sumitomo+Group&BrandName=Packard+Bell&ModelNumber=845061&Page=1&SortBy=idealitemnumber&SortDirection=desc
Apr 23, 2010 | Packard Bell (190169) Power Supply
Want to add an additional dvd rom to my packard bell IXTMX6618 but unable to remove the front panel can anyone help
no need to remove front pannel there r slots on the upper portion of cabinet. unscrew cabinet side door and push one of the slot it will come out then u can place dvd from front connect necessary cables and screw the side door
Jan 11, 2010 | Computers & Internet
Packard Bell Easy One Silver monitor problem
Hi there.
You need to be looking at the inverter, this is a very thin circuit board located underneath the screen so you will have to remove the plastic bezel (screen surround) check the connections on that. If the screen is still white look at the inverter itself because there could be a dry joint or the coil has gone, if you are confident with a soldering iron then re-solder all the points on the inverter circuit board and try it again.
Good luck and thanks for using FixYa!!
Mar 11, 2009 | Packard Bell Easy One Silver 2120 Notebook
Computers & Internet Logo
183 people viewed this question
Top Packard Bell Computers & Internet Experts
carey w mason
carey w mason
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
