Dear All,
I am getting the below error msg in IE explorer suddenly after some time while using or browsing IE.Please suggest on this as early as possible.
OS : Windows Vista
IE : IE7
Problem signature:
Problem Event Name: APPCRASH
Application Name: iexplore.exe
Application Version: 7.0.6000.16386
Application Timestamp: 4549b133
Fault Module Name: StackHash_ff4d
Fault Module Version: 6.0.6000.16386
Fault Module Timestamp: 4549bdc9
Exception Code: c0000374
Exception Offset: 000af1c9
OS Version: 6.0.6000.2.0.0.256.6
Locale ID: 1033
Additional Information 1: ff4d
Additional Information 2: 704a928f797f0c83154805ff108b6848
Additional Information 3: fa8b
Additional Information 4: 8de5f25cbb7d67015a964074e187a22b
Thanks & Regards
Rupesh A.
If you open the website and your IE crash, don't open again. try windows update, maybe there is an update for your IE. Otherwise using mozilla firefox
You may have encountered the following message while browsing certain websites:
"Internet Explorer cannot open the Internet site http://<website>.com. Operation aborted."
This really has nothing to do with your browser or your computer. You get this error because of faulty web coding from the webmaster's end.
IE displays this error when it is unable to open a particular element on a web page.
There are many things you can do to troubleshoot this kind of problem.
Upgrade Internet Explorer.
This problem does not occur in Internet Explorer 8. Navigate to Microsoft download Center and click on the "Download" button to upgrade to IE8 or IE9 (see Below).
http://download.cnet.com/windows-internet-explorer-8/3000-2356_4-10910662.html
IE 8
http://www.microsoft.com/windows/internet-explorer/default.aspx
IE 9
Click on "Tools" and select "Internet Options." Hit the "Advanced" tab.
Click to remove the check mark next to "Show friendly HTTP error messages" under "Browsing" sub-headings.
Click on "Apply" and hit "OK." Please note this works mostly for Internet Explorer 6, although there is no harm in trying this on older or newer versions.
Add the specific website that is producing "Operation aborted" error under "Restricted Sites."
Click on the "Security" tab under "Internet Options."
Single-click to highlight "Restricted Sites."
Hit on the "Sites" button and click on "Add."
Type the URL of the website and hit "OK."
This works for Internet Explorer 7, but again, you can try this in earlier versions.
Disable or require prompt for "Active Scripting" when you view the specific website.
Click on the "Security" tab.
Click to highlight 'Restricted Sites" zone.
Navigate down to the sub-heading "Scripting."
Click to select "Disabled" under "Active Scripting."
You may also choose "Prompt" if you want IE to issue a prompt when opening the specific web page or website.
You can run a free registry scan using utilities from http://re7.info
If you are still worried about the registry or need to fix any problems with it
Hope this helps.
How much memory is installed on your system
which version of internet explorer is compatible with windows 7 ultimate
