Question about Hotpoint First Edition FEW12 Front Load Washer
My Hotpoint First Edition FEW12 Front Load Washer is filling with water, even after finishing the washing thoroughly (even off). Can you help me? Thanks in advance.
  • Archie Amphlett May 11, 2010
    The vaulve at back of the machine needs replacing. remove top, disconnect water supply and that is the part you need . Tip if machine has 2 hoses, you need to determine which is faulty, you can do this by turning hot water off 1 night if your machine is empty in morning then you know it is hot water vaulve, failing that then turn off your cold water next night.
    Sergeant:
  • 215 Answers
The inlet vaulve is faulty. Is machine hot and cold fill? if so you will need to change correct vaulve.
Posted on Feb 10, 2010
My hotpoint few12 is emptying through top where you put powder But it is spinging ,Whats wrong with it
I think what was meant is that the water seems to overflow from the top side and so washes off the powder. This can be due to a improper setting or fault on the water level controller unit as it fails to detect and stop the water flows at a lower level.
Sep 29, 2011 | Hotpoint First Edition FEW12 Front Load...
My machine won't drain and I can't find the
After having removed back panel, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Hope this helps you.
Jan 02, 2010 | Hotpoint First Edition FEW12 Front Load...
Few12 will not spin after washing, any ideas
Had the same problem. Removed the kick plate at front and unscrewed filter. In the filter recess I found a cotton wool bud. Appeared to have stopped the blade like fan spinning which appears to push the water into the drain hose. Works perfectly now.
Aug 19, 2009 | Hotpoint First Edition FEW12 Front Load...
Even when not programmed to the washer/dryer fills up with water?
Check the water inlet valves, located where the water lines plug into the machine. Also check for proper water pressure and make sure that your water pressure is not surging. If this help please rate. Thank you
Feb 12, 2009 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition takes in water but does not wash
Could possibly be a broken drive belt to the motor or motor brushes may need replacing.
Oct 28, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint FEW 12 filling problem
possibly overfilling, or blockge in dispenser or hose from dispenser to drum.
Oct 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint first edition few12 wont fill
hiya
if your machine wont fill it will more than likely be a faulty inlet valve.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Jul 07, 2008 | Hotpoint First Edition FEW12 Front Load...
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint few12, machine not filling
the timer, electronic or mechanical is not advancing to the fill contact. if mechanical the cam contact may be burnt. if electronic the gated triac [solid state relay] is burned up [replace]
Sep 05, 2007 | Hotpoint First Edition FEW12 Front Load...
Hotpoint First Edition FEW12 Front Load Washer Logo
128 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
