Question about Honda Mmd 5000 Watt Generator W/ Engine Ngk 6000H
How to find year of manufacture in a serial number for a honda generator
When was the winchester model 190 serial number b1011064 made
Google winchester arms and check the listed website
Dec 30, 2016 | The Optics
Serial # range for marlin model 60 with 18 shot tube and last shot bolt hold open
On Marlin-branded Model 60 rifles, the first two digits of the serial number indicate the year of manufacture. For example, if the serial number starts with 18... The 18 is significant, for subtracting it from 2000 gives the date of manufacture for the rifle, 1982. Likewise, a serial number starting with 17 would be a rifle manufactured in 1983.
This method has not been uniformly followed. It is valid only from 1971 through 1999. Prior to 1971, the first two digits indicated the year of manufacture. For example, a rifle with a serial number starting with 70... would have been made in 1970. Starting in 2000, this same old method has returned; the first two digits once more indicate the year of manufacture directly, with no subtraction required.
Sep 17, 2016 | Marlin Model 60 .22 Cal Rifle
I'm wondering how to read the Serial # to determine the year of the machine.
very few serial numbers give indication of year of manufacture
a year of manufacture will show when a serial number began but will not tell how many years variations of that serial number ran for
for example in 1990 a serial number 0010101 was started for the first item produced but after 10 years the serial number will be 00101999 so 001011596 will not show a year of manufacture just that it was produced between 1990 and 2000
to add more confusion
in your particular question example a model 7800576 could have been produced in 3 different countries and the serial number will be from any one of those countries as each set of serial numbers will denote which country it was made in
may be it you contacted the manufacturer technical division, they may be able to provide a matrix that will answer your question better
May 13, 2016 | Garden
Can you tell me the model of my 270 winchester rifle serial number is G1871685
This is more specific to decoding your serial number as the other information I gave was on your Model 70.
[PDF]Winchester Firearms Manufacturing Dates By www.winchesterguns.com/.../winchester.../serial-number.../Winchester-M...
  1. Cached
Winchester Firearms Manufacturing Dates by Serial Number and Year. 1866 through the early 1990s. The following pages were scanned from documents ...
What year was my Winchester manufactured? (Serial ...
www.winchesterguns.com/support/faq/date-your-firearm.html
  1. Cached
  2. Similar
Winchester Firearms Manufacturing Dates by Serial Number and Year. 1866 through the early 1990s. Below is the download link for a special resource for ...
Model 1894 (Mod 94) - Winchester Dates of Manufacture
oldguns.net/sn_php/windateslookup.php?file=win1894.dat
  1. Cached
  2. Similar
Winchester Model 1894 (Mod 94): Covering numbers: 1 - 5103249. Please enter a serial number and click the submit button.
Dates ' Winchester Collector
winchestercollector.org/dates/
  1. Cached
  2. Similar
When was Your Winchester Made? ... Serial Number ... the dates of manufacture shown were obtained from the original Winchester Factory Polishing Room ...
Winchester Serial Numbers - ProofHouse.com
www.proofhouse.com/win/index.html
  1. Cached
  2. Similar
Main Page. Lever Action Rifles Slide Action Rifles Bolt Action Rifles Semi-Auto Rifles Shotguns Military Misc. Lever Action Rifles top. Walter Hunt's Repeater
Winchester Dates - ProofHouse.com
www.proofhouse.com/win/winchester.htm
  1. Cached
Serial numbers of the Henry rifle overlap those of the model 1866 from 1865 to 1866. .... George Watrous, a Winchester employee, counted total production at ...
Serial Number info for Winchester Model 94 - The Firing Line Forums
https://thefiringline.com/forums/showthread.php?t=322230
  1. Cached
  2. Similar
Nov 27, 2008 - 25 posts - ‎17 authors Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 30 30 ? ccookin is offline ...
Winchester Model 1894/94 Dates of Manufacture
www.savage99.com/winchester1894_dates.htm
  1. Cached
  2. Similar
Our database contains values of serial numbers through 5103248 which ended the year 1982. Our sources disagree a bit, but this seems to be the best set of ...
Date Your Model 70 and 94 - RifleShooter
www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803/
  1. Cached
  2. Similar
Nov 3, 2010 - We bought a Winchester model 70 with serial number G1741812. ... Kurt. Where can I find manufacture dates for Winchester Model 1894 rifles?
Winchester Model 1894/94 Factory Records - Shooters Forum
https://www.shootersforum.com/winchester.../67350-winchester-model-1...
  1. Cached
  2. Similar
Aug 12, 2010 - 7 posts It should now very clearly show the progression of verified dates of manufacture. I do not plan to add any additional new serial numbers to the ...
  1. Cached
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
  1. Cached
  2. Similar
May 01, 2016 | Optics
Serial number look up
On the bottom of the Xbox 360, you will be able to see the Xbox 360 manufacturing date and the Xbox 360 serial number. The manufacturing date is in the following format:
2008-11-03 this is how you read it
YYYY-MM-DD
(Year-Month-Day) which is the date according to ISO 8601.
This would
The serial number looks like this:
6144526 84302
the serial number is formatted (LNNNNNN YWWFF)
  • L the number of the production line within the factory,
  • NNNNNN the number of the Xbox within this week.
  • Y the last digit of the production year,
  • WW the number of the week of the production year
  • FF is the code of the factory (02: Mexico, 03: Hungary, 05: China, 06: Taiwan),
So taking the serial number 6144526 14302 this would give us
  • Line 6 of the factory
  • This would be 144526 off the production line
  • 2008 production year
  • Week 43 of the year
Aug 08, 2014 | Microsoft Xbox 360 Console
Year 2000 honda odyssey car radio code
This can only be retrieved by the Honda dealer. You will need the VIN and possibly the radio serial number meaning that you will have to pull the unit out. Call the dealer first. If they want to charge you for this, let me know. I may be able to get it for free but MAY require you to pull the radio. some manufacturers require the VIN and some.... the radio numbers.
Feb 16, 2011 | 2000 Honda Odyssey
What year was this dryer made
The date of manufacture is determined by the SERIAL NUMBER on the appliance. The following link explains how you can determine the date on Whirlpool manufactured appliances:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
Locate your serial number. It should be on a nameplate around the door opening, along with the model number.
The second DIGIT in the serial number represents the YEAR it was manufactured. The next two NUMBERS following that digit, represent the WEEK of the year it was manufactured (52 weeks in a year).
If you have questions about how to read your serial number, please post back and let me know. I hope this helps you.
Jun 08, 2010 | Whirlpool LEQ8000JQ Electric Dryer
What year is this Kenmore dishwasher Model # 665.15831791 made?
The date of manufacture is determined by the SERIAL NUMBER on the appliance. This dishwasher was manufactured by Whirlpool. The following link explains how to determine when it was manufactured:
The serial number is usually located somewhere around the door opening. The first two numbers in the serial number identify the WEEK it was manufactured (52 weeks in a year). The second DIGIT in the serial represents the YEAR it was manufactured.
If you have difficulty determining the manufacture date, please post back with your serial number and I will assist you. I hope you find this information helpful.
Mar 29, 2010 | Dishwashers
I,m wiring an outlet in the garage to plug my honda 3000 into , to power a few circuits in the house. How many amp circuit can I run with a Honda 3000? Thanks RJ
On your sump pump, there is something called a nameplate which lists model number, serial number, manufacturer, and power requirements. The power can either be listed in watts directly, or in amps (at 120v). Also click on this web page and You will be able to figure it out. http://www.donrowe.com/inverters/usage_chart.html Hope that answers Your question.
May 26, 2009 | Honda 3000 Watt Portable Generator
Honda Mmd 5000 Watt Generator W/  Engine Ngk 6000H Logo
350 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
